A12GX engine
The A12GX Engine is the one with the largest ports -- bigger than A14 or A15 -- and was rated at 83 hp. Only the A14E engine was rated higher
Here's one listed this month on Yahoo! Auctions for $6,500 USD
● B110 Sunny GX5, A12 engine, overhaul confirmed
● A12, front desbi [distributor], elliptical port, chamfer
● Valve spring (double)
● Valve polishing, rubbing
● Flat piston
● Water jacket, pressure wash, plug plug (new)
● Piston ring (new) - Main metal, connecting rod metal (used) - Gasket, seal (new)
● Accessories: Used, water pump, fuel pump, flywheel, disc thickness 8,5mm, clutch cover
● SU twin cab (temporary group) EX manifold, front desbi, with alternator
* Cell motor [starter] and housing are not included
jpg  a GX beauty item.jpg (64.49 KB)
174_67b163945c590.jpg 480X480 px
jpg  b GX on a pallet.jpg (62.76 KB)
174_67b163a8aaeee.jpg 480X480 px
jpg  c engine left side.jpg (62.40 KB)
174_67b163ac9803e.jpg 480X480 px
jpg  d GX with cast header and collector pipe.jpg (64.29 KB)
174_67b163b1892d9.jpg 480X480 px
jpg  e GX with cut-down starter housing.jpg (62.18 KB)
174_67b163b8716cd.jpg 480X480 px
jpg  f Hitachi Twin Carbs.jpg (64.32 KB)
174_67b163bf397bb.jpg 480X480 px
jpg  g overhead valve engine.jpg (90.28 KB)
174_67b163c41c6b4.jpg 480X480 px
jpg  h NISSAN cast head.jpg (64.23 KB)
174_67b163ccaf42c.jpg 480X480 px
jpg  i crankshaft and block breather net.jpg (64.65 KB)
174_67b163d1d47cf.jpg 480X480 px
jpg  j GX-hi flat-top pistons.jpg (60.42 KB)
174_67b163d71eed7.jpg 480X480 px
Posted on: 2/16 4:05
Re: A12GX engine
From Beautiful Sunny (sic) Melbourne
Very nicely presented engine - but it looks like it has round ports! Even if the inlet ports are oval, rather than round (which could be the case as none of the photos show the ports straight on) it doesn't look like a GX head, whch has oval inlet ports where the top of the ports seem to be the smae height or even slightly higher than the manifold studs
Posted on: 2/23 7:54
Re: A12GX engine
Well spotted there, heads are just enlarged round ports
My sambar kei truck with supercharger and 660cc makes 82hp
with just pulley change and bigger injectors and cost me
halve that pretend A12GX so for me 6500usd is a bit much.
Posted on: 2/23 13:18
