« 1 ... 4 5 6 (7) 8 »
Re: S13 Struts - Firey style!
From windsor, sydney
there is no reason the std box wont work , as long as you are aware of bump steer and how to correct it , the reason for my rack conversion was to reduce the turns lock to lock compared to the std box , im in the 2 and 1/4 turns range , the std box is conciderably more.
Posted on: 2011/6/2 9:30
WARDMAN ENGINEERING
CNC machining
Race Car Fabrication
Suspension, Brake, Drivetrain modification
TIG welding of all metals
0413 595 627
From Townsville, Qld
B310 box has a quicker ratio than the B110 box
Posted on: 2011/6/3 9:25
From Chipping norton sydney
So to make this mod do Able wat is needed I have s13 compleat hubs n s13 shocks wat else is needed to make it work n wat needs to be modified cheers guys
Posted on: 2011/6/14 11:37
Well so far the list would be like :
- s13 hubs, brakes, rotors
- Your choice of control arms (910,S13,R31,Toyota Crown,ect (need to drill or adapt a bracket for swaybar on some of these arms)
- Caster arms for control arms being used (if s13 you can use r31 or chop off vertical mount and tap thread into bar)
- S13 struts with spring perch cut off and coilover kit welded on (or aftermarket coilvovers)
- 2x 1200\120y left side inner tierod so S13 outer tie rod can adjust as normal (re-tapping the rods to make them fit of course)
Jake77 has a working setup which is where I got my inspiration to start playing with this project from. The purpose of my long winded thread is to explore additional parts that may be cheaper\more common and give different results.
Posted on: 2011/6/14 12:52
From Near Bundaberg QLD
Posted on: 2011/6/14 13:34
Thanks, Sam-U-El/Racer135
4 utes, 1.5 sedans, 2 120Y sedans, 1 C120, 1 1600 sedan, all look like or are wrecks
Would work good but I foresee making up a new shorter steering column to fit it in and possible (imminant) desing rules violations edit: unless that replaces the steering box altogether?
Posted on: 2011/6/15 15:09
From Ringwood, Melbourne, AUS
This guy makes modded S13 knuckles and LCA's (Engineered to Slide), would be an easier way of getting more steering lock than fitting the steering quickner
Posted on: 2011/6/15 23:06
Deano
From Central Vic
Just a quick one, bare strut weight increase over stanza strut??
Obviously its heavier then the 120y strut but given the upgrade path this can take (four spots etc) a guide as to the base unsprung weight increase is what Im concerned with.
I have just bought lighter wheels and don’t want to put the weight back on in the strut.
Posted on: 2011/6/16 4:14
to buy or not to buy???? OK
This is the reason I have five coupes
I was going to weigh all this stuff on a friends' set of packing scales ewhen I had a chance. As it stands the assembled S13 setup I have in the pics feels like it's 15kg or thereabouts. Could be majorly wrong though since i haven't been practising logistics in a few years.
Posted on: 2011/6/16 14:15
From Cape Town, South Africa
Finally got time to start with the front suspension, here is my design:
jpg  Datto13Aug13.jpg (92.71 KB)
11688_4e4b9a4325f7e.jpg 800X600 px
jpg  Datto13Aug14.jpg (88.24 KB)
11688_4e4b9a4c48a4d.jpg 800X600 px
Posted on: 2011/8/17 11:39
Project Build: http://datsun1200.com/modules/newbb/viewtopic.php?topic_id=45104&forum=9
Don't find a problem, find a solution!!!!
www.race-tech.co.za
