A12GX engine
The A12GX Engine is the one with the largest ports -- bigger than A14 or A15 -- and was rated at 83 hp. Only the A14E engine was rated higher
Here's one listed this month on Yahoo! Auctions for $6,500 USD
● B110 Sunny GX5, A12 engine, overhaul confirmed
● A12, front desbi [distributor], elliptical port, chamfer
● Valve spring (double)
● Valve polishing, rubbing
● Flat piston
● Water jacket, pressure wash, plug plug (new)
● Piston ring (new) - Main metal, connecting rod metal (used) - Gasket, seal (new)
● Accessories: Used, water pump, fuel pump, flywheel, disc thickness 8,5mm, clutch cover
● SU twin cab (temporary group) EX manifold, front desbi, with alternator
* Cell motor [starter] and housing are not included
jpg  a GX beauty item.jpg (64.49 KB)
174_67b163945c590.jpg 480X480 px
jpg  b GX on a pallet.jpg (62.76 KB)
174_67b163a8aaeee.jpg 480X480 px
jpg  c engine left side.jpg (62.40 KB)
174_67b163ac9803e.jpg 480X480 px
jpg  d GX with cast header and collector pipe.jpg (64.29 KB)
174_67b163b1892d9.jpg 480X480 px
jpg  e GX with cut-down starter housing.jpg (62.18 KB)
174_67b163b8716cd.jpg 480X480 px
jpg  f Hitachi Twin Carbs.jpg (64.32 KB)
174_67b163bf397bb.jpg 480X480 px
jpg  g overhead valve engine.jpg (90.28 KB)
174_67b163c41c6b4.jpg 480X480 px
jpg  h NISSAN cast head.jpg (64.23 KB)
174_67b163ccaf42c.jpg 480X480 px
jpg  i crankshaft and block breather net.jpg (64.65 KB)
174_67b163d1d47cf.jpg 480X480 px
jpg  j GX-hi flat-top pistons.jpg (60.42 KB)
174_67b163d71eed7.jpg 480X480 px
Posted on: 2/16 4:05
Re: A12GX engine
From Beautiful Sunny (sic) Melbourne
Very nicely presented engine - but it looks like it has round ports! Even if the inlet ports are oval, rather than round (which could be the case as none of the photos show the ports straight on) it doesn't look like a GX head, whch has oval inlet ports where the top of the ports seem to be the smae height or even slightly higher than the manifold studs
Posted on: 2/23 7:54
Re: A12GX engine
Well spotted there, heads are just enlarged round ports
My sambar kei truck with supercharger and 660cc makes 82hp
with just pulley change and bigger injectors and cost me
halve that pretend A12GX so for me 6500usd is a bit much.
Posted on: 2/23 13:18
A12GX engine with competition carbs
Here's one that appears to be a created GX engine, rather than a factory one. But it's all period parts, and if it has the high compression pistons, totally equivalent
has a Cherry front-dizzy M08 block, but with competition carburetors. These are flat-tops from 1973 but without the float bowl vents that production A12T carbies had. They were sold by Datsun Competition outside of Japan
jpg  a twin carb A12.jpg (171.71 KB)
174_67fefd367ab16.jpg 899X1200 px
jpg  b M08 block casting.jpg (142.15 KB)
174_67fefefdad6e1.jpg 1200X899 px
jpg  c Top twin carb.jpg (120.07 KB)
174_67feff65a8c05.jpg 1056X892 px
jpg  d air cleaner.jpg (184.42 KB)
174_67feff90931da.jpg 1200X899 px
jpg  e A12 NISSAN JAPAN.jpg (150.18 KB)
174_67feffb66fd81.jpg 1200X899 px
jpg  f right stock.jpg (117.19 KB)
174_67feffeb932a8.jpg 892X1132 px
jpg  g right spark delay.jpg (94.38 KB)
174_67ff00712a635.jpg 848X1024 px
jpg  h air cleaner base.jpg (145.60 KB)
174_67ff0075616de.jpg 1200X899 px
jpg  i left Alternator.jpg (165.68 KB)
174_67ff007bdb9c7.jpg 899X1200 px
jpg  j exhaust.jpg (83.06 KB)
174_67ff010b2da1e.jpg 832X880 px
Posted on: 4/16 2:00
Re: A12GX engine
From Las Vegas USA
Late to the party but just wow on the $6500 price tag.
Posted on: 4/16 2:48
Re: A12GX engine
It didn't sell. Perhaps the price was too higher, or maybe the price was right and the 0 bids were for another reason?
The 2nd one with the flat-tops got 24 bids and sold for 201,500 yen, what is that, $2,015 USD?
https://auctions.yahoo.co.jp/jp/auction/j1165374226
Posted on: 4/16 5:54
Re: A12GX engine
I offered my A12GX bottom end for $100 when I was selling my kb10
I ended up giving it away but little did I know that next to an A12
it weighed almost halve less, so we pulled the sump to find it had
a knife edged crank and some skinny rods with the flat tops.
Later owner found rods where kawasaki rods and camshaft was hollow
which was he said could have been using gun drilling.
It spent its life at 10k rpm plus as it was ex-speedway but how
crazy the extent some of these oval trackers go for to get the last
bit of hp, when a bit of boost on a stocky similar to TopGear a12
with an SU can make double the torque and same race hp at normal RPM.
His used a 10 degree locked dizzy which today could be helped again
with a H2O/Meth control unit for more boost, so there is no need for
big money investment for a GX when a little A12.
Yet hard to even find that these days!
Posted on: 4/18 5:53
Re: A12GX engine
yes the GX short block is identical to regular A12 except for the pistons. It also uses a Suction Pipe with an extra fitting on it for the heated manifold
Posted on: 4/18 22:49
