1/4 mile time
1972 datsun 620. L20B,single 45mm dcoe,headers,stock 4speed tranny.4.11 rearend.could somone give me an estimate on what i would do on the 1/4 mile please.thanks.any replys welcome
Posted on: 2004/10/26 20:51
Re: 1/4 mile time
From Brisbane, Australia
Taking in to account the standard weight and light tray configuration, I would have to say: 24.732seconds at 91.3mph (approximately). As you can see from the MPH it has the capability to do a high 15, if only you could put the power down. Consider a bag of traction cement in the rear right corner of the tray. Maybe 2. Maybe some slicks? Rear spring rate and damper changes. Have you considered launch/traction control?
Posted on: 2004/10/26 21:30
Re: 1/4 mile time
hey thanks for your reply.how do i change the rear spring rate and damper.and what about traction control???i found a traction spring from JC whitney catalog that reduces spring wrap.it bolts on infront of the rear leaf spring.is that good??what else could i do to get lower E.T's on the quarter mile.
Posted on: 2004/10/27 1:22
Re: 1/4 mile time
From WA
a 2 link rear end is a cheaper and easier bet in my books.
use 4 rod ends and nuts, 2 lengths of 1.5mm wall tube and some custom hangers.
set it up like so ---->
Posted on: 2004/10/27 3:37
Re: 1/4 mile time
From sutho shire
the picture is showing the tramp rods same set up i am using on my ute made by Romac, really make u get outer the hole alot quicker,
Posted on: 2004/10/27 6:07
*1200 ute ca18det (CYA-18T)
256 rwhp at 14psi wanting more power
Team New skool
Re: 1/4 mile time
where did you get those parts.looks like you got it from a company/manufacture.let me know where you got it because i like that set up.tell me how you did it.its kind of like ladder bars
Posted on: 2004/10/27 6:25
Re: 1/4 mile time
From Christchurch. NZ
Looks like a nice well made setup, Where would you get something like that?
Posted on: 2004/10/27 6:33
Re: 1/4 mile time
we are asking where did you get that or how did you make it.did you modifi it from somthing else
Posted on: 2004/10/28 18:58
Re: 1/4 mile time
From Sydney, Australia
I think it was unfair of him to post those pics. I'd say the guy did it himself.
There are very few "Nismo" or similar hotup products available for 1200 (Even with their racing history). Your 620 would never have had such parts available, as it is a work truck, not a race car. If you want it to be a racecar, you will need to design and implement solutions similar, but you would be extremely lucky find any "off the shelf" items for your truck.
If you want to be a 1/4 mile champion, you will need to assess what potential the 620 has, given your skillset, and the availability of parts.
You need to either have a friend with many tools, or have the tools yourself. Working on a Datsun is about ingenuity and knowledge of auto electrics and mechanics, and bank-account size has much less to do with it.
Posted on: 2004/10/29 2:05
Re: 1/4 mile time
The 2 link bars pictured are originally known as Cal-Tracs and originally designed by John Calvert a 3 time NHRA national winner.
Here is some info on how they work.
Posted on: 2004/10/29 3:03
