Browsing this Thread:
1 Anonymous Users
Re: Silvia-Specr's Project Sleepy |
From Vancouver, Wa
Had the steering link shortened today and installed, the rack works nice and smooth. Installed the turbo and exhaust mainfold. Heat sheild is on too.
Posted on: 2011/3/13 6:47
1969 Datsun 1000 (B10) 1972 Datsun 1200 coupe (ADVAN) 1981 Datsun 210(B310) 4-door (sr20det) 1971 Datsun 1200 (sedan)
From RAdelaide
Like the rocker cover mod, in your opinion, whats best way to do it. I reckon it makes the motor look like a lotus twin cam
Posted on: 2011/3/13 8:42
"My mind is a raging torrent, flooded with rivulets of thought, cascading into a waterfall of creative alternatives." - Hedley Lamarr, Blazing Saddles
From Vancouver, Wa
I tried getting acouple of different machine shops to do it, but they all said no. so I just used a grinder and a sander. still got some more fine sanding to do then it's off to powdercoat. and Thanx for the compliment.
210 011a.JPG (118.51 KB)
Posted on: 2011/3/13 9:18
From mandurah
thanks silvia-specr ,what are the main advantages to rack and pinion and could i run it without power steering ?
did you need to shoren the rack ? and can you please explain how you are putting the 240sx front end in ? what mods ? and what components are you using
thanks :) nice work ,those dress up bolts look shmicko!!!
Posted on: 2011/3/13 12:36
77 1200 ute 77mm bore a15 ,12:1 comp ported and reconed h89 head fairly aggro cam ,billet rocker spacers twin 40mm solex carbs on bpro manifold MSD 6al2 with 2 step limiter 4speed 60a box hd clutch 2 inch exhaust locked 4:11 ute diff ...
From Vancouver, Wa
i am running mine with no power. mostly just trial and error, right now i will most likely end up with some bumpsteer. will work out the kinks in the system later. Thanx, here is a way i found after i had done mine. after i cut off the treaded tudes for the lines i just inserted grease fittings and filled with grease. here's a link http://www.nicoclub.com/archives/howtoo-steeringrack.htmlhope this helps
Posted on: 2011/3/16 4:27
From Vancouver, Wa
Been working on more of the front suspension, got the arms cleaned up and painted, also cleaned up the valve cover the rest of the way. and got it painted. A couple of pics also with the new center plug cover.
Posted on: 2011/3/28 6:09
From Snohomish, WA USA
Attention to details I see!  Looks great!
Posted on: 2011/3/28 7:37
'73 2 Door Sedan KA24DR, Twin Webers 38/38 Sync. Crower Stage 3 Cams/SS Valves Forge CP Pistons/ Eagle Rods Eaton M62 SC 10 lbs. Boost / 160hp Progressive Nitrous GM 2 Speed Poweglide/Transbrake 3500 Stall Ford 8.8/Mini Spool/4.11
From malta
i m going on with the same modification over the 210 - which cross member did you use???? and what r u doing on suspentions i mean both rear and front  this is a the silvia cross member & rack and pinion
Posted on: 2011/4/5 8:44
Edited by datsunsunny on 2011/4/8 21:32:50
From Vancouver, Wa
Front suspension will be s13, coilovers, brakes and arms. the rear, i just picked up a complete rear fron a 80 200sx, should bolt right in, but it is only a h165, i have an h190 but i need all the mounting transfered over. The crossmember is a combo between s13 and b310. yours looks way cleaner than mine does.
Posted on: 2011/4/12 7:04
From Vancouver, Wa
almost forgot the new pics, new engine pic, part of the front suspension in, a maxima rear spoiler fit really nicely, and the tens on the rear (just needed to put them somewhere for now)
Posted on: 2011/4/12 7:11
