Diff swap
Ive heard the trx/bluebird centre will fit into the 1200 ute housing. has any one done the swap? Im looking for a ratio change. Also, do the 1200 ute axles fit the
trx centre? any info appreciated.
Mark
Posted on: 2001/9/17 9:22
Re: Diff swap
From Sydney, Australia
The Bluebird centre in question certainly does fit. That's what my diff is using.
Although there are only 2 ratios that I know of
95% came with 3.9 diff (no change)
5% came with a 3.7 diff (good for 1200 + CA18DET)
I'm running the 3.9, and I never ever use 1st gear, even on steep hills. The 3.7 is better
for general driving.
Posted on: 2001/9/17 7:37
Re: Diff swap
from memory, its the series 3 bluebird centre. grab a hold of the disc brakes as well coz the ybolt striaght up.
easy rear disc conversion.
the axles are the same size and spline as the bluebird
Justin
Posted on: 2001/9/18 4:53
Re: Diff swap
Cheers Chris and Justin for the info. Even 3.9 would be an improvement over the 4.11s the ute has at the moment. At 110kmh its doing pretty close to 4 grand on the tacho. I
might keep the 4.11s for hill climbs.
thanks from Mark
Posted on: 2001/9/18 7:49
Re: Diff swap
Not too shy to talk
hey, run 5 speed overdrive and 14's, 130kmh @ 3000 revs, only way 2 go,
economy and power
Posted on: 2001/9/19 7:30
Re: Diff swap
Sounds good but do you know any one in West Oz willing to part with a 5 speed? datwreck looked at me as if I hadnt heard of the internatinal 5 speed
A series gearbox shortage.
Mark
Posted on: 2001/9/19 8:35
Re: Diff swap
Try www.datrats.com.au
I know they are not in WA, but they do have 5 speeds, and they will
ship them to you.
Have fun
James
Posted on: 2001/9/19 8:39
