« 1 (2) 3 »
Re: My engine is smoking
From sydney.nsw
thats a bad habit(smoking pot)haha. rings or seals.
Posted on: 2011/6/28 7:52
A.T.E RACE ENGINES: ( " AUST 1 " 2010 ) A15 GO THE DATTOS... 0412 864 741
From Cape Town ZA
They are so cheap to freshen up, I'd just pull the whole thing and give it some love...
Posted on: 2011/6/28 10:21
1200 GX Sedan
New(being installed)
4AGE 20V NA
Old
4AGZE 16V turbo
196.5KW/283NM
800m - 200km/h
400m - 12.3s
I mentioned VSS due to the take off and then disappearing
as you go but maybe glazed bores due to overfuelling from carbs?
Just make sure you put some reggae & avoid getting high :)
jpg  smoke god.jpg (74.08 KB)
737_4e09b303c3498.jpg 545X637 px
Posted on: 2011/6/28 11:57
From Bendigo, Victoria
Don't worry about it DD, mines been like it for years. Just keep topping the oil up.
Posted on: 2011/6/28 12:29
From mandurah
It'll stop blowing smoke if you stop filling it up
Posted on: 2011/6/28 15:22
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
From Coondle, WA Australia
by kululadotgroen on 2011/6/28 18:21:37
last time i was involved in a budget freshen up, i think it cost me more in beer than rings and seals...
ring-a-rectomey... way forward.
Posted on: 2011/6/28 23:36
EARTH FIRST! - We can mine the other planets later...'
'69 Blue 4 door Project Daisy (http://www.datsun1000.com/TopicView.asp?TopicID=668)
(https://pcmhacking.net/forums/viewtopic.php?f=15&t=5640)
(http://mx5cartalk.com/forum/viewtopic.php...
I finally found my compression tester. Here are the results. These numbers match up to the plug conditions:
#1 oily
#2 fine
#3 burn good, bit lean
#4 partially oily
The valves were adjusted correctly, at least I could get a 12 thousands gauge in each one. Forgot to shine a light on the valve seals, hard to see inside the springs...
Posted on: 2011/7/2 1:45
From Las Vegas USA
Well looks like the it's time for rings, two weak/ weakish cylinders................should be able to do a quickie ring job in a day: pull the head with everything still attached, pluck the block lay it on it's side and throw some rings in it OR use thicker oil, keep driving it and build up another bottom end. I'd likley go with the hillbilly rebuild...........cuase it's a street car albeit a very nice one.
Tom
Posted on: 2011/7/2 2:12
Thanks Tom. I have a shortblock ready to go ... it's not my daily driver so I'm not necessarily in a hurry. I won a best in class award last Saturday in a 850 car show here in Seattle, good thing the engine wasn't running while the judges came by, little did they know..
I was planning on using this head again and found two problems:
1. #1 Rocker is binding, #2 is good.
2. #7 intake valve stem seal has popped up
I guess it won't be too hard to fix those, put a new seal on #7, and swap the rocker shaft for a good one.
it has these type seals:
Posted on: 2011/7/2 2:51
So the bottom end rings are no good DD?
Posted on: 2011/7/2 5:07
« 1 (2) 3 »
