Engine block weight
From Okinawa, Japan
Any body ever weighed a bare block? I would perfer A14/A15 numbers but also interested in early A12. If somebody does have an answer please tell me if it had main caps attached too. Thanks.
Posted on: 2004/4/26 2:31
Re: Engine block weight
From Sydney
87kg- A12
93kg- A14
this info is in the tech section... i hope i got it right!
Posted on: 2004/4/26 2:53
From Okinawa, Japan
yeah that's assembled, thanks anyway!
Posted on: 2004/4/26 3:00
From Christchurch New Zealand
i can weigh an A14 on wednesday
Posted on: 2004/4/26 5:56
"If your not living on the edge your taking up too much space" Rod Millen
From Okinawa, Japan
You're the man!
Posted on: 2004/4/26 6:02
ive lifted a bare a12 (no end bolts) into my ute off the gound, would have to be about 50kg... but im an idiot.
Posted on: 2004/4/26 10:40
I just weighed my uncut A15 bare block with no caps etc and it comes in at 32kg's or 5 stone. The only thing extra on the block is its o-ringed but they would weigh bugger all.
Posted on: 2004/4/28 1:33
From Okinawa, Japan
Thanks man! unfortunately that's right at the limit of sending one through the mail (70 lb max) so packaging it would tip the scales too far.
Posted on: 2004/4/28 3:31
Pity its not a twink engine they are only 28lbs and in Holland some racers have them pumping 238hp.
http://home.sprintmail.com/~paulzielinski/page4.html
Im in the process of trying to get some prices on having a toyota t series rwd gearbox adapted to one. I can use pre pollution gear, they are crossflow with 42mm valves standard on renault 17tl versions, have very short pushrods, hemi style head and can be taken up from 1647cc standard to 1980cc with mecaparts kits.
http://www.mecaparts.com/Moteurs/R12page1.php3#ok
this link shows the upgrade options.
two bare blocks will weigh 56lbs!!
Posted on: 2004/5/1 9:57
