Browsing this Thread:   4 Anonymous Users
Hydraulic Clutch in a 1200
From Melbourne, Aus
Has any one converted their clutch over to Hydraulic?
Posted on: 2001/11/25 3:16
Re: Hydraulic Clutch in a 1200
i nearly did to put in the overdrive 5 speed i've got.
i measured it all up ready to go in but then i had the acco.
just get hold of a hydraulice clutch box, unless you've got one waiting, and then grab a master cylinder off something like 1600 (510) and work out how long the travel has to be
with the piston in it.
then work out that travel on your clutch pedal, to where it has to be located on the firewall, the ndrill and insert.
run all your pipes etc and your away.
by the way i've still got the overdrive 5 speed here if anyone wants to buy it......
Justin
Posted on: 2001/11/25 8:00
From Sydney, Australia
All of the CA18DE/T boys have. Mine uses an AE86 Sprinter/Levin/Corolla
GTS clutch master.
I had to modify the pedal box a fair bit, but it fits in nicely next to
the booster.
Chris.
Posted on: 2001/11/25 8:23
how much for the box???
what rpm in 5th at 100km/h does it get
Posted on: 2001/11/25 9:26
i honestly couldnt tell ya what revs it pulls in 5th but she's a genuine overdrive gearbox so 5th gear is 0.875:1. she's gotta be a shit load better than
the old 4 speeds.
i'm asking $1000 with a brass button hyfraulic clutch setup.
Posted on: 2001/11/27 2:43
the old 4 speeds.
i'm asking $1000 with a complete brass button hyfraulic clutch setup.
Justin
Posted on: 2001/11/27 2:44
Hyfraulic? Is that pooible?
Linc.
Posted on: 2001/11/27 3:52
Pooible hyfraulic cog swappers
From Invercargill, New Zealand
Sum of yous yung fellas ned to fas up to the fuct thad the mos liderate Datsun ohners are in New Zealand. Thair iz evadunce thad Audraleein techerz pursecude kids who lighe
Datsuns and they leaf skool and seg joobs in da eluctricool indoestree...
Posted on: 2001/11/27 5:27
From Arlington, TX, USA
This is a bit confusing? Just about every Datsun ever sold in the USA (including the 1200) has a hydraulic clutch. What on earth did they give you guys down under? Cable? Z-
bar? To answer the question, a hydraulic clutch would be a piece of cake if you got a few choice parts from a hydraulic (USA?) 1200.
>By: lump_a_charcoal
>Linc.
Posted on: 2001/11/27 9:17
From Good Old Knockfull, Tennessee, USA
Do the transmissions in your Australian 1200s and Y120s have the machined area that accepts the hydraulic slave cylinder?
If not, most any hydraulic clutch could be made to fit with a bit of ingenuity. I like the feel of a hydraulic cluch. It works much smoother than cable and especially better than
mechanical reach rods.
Mt friend, Trigg, and I were at a stop sign in his 240Z when he just lurched out in front of a car coming from my direction. He slammed the brakes and killed the motor. We almost got hit
by a car coming towards his side. Luckily everyone got stopped before any damage was done. I asked Trigg why he pulled out in front of the busy cross-traffic. He still had his foot on
the clutch pedal and it was still to the floor. The slave cylinder had ruptured a seal. Luckily, the Datsun dealer was close by and we repaired it on the street. That was in 1981.
Mareo
Posted on: 2001/11/27 10:58
