Browsing this Thread:
2 Anonymous Users
How to identify dogleg 5 speed? |
Hey guys in need of some info on how to identify a 5 sPeed dog leg gearbox I've been told ot is one but want to make sure what should I look for ?
Posted on: 2012/2/29 3:41
Re: How to identify dogleg 5 speed? |
Posted on: 2012/2/29 4:06
The dogleg trans is marked with 63A on the rear tail housing.
John
Posted on: 2012/3/11 2:34
From Sydney.au
didnt someone ask this question just like a week ago... maybee the Tech Wiki on the LHS should be flashing or somethign ! :)
Posted on: 2012/3/11 2:50
From Sydney, NSW
put it in a car and drive it :)
Posted on: 2012/3/13 10:10
Snapped crank and still smiling, How do I do it? LOL
It doesn't have 63a but on the front casing it's stamped 60?
Posted on: 2012/3/13 10:12
datsun a15 ute
Still could be a dOgleg but depends.
Is it cable or slave cyl activated?
Posted on: 2012/3/13 14:11
From Fremantle, West Australia
If it has "60" cast into it it could be 4speed 5 speed std patern 5 speed dogleg pattern
IF its a 5 speed dogleg, the drain plug will point to the REAR, not downward as is the case for the std pattern 5 speed
or simply put it in gear in the TOP LEFT position and then turn the input shaft. If the output shaft turns the OPPOSITE direction, its a dogleg 5 speed (FS5W60L) ie you are in reverse in the top left position
to easily see the output shaft rotation direction, push on a short piece of 19mm poly retic pipe or a plastic water bottle onto the output shaft
Posted on: 2012/3/13 14:49
69 KB10 (A15 + 5 speed one day) 68 VB10 granny spec
Thanks it's def a 5 speed as it looks much bigger then a standard 4 speed box
Posted on: 2012/3/13 20:58
datsun a15 ute
From New Zealand
they made 4 speed 60a gearboxes as well so you wont be able to tell just from the size of it, they look identical to 5 speeds
Posted on: 2012/3/13 21:55
