« 1 (2)
Re: a15 pinging when slightly hot and missfires
From Malaysia
BP and BPR may look same, but actually it is not. BPR is resistor plug.
Posted on: 2012/10/16 3:03
From mandurah
ok well ive got bp plugs coming and hopefully that will sort out the pinging :D
would water/methanol injection help much ? would give a slight power boost aswell as lower chamber temps
Posted on: 2012/10/16 5:47
77 1200 ute
77mm bore a15 ,12:1 comp
ported and reconed h89 head
MSD 6al2 with 2 step limiter
4speed 60a box
hd clutch
2 inch exhaust
locked 4:11 ute diff
From Adelaide
Water injection will be similar to higher octane fuel. A rough guide is to inject water at 70% of the fuel flow rate. Simon could be on the money with vapour lock though. Try lagging (insulating) your fuel lines.
Posted on: 2012/10/16 7:33
1200 Coupe A15E - ITB
Lamb Daiquiri - a man's cocktail!
Quite a regular
From Mid North Coast N.S.W
Can someone tell me what the problem is with running a resister plug?
AFAIK all it does is filter any interference. Surely heat range would make a greater difference than BP or BPR?
(and just so i feel smart, the P means "Projected Core" on NGK plugs. The bit that sticks out past the thread...)
Posted on: 2012/10/17 12:43
'72' B110 sdn
'68' (allegedly) B110 sdn
'72' 808 sdn
'00' E50 ELGRAND
'93' JZA80 Supra
From Ballarat Victoria
The pressed metal impellors on water pumps are ok, but can cause cavitation at high speed.
Going from your first post, the pinging is definatly heat related. plugs wont fix it unless you are using a heat range far too hot and they are causing preignition.
When you are doing a burnout, the combution chambers, valves and pistons get very hot, regardless of what your temp guage says. Detonation is caused by either too much heat or too much pressure for a given octain rating fuel.
Because the problem only shows up after you have been under heavy load for a while, you need to help dump heat or retard ignition timing.
To help with heat, you have a few choices. Increase water flow through the engine while increasing water pressure(increase pump efficiency and run 16Lb+ cap). Dont run glycol coolant! Use a water wetter(like the one from Redline). Or as Lamb_daiquiri has mentioned use water injection or a octain booster.
If it was mine, the first things i would try is-
Pull 2-3 deg timing, drain any glycol and swap for water wetter and put on a 16psi cap. Put a cooler thermostat in it. Make sure the fuel mixtures are plenty rich under load.
Water injection doesnt make power by itself. It does cool thing down, which allows leaner mixtures and more timing that then make the extra power.
Posted on: 2012/10/17 22:05
VIC DYNO HIRE
From Wanneroo, Western Australia
Jesse will the officials at the track let you run without a bonnet? If so, taking it off for passes would be a quick fix to reduce engine bay temps.
Posted on: 2012/10/17 23:33
« 1 (2)
