velocity stacks
From Canberra
Quick random question I have just had my head flowed and everything and worked out the size velocity stacks I need for my twin 45mm webers but just more a random question do the velocity stacks make a massive difference on intake noise on webers? just curious as never seen them but guess ill know once they come hopefull 4-6hp gain with them
Posted on: 2016/10/11 6:21
Re: velocity stacks
From Sydney
Ram tubes have significant impact, especially in NA applications. Take a look at full radius tapered type. they are the business. As for the noise, fitting them under the air fiters will be a challenge. Pipercross make some rather cool longish pillow type filters complete with a backing plate etc.
Posted on: 2016/10/11 7:18
1971 B110 Sedan GX Spec
1970 KB110 Coupe Track Car
1970 KB10 Coupe
S13 caliper b...
Re: velocity stacks
On my A14 I did not notice any noise difference between Velocity Stacks and open/no air filter. Both were extremely loud (like Harley loud)
Posted on: 2016/10/11 7:42
Re: velocity stacks
From Florida, USA
You might think about the curved intake runner stacks, something like inside the airbox of an M5 V-8 BMW. the radius of the curve would probably allow you to build a filer housing that would enclose them and then you would get the benefit of having a pretty long intake tract, if that is what you are after.
Posted on: 2016/10/11 15:40
Carbon offset purchases are the Environmentalist equivalent of Television Evangelists being caught with Hookers.
Re: velocity stacks
From Las Vegas USA
Velocity stacks do,make a difference on most carbs. I can tell you from my motorcycle road racing days that proper stacks will see you changing main jets so obviously there is a power increase.
Tom
Posted on: 2016/10/12 5:00
Re: velocity stacks
From Midway City, California
when i added 3 inch velocity stacks to my SU's, i had to completely retune them. so yes, they make a difference.
Posted on: 2016/10/12 6:20
if it was easy to restore, they would call it chevrolet
don't piss off America, or we will bring democracy to your country
Re: velocity stacks
Quite a regular
From Sutherland Shire
Most Modern cars use variable length runners in their intake manifolds.
Long runners promote more turbulence of the air going in giving more torque at low RPM.
Short Runners get the air in quicker and easier at high RPM as there is less restriction.
May have something to do with it.
Just my 2 cents.
Posted on: 2016/10/12 6:38
1972 1200 Coupe
SR20DE
R31 Diff
S14 Front End
Re: velocity stacks
From Canberra
Some reason not adding the pic correctly but got them today was advised for the cfm of my intake head and carbs and for how ill be driving and events ill be wanting to do a 40-50mm length velocity stack is best so I went ahead and have got 43mm billet Bell end stacks being that I already have a uni filter backing plate and cage with foam filter the cage is just not long enough so ill have to space the cage a little from the backing plate and still be able to use the uni filter along with it
Posted on: 2016/10/12 9:14
Edited by loosekid on 2016/10/12 11:57:20
Re: velocity stacks
The length mainly relates to RPM
To use a JPG link, add it between [ img] tags (lower case, and square brackets)
Posted on: 2016/10/12 10:03
Re: velocity stacks
From Sydney
I have tried a couple of differnent velocity stack lengths.
These short 50mm tapered full radius ones made for better peak power.
And these ones are much longer, resulting in a much fatter torque curve in the mid RPM range at the expense of peak power. The difference was about 4HP at the wheels difference. I went with the longer tubes with the aim of having better punch out of a corner.
Posted on: 2016/10/13 3:37
1970 KB10 Coupe
S13 caliper b...
