New wheels wont fit over 120Y studs.
From Canberra
G'day all,
I've just got my hands on some 13 x 6 wheels for my 120Y and the centre part where the studs go through is quite thick (3cm) and I cant get the wheel nuts onto the studs once the wheels are on. Do I just need longer studs or something more complicated. Also, the stud-holes in the wheels are a bit bigger than the stud diametre, should this make a difference?
Any info would be much appreciated.
Posted on: 2004/5/13 6:37
Re: New wheels wont fit over 120Y studs.
From Christchurch NZ
Sounds like you might need shank nuts.
Posted on: 2004/5/13 6:57
Forced Induction!
From WA
you should be able to order longer studs from somewhere like repco etc.
the hole should be a touch bigger as to let the nut centralise the wheel hole to the stud and provide a dovetail face grip to the stud hole.
Posted on: 2004/5/13 7:02
From Canberra
Thanks for the info, rang Autopro and they said they could get them in for me, is $7-8 what I should be paying?
btw, what are shank nuts? what do they do?
Tyrie
Posted on: 2004/5/13 7:06
From Toowoomba QLD
there are 2 different types of wheel nut, mag nuts, and chamfer nuts
You need the mag nuts (shank nuts) that are like a long tube shape one end and then the hex nut the other end.
Chanfer nuts are like standard wheel nuts and have a taper where they seat on the rim
Posted on: 2004/5/13 7:22
From Perth Western Australia
here's a shank nut for you
Posted on: 2004/5/13 11:21
From Canberra
Thanks for the tips, i reckon I'll be lookin for shank nuts then :)
Posted on: 2004/5/14 9:55
From Okinawa, Japan
Not all aftermarket wheels use shank nuts, though, so it may be best to bring them by your local tire shop to ask them if you're not sure what you're looking at. If the wheel's countersunk for each lug nut chances are you're not going to use shank nuts.
Posted on: 2004/5/14 17:37
From Canberra
I got me some shank nuts from supercheap today, $60 for 16, and the wheels are on, lookin great, but car darts around the road when under heavy breaking from about 80k...not very reassuring...
Posted on: 2004/5/15 11:39
Just to add to the picture, the factory mags used on Chrysler Valiants & Datsun 200B's [810] along with Bluebirds [910] use a tapered face shank nut.
I have often wondered why the two factory setups went this way & i still don't know, but perhaps it more accurately centers the wheel.
Posted on: 2004/5/15 11:44
Love your Datsun.
Treat it well.
