« 1 2 (3) 4 »
Re: aluminium rocker cover?
From Darwin NT
http://www.revheads.com.au/performance_engine.html
check under rocker covers at the bottom...
Posted on: 2011/4/18 9:26
current project 4x4 patrol...
From Adelaide
Any one considered making a carbon fibre or glass fibre (GFRP) custom rocker cover, it is possible to chrome plate them. That would surely work out easier and cheaper. Not to discourage of course. Interested to see the product!
Posted on: 2011/4/18 10:54
From Coondle, WA Australia
as cool as the alloy one is, i really want a clear poly one, so you can see the rockers and stuff going on. Bit like the clear dizzy caps you used to get. and multi colour leads.
Posted on: 2011/4/18 11:55
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
well there you go. $245 will get you a cool alloy one.
the bottom one looks to be an l series one.
Posted on: 2011/4/18 11:57
From Adelaide
Clear poly would be cool as! Have to get a plastic with low permeability though or coat it with something to stop the oil staining it. HDPE maybe? Make a mold and bake it.
Chris has played with acrylic (those discs he had for the head), maybe he can tell you how quickly that stuff stains. I remember making molds and making things with that in school. Not sure how hot the oven was...
Posted on: 2011/4/18 13:15
From Perth Western Australia
Yeh seen those covers from revheads before they just aren't as cool as the tomei ones tho! I seem to remember some guys on biker build off or American chopper using clear engine covers (although they forgot to seal them properly and they leaked like a bitch)on one of the bikes they built
also i found these Greedy Clear Cam caver
Nitto one
this is much more promising ---> Clear Vue Concepts
I reckon if we had enough people lined up for them we could get them to make some
Posted on: 2011/4/19 1:21
Datsun 1000 it's
All-round Action!
Thou Coupe worked A14 twin bbq's
Best stuff yet Kue, Group buy Im in. Then any sticker custom paint
could be added on top or chrome stick on retro letters.
if chev ones cost 295usd ours should cost 148 USD lets do it!
Posted on: 2011/4/19 6:47
hey lamb_daiquiri,
Its possible as i'm awaiting for a dry carbon rocker cover i bought from japan for the a series.Wouldn't say it was cheap.But what material gasket would one use with a dry carbon rocker cover ?
The cover is using an L series cap hole.
cheers
Posted on: 2011/6/30 10:13
Edited by a12grunt on 2011/6/30 10:57:10
Edited by a12grunt on 2011/6/30 10:58:00
From Adelaide
I'd reckon a rubber or standard cork would work fine, so long as it's softer than the two parts it's sealing which I'd reckon it would be.
Posted on: 2011/7/1 8:38
Use silicone RTV.
Posted on: 2011/7/1 8:52
« 1 2 (3) 4 »
