Building a bottom end - What Pistons to use?
From NSW, Australia
My A14 turbo bottom end is on its way out. I priced up s set of forged pistons and these days there custom made for around $1300. I also got a quote on a second hand set for $900 with ping marks on the top?
I diddent want to spend so much on the A series as by the time i finish with the build, i'll be around the same $$$ as a CA18. Im looking for maybe a semi forged piston or factory turbo piston that would handle 10-12psi boost.
What have you guys used? any suggestions for this would be great.
Posted on: 2012/10/4 0:17
Cheers,
Big D
Quadruple Crown in 1980, the year my 1200 was Built.
Re: Building a bottom end - What Pistons to use?
Don't people use e15 pulsar turbo pistons or rb or Mazda mx5 ones?
Posted on: 2012/10/4 0:22
Suzuki Vitara pistons take jut over 25psi and 450hp look at the honda forums they are the ultimate cheap cast pistons that are a prerequisite in every turbo honda d16.
problem is not available in 77mm as far as I know as stockies are 75 and max about 76.2
Posted on: 2012/10/4 0:56
From melbourne
cast pistons should do, if you stay under 8000rpm at 10 psi, if you go harder try e15et pistons
Posted on: 2012/10/4 3:16
Suzuki vitara g16b pistons handle 9500rpm and 25psi plus boost they are certainly worth every penny of 120usd :)
Posted on: 2012/10/4 8:52
From Griffith
I was going to use e15t pistons when i was going to build my a15 turbo, but didnt go through with it and went ca18det instead. ive still got the pistons if your interested ill let them go for $300 inlc postage . the only problem with the e15 pistons is the compression height is taller than the a14/15 so tops of them have to be shaven down a bit so they dont stick out of the block
Posted on: 2012/10/4 9:17
From NSW, Australia
I'll get a quote on these two types suggested, the Suzuki pistons sound impressive.
Hey Dat82 i might be interested in the E15 set you have, is that price including the rings?
Posted on: 2012/10/5 3:36
Cheers,
Big D
From Griffith
yea mate with rings
Posted on: 2012/10/5 8:16
From Christchurch NZ
Those E15et slugs look very very strong. NIce thick crowns, and beefy ring lands. The too tall compression height is probably a good thing. They have like 25x the bowl volume of the standard A14 pistons. It'd pay to work out exactly what CR you want. I reckon you could run an open chambered A14 head,(H75?) and shave it down till it was a closed chamber. Then with a small cut to the tops of the pistons, (And maybe even a wee deck cut too) you could get some nice squish/quench going on. Which should make for a more stable combustion.
That's what I always wanted to do anyway. (Still have many of the parts in the shed too)
Posted on: 2012/10/5 10:07
Forced Induction!
I dont know why your getting quoted so much...I paid less for a set of 8 custom pistons from ROSS. http://www.rosspistons.com/
Set of 4 custom pistons suit any nissan for around $550.
They have a price list on the website.
Posted on: 2012/10/5 13:17
