GA16 engine vs A series
From NZ
Saw this engine listed for sale (wishing I'd bought it now). GA16 for sale/sold
The comments from the seller are that "A" series gearbox bolts straight up.
GA16s have 76 bore and 88mm stroke (not so keen on the latter aspect). Apparently around 105HP std.
Does anyone know much about these engines? Wonder if the bellhousing pattern for this example had somehow been modified? (this would be an unusual?) Wonder how far off the head gasket pattern is from an A series? (bore is comparable) Are the heads a good design?
Food for thought.
Posted on: 2010/1/9 11:02
1200 Coupe Racecar, mid-mount A13, C/R 60L g'box.
Previous "Datsuns": B310 sedan worked A13. B310 coupe A14/dogleg 5-spd. 260C sedan, L26, 3-spd man col chng, 6-seater great tow car!. VL wagon, RB30, 5-spd. Nissan Bluebird SSS U13, SR20, 5-spd.[i...
Re: GA16 engine vs A series
From Melbourne, Oz
not verry close Open in new window
Might be a good piston option, if performance parts are more commen?
Posted on: 2010/1/9 14:55
"I hav achieved wood"
Not too shy to talk
From Sacramento, CA, USA. Where the tax dollars die.
There have been several threads on GA16DE RWD with an A series tranny.
link
http://datsun1200.com/modules/newbb/v ... 95&forum=1&post_id=298408
It appears that the alignment dowels line up and either 3 or 4 of the bolt holes line up. The input shaft may be too long. GA16 starters may be either on the engine side or the tranny side. A flywheel with the ring gear on the engine side will be required for the swap. In stock form up to 115 hp can be had. Performance parts are expensive. Search the web for more info.
Posted on: 2010/1/9 17:27
From St. Louis, MO USA
Do any of the GA experts know the bore & stroke of the (rare) GA18? I read they have the same stroke as a GA16 (88mm)?
What cars in which countries had GA18s? Thanks, Peter
Posted on: 2010/1/9 18:22
Nope. It bolts up [edit:]partially but not "straight up".
However, there is a RWD gearbox for the GA engine. See 1200 tech: GA Engine Swap
A GA18 is perenially discussed, but appears to be a global legend, always existing in 'some other country' but never actually seen.
Posted on: 2010/1/9 20:41
Edited by ddgonzal on 2010/1/9 23:20:17
From New Zealand
yeah i talked to a friend of the guy with that ga for sale on trademe, he'd had issues with starter/fywheel and never got it finished and dragged it out and went sr20 instead. Lucky it sold cheap!!
Posted on: 2010/1/9 23:07
From bop new zealand
hey boys and girls first post and gess wat i brought the motor in question and yes it does bolt up up 2 an a series box! 4 bolts line up and ive drilled out 2 more so now ive got 6 2 work wif! the motor is a minta done 60 thou clicks and it has no signs of wear on any workin parts at all not bad for 51bucks aye? theres only a few things im goin 2 have 2 do too fit the motor in the ute got notch the crossmember 2 dorp the motor low enough. make new mounts bigger and stronger ones and try find a crank angle sensor or cut a hole in the fire wall for the dizzy!and thats bout it
Posted on: 2010/1/24 7:05
Pretty big job
Excellent buy at $51! Take pics and let us know how it is progressing.
Posted on: 2010/1/24 7:13
will do ill start a build therad once its all done too busy giving the ute a full freshen up
Posted on: 2010/1/24 7:16
