I want power but I also want reliability with my A-15 I'm building up. My plans initially were to turbocharge it (10-15# boost max) with EFI, cause that easily adds the most power. But a nicely built NA motor could also kick but and would probably turn out cheaper, but wouldn't be able to match the gas mileage (potential gas mileage anyway if I can stay off the gas). I think I'll stick with the turbo idea, I want it to rev to 8,000 which isn't asking much,give at least 180hp, and run 13's. With what I have planned I don't think that will be hard to accomplish. That one turbo 1200 sedan in the photos section doesn't have as much work to it as I plan to do, and he's putting out 180 hp and running high 13's in the quarter mile!! That is what I want, but I'm looking at at least a year before being able to pursue that project. Oh yeah, I took my coupe to the drags the other day...first time since I replaced my head. My previous best was like 17.5, and I improved quite a bit. First off I was running the wrong oil in my SU's, and I only got two runs in. On top of that when I tried to warm up the tires, my clutch decided to slip instead of grip. In any case, on my first run I totally bogged it out at the start, didn't rev it high enough before dropping the clutch, and ran 17.7, I knew I could go a lot faster. On the second and last run, I revved it up too high and smoked the tires through all of 1st gear and ran a best of 17.0 So whenever I get a chance to go again I think it will be no problem busting into the 16's. The mods I have done is rebuilt/balanced A-15 (stock rotating assembly and compression), street cam, dual SU's, headers w/2.25" exhaust, and oversize Si valves, not too bad I think. I wonder what other 1200's in the club are running in the quarter mile and what mods have been done????? -Andy
Posted on: 2001/9/15 12:31
