« 1 2 3 (4) 5 6 7 ... 9 »
Re: ## 1200 and 120y strut and brake upgrades ##
From mandurah
i have used 1200 LCAs,steering arms and tortion bars and cut springs(just so its drivable)
my wheels are 13x6.5 jellies
PS stupid question but did the 1200 coupes come out with disc brakes and will they fit in a 1200 ute ?
Posted on: 2009/10/24 13:08
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
From Mandurah, Western Australia
The 1200 coupe came out standard with disc brakes on the front. This is the same strut assy as the later 120y
If you had said 2 months earlier you wanted some. Could have given you a set. Gave 4 sets away to a guy building a buggy.
Posted on: 2009/10/24 14:10
From mandurah
hey old_school I saw you at that pinjarra festival thing and you had your coupe on display ther
oh thst sucks because i need 120y struts
Posted on: 2009/10/24 15:13
77 1200 ute
4speed 60a box
hd clutch
2 inch exhaust
Estyre - You could do a brake upgrade on the 180B struts and they have a larger stub axle assy. Some adjustable camber tops should correct the alignment issues you mentioned i another post.
Onve you have the bigger disc on your strut, make some mounting brackets out on 10 mm plate. to suit the matching calipers.
Posted on: 2009/10/24 15:34
Nothing was lost during the site upgrade. Posts and wiki articles are still there.
S13 Strut Swap. See the B210 section of the article. Lot of pics.
Posted on: 2009/10/24 18:01
From mandurah
yeah i would up grade my disc anf calipers on the 180b struts but the wheels still hang out of the guards heaps although it looks awsome it isnt legal
Posted on: 2009/10/27 14:30
77 1200 ute
4speed 60a box
hd clutch
2 inch exhaust
From northern 'burbs adelaide
ddgonzal, the writeup on how to convert 120y struts to s13 disc was lost out of the wiki not the s13 strut conversion
Posted on: 2009/10/27 20:12
From Griffith
My question is if i run r31 struts with all the suspension upgrades thats needed for these to fit , will i have a offset that will make my wheels stick out of the gaurds , or will it sit in about the same spot as the 1200 struts/brakes ?
Posted on: 2009/11/16 11:01
From Geelong, Vic
track will increase about 30mm with r31 struts, but you can run more positive offset wheels on them to bring it back in a bit
Posted on: 2009/11/16 12:05
From Johannesburg-South Africa
what cars do the 180b struts come in?
Posted on: 2009/12/4 8:12
