« 1 2 (3) 4 »
Re: Ga head flow compared to A series
From Ballarat Victoria
Nissan4eva, do you have to use a Nissan engine? is it for competition? I've tuned a couple of Toyota 4AGE 1600cc 20 valve engines lately, The one that left yesterday made 97Kw at 7600 and 140Nm at 6000 ATW with standard cams and 13:1 comp. It had manually adjustable cam pulleys that made a significant difference to putting the torque where the customer wanted it. I know its a bit off topic, but just showing it as a comparison.
jpg  4AGE resize 27%.jpg (162.62 KB)
6746_57e1bc4dccf9a.jpg 700X523 px
Posted on: 2016/9/20 23:33
VIC DYNO HIRE
any info or pics of this [GA16DE] setup??
Notice
* standard A-series engine brackets
* twin weber 45s
* hole cut into firewall so that the rear-mounted distributor will fit
Posted on: 2016/9/21 0:35
I like the VVT version
* Extra HP, yet idles smoothly
* Can trigger VVT with dash-mounted switch (no computer needed)
Posted on: 2016/9/21 0:40
In Datsun 1200, with tubular exhaust header
with remote oil filter kit, looks like a dry sump system
Posted on: 2016/9/21 0:52
GA16DE in B310
How to adapt an A-series transmission
* bolt up 3 bolts
* (optional) redrill 4th bolt
* machine GA flywheel to accept A12/A14/A15 flywheel ring gear
* grind GA block corner where A-series starter fits
* Cut extra length off the A-series spigot (or drill the GA crank deeper)
* Use pilot bushing 1/2" x 3/4" cut to length (0.69 inch)
Posted on: 2016/9/21 1:23
speak to PJZ to see what they managed and share with us
Posted on: 2016/9/21 8:54
From Las Vegas USA
D I'm not sure Peter went with the GA, it's been a year or two since I spoke to him but he was still using the A series.
Tom
Posted on: 2016/9/22 4:53
Thanks Tom
He kept saying he was going to use it next season but I guess
he must still have some hot A series left overs to abuse first
on the sentra and SR20 forums one is making 119whp with bolt ons
http://www.nissanforums.com/naturally ... or-ga16de.html#post384683
Originally Posted by Mervic Someone from another forum made 154whp out of the GA16DE using 12.5:1 pistons, shotpeened rods, SR20 throttle body, JWT cams, JWT ECU, JWT clutch, SR20 valves machined to fit, port and polish, custom 4 bolt main caps, Extrude Honed intake, header, ARP bolts everywhere and lightened flywheel. Like he said "One fun Honda killer".
Thats factory inlet manifold and compatible camshaft to suit not race cam
while cant find the link to the 178hp 1.6L race motor which had what PJZ
also mention that with little work still has incredible fat torque curve
Either way would love to see Peters setup
Posted on: 2016/9/24 1:40
Edited by D on 2016/9/24 5:52:03
From Bridgetown, Barbados. W.I
Dd this is my setup..had to make it work with 4,days to go before racing, after I damaged my 2 A15s.
4_1 extractor and twin 40s on b14 straight port ga15..
Can't use vtc/VTEC/vvt/vvl etc in this particular class, but any nissan engine under 1601ccs
Posted on: 2016/9/24 16:25
Life's better SIDEWAYS!!
Sik...not allowed to cross manufactures. But I do have a ke70 with bt20v which I use in a higher group...jus trying to keep the Datsun alive.
Posted on: 2016/9/24 16:34
« 1 2 (3) 4 »
