« 1 ... 16 17 18 (19) 20 21 22 23 »
Re: Revhead has a new toy... 2 door sedan 1000.
So I felt like lowering the front end today, so I got out there, removed the spring pads and chopped a little out then reset the bushes and drove it around the block for a feel. Went good. I liked it.
I liked it so much that I thought I'd lower the rear, although I don't have any lowering blocks I figured I'd do the old flippy trick...
Whoops!
So now I think I might either get some lowering blocks or get the leaves reset. Dang. It looks so good though.
Posted on: 2011/12/4 6:46
From Sydney, Australia
Looking awesome.
I really need to get a good 2 door b10 sedan one day!
Posted on: 2011/12/4 7:04
Nah the front just needs to be lower
Posted on: 2011/12/4 7:09
Love the stance but I'll have to raise it a bit.
Posted on: 2011/12/4 7:10
Would handle much better at front- rear does need to come up 20mm or so
Posted on: 2011/12/4 7:17
How does it handle Don? usually lower at the rear with hardened springs handles amazing but never tried flipped springs on 1k, I did on a 73 rolla & ford xm but was awful.
The escorts in the UK if you watch some vids of ashphalt rallying youll see all sit like your last pic lower at the rear and seems to help with weight transfer/balance.
Posted on: 2011/12/4 12:29
Edited by D on 2011/12/4 16:24:26
did you just flip the rears or reshuffle the order too in the pack, i found by reshuffling the fliped one, it gave different ride height and slight handeling differences.
Posted on: 2011/12/4 12:44
From Melbourne Vic
definately looks the goods... but with no suspension travel and a bumpstop likely to be very close id say it'll not be handling too well
Posted on: 2011/12/4 12:48
CA18DET 1200 lagwagon retired
LAG510 - SR20DET 1600 sedan
1000 wagon daily - A series magic
From Snohomish, WA USA
I think the car height looks just right. The car itself looks good.
Posted on: 2011/12/4 16:12
'73 2 Door Sedan
Crower Stage 3 Cams/SS Valves
Forge CP Pistons/ Eagle Rods
Ford 8.8/Mini Spool/4.11
From Sydney
Go for a reset leaf spring stack. Replace the friction pads between the each leaf and the ride is so much better. I remember when I did mine the ride was improved 10 fold, You could actually feel the rear end working through bump and rebound smoothly.
Posted on: 2011/12/4 23:27
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
