Chis Im stoked will be driving it next week when I pick it up just have to fit the harnesses
PS: they can mod the cam angle (a real pain in the ass) ended up costing $180!! but you get that. A lot of stuffing about.
Micksute the camshafts are stock items with adjustable cam gears. I looked at aftermarket camshafts but for the $$$ I can run the car for a season (nearly) .
Lagwagon As for the low figure on the dyno I think its making as much if not more power than before (190rwkw @18psi) on lower boost. It has to be as we cranked the fuel pressure up a bit and the injectors are well over 90% duty.
Im using Supra 7mgte injectors they are rated at 430cc the gtr ones you have are only 440cc from memory. Ill stick with what I have as its making good power with a pretty low boost setting. Good for engine reliablity.When I feel the need for more spped Ill look into bigger squirters.
Datman I was very nervous too. Good luck with yours. I rebuilt the engine over a few nights (very late ) tired ect all was good except I had the cam timing out a bit. When it first fired it sounded like it had a huge set of cams . Now it idles like a baby and mega responsive a little loud if anything with the new exhuast.
