« 1 2 3 (4)
Re: aluminium rocker cover?
so i would have to get the head gasket custom made from those materials?
attached are the pics of the dry carbon rocker from seller.will take better pics when it arrives.but doesn't include the cap or the other fitting.
cheers
jpg  racing1.jpg (22.01 KB)
15239_4e0dbb4cce3e7.jpg 600X450 px
jpg  racing3.jpg (20.79 KB)
15239_4e0dbb61604f6.jpg 600X450 px
jpg  racing2.jpg (25.05 KB)
15239_4e0dbb73c576e.jpg 600X450 px
Posted on: 2011/7/1 13:22
the pictures look abit blurry on the forum.they are quite clear on my pc.
also some links showing dry carbon durability and tested against wet carbon.quite interesting
http://www.youtube.com/watch?v=BwEA9ZSap9k
http://www.youtube.com/watch?v=Uo9F_V8j9Dc
Posted on: 2011/7/1 13:28
From Adelaide
pretty much any rocker cover gasket will do. As D said gasket silicone will work if you follow the instructions. It's wide and flat so should be easy.
Nice rocker cover by the way. By not cheap are you talking 200 ish, 400 ish ?
Posted on: 2011/7/1 13:34
From mandurah
Where did you get that rocker cover from !!! I need one
And how much was it
Posted on: 2011/7/1 13:54
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
paid more than that for it.
have a quick search on google about dry carbon and how its processed compared to the "normal" wet carbon fibre as thats where the costs differ.
Dry vs. wet involves completely different processes of manufacturing. You can find extensive articles about the details on the web if you do a general search. As for pros and cons, here is a brief summary: Simply put, dry carbon is for RACE USAGE so you get the most strength and save the most weight. The weaves and quality are more consistent, but they are generally 3 to 4 times more expensive than wet carbon. Wet carbon products are hand-laid, and are more prone to small defects like wavy weaves and tiny bubbles. They do not save as much weight as their dry carbon counterparts. But on the plus side, you get an incredible combination of visual attraction, weight-reduction, and most importantly, price. All products you see on our website are wet carbon. Wet carbon products are also the most popular and most commonly referred to as just "carbon fiber" .
thats from seibon website that sells wet carbon car parts
cheers
Posted on: 2011/7/1 14:06
From Brisbane
Geez isn't that sexy, looks good!
Posted on: 2011/7/1 14:09
Need and want are different things....
Id rather the breather at the back out of sight and
maybe some gold metal flakes thrown in :)
Posted on: 2011/7/1 16:27
« 1 2 3 (4)
