« 1 2 (3)
Re: Sway Bar.
From Trinidad and tobago
Quick Question..
Caster Tops on 1200 springs non ajustable..Could that be acomplished?
Posted on: 2012/10/20 10:31
'71 Four Door Sedan.
Street Sleeper!
STILL LIVIN' THE 70'S LIFE !!
Re: Sway Bar.
Yes, just run camber tops rotated slightly gives some castor and camber adjustment
Posted on: 2012/10/20 10:55
Re: Sway Bar.
From Brisbane, Australia
Rallytwit wrote:
I'm running 7/8ths front 5/8ths rear Addco bars which I believe equates 22mm front 16 rear and I'm using 250lb springs front and the nisom srpings rear which I think are 110lb?? The 250lb spring is as stiff as I want to go on treaded race tires,
22mm front bar is roughly 45% higher rate than a 20mm bar, while the 250lb spring is 12-20% softer than my estmated 280-300lb. So your overall rate would be higher than my car was. Just a different way of achieving it.
Posted on: 2012/10/22 0:22
Re: Sway Bar.
have read through this topic, some awesome info in here!! Nice work.
is the std 20mm 120y sway bar a direct bolt in?
is there a car u can pull the 22mm bar off thats a direct bolt in??
Posted on: 2012/10/22 4:18
1200 Ute - Mild A12
1200 Ute - Donor Shell Sold
1200 Coupe - A14 EFI SC
Re: Sway Bar.
Yes I did it But be sure to get the 210 brackets and rubbers.
Here's a link. http://datsun1200.com/modules/newbb/viewtopic.php?topic_id=48125&forum=9&post_id=420184#forumpost420184
Posted on: 2012/10/22 5:05
Street Sleeper!
Re: Sway Bar.
B210, not 210 which is a different Datsun
There is no factory 22mm bar as far as I know. What size is the 610 (180B) bar? It might bolt in to a B210???
Posted on: 2012/10/22 5:46
Re: Sway Bar.
From Las Vegas USA
L18_B110 I'm of the stiffer bars softer spring set up so even though overall spring rates are close the handling characteristics are different..............matter of driver preference and type of circuit naturally. Of course our sports racer had no sway bars at all but it was a 70 inch wide car with actual frame only being about 18 inches wide..............not able to take advantage of wide track with a 1200.
As for bigger bars some of the slick shod GT-Lite 1200's I've seen are running 1 inch front bars but they are also running 8-10 inch wide slicks.
Tom
Posted on: 2012/10/23 5:15
Re: Sway Bar.
From Sydney
I have been working on a little side project with the rear sway bar on my 1200 coupe. This time I'm trying with a bit more of a mathematical approach. I am going off the advice of a good friend who is a racecar engineer with the baseline spring rate matched to the rear suspension roll centre and rear axle travel characteristics. I am planning on fitting up a calibrated part from "Schroeder torsion bars" based in California USA. They are the choice of sway bar for many racecar categories e.g. nascar. The torsion bars come in calibrated diameters and when matched with the appropriate 4130 chrome molly or 4005 alloy arms [which also come varying lengths], can be identified with a known spring rate. All of the technical data is available on the schroeder torsion bar web site. i.e., spring rate tables and response curve charts.
This could all end up being a total disaster with having all suspension components adjustable, trying to dial in the ultimate set-up. Different set-ups would suit different tracks and or different conditions on the same track though. Just have to start recording the set-ups and outcomes in a notebook for reference.
Anyways I plan to post up the findings once I get the bar fitted up and hopefully translates to better lap times. Plan to fit one the front as well at some point as well.
Pic for reference.
Posted on: 2012/10/23 8:19
Edited by benny on 2012/10/23 9:09:23
Edited by benny on 2012/10/23 9:19:08
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
Re: Sway Bar.
This is probably a bit late but I posted this about a year ago.....
http://datsun1200.com/modules/newbb/viewtopic.php?topic_id=55181
Posted on: 2012/10/23 11:23
Re: Sway Bar.
Benny, if you're going to that much trouble, may as well make them blade adjustable as well rather than those solid arms in the pic.
I used to adjust the rear swaybar by moving the U-shackle mounting points on the diff and loosening/tightening the nyloc nuts on the links, or swapping some poly bushes for rubber or vice-versa. It all works and its free. Making all that stuff fixed rose joints like in that pic is taking away the tuning you had with the more basic setup. To me that's a step backwards for a track car.
Posted on: 2012/10/23 22:59
« 1 2 (3)
