Where to find U-bolts and the plates to suit ute diff?
From Brisbane, Narangba
I have not rung around yet just wondering if anyone can tell me where to find U-bolts and the bottom plate and the top plate where the u-bolts sit to suit a ute diff. Can I buy them new or what other models have h165? Do 120y borgwarner u-bolts fit? Or does anyone have any they could sell?
Cheers
Please dont say go search. Simple questions only require simple answers.
Thanks
Posted on: 2005/4/19 12:15
Re: Where to find U-bolts and the plates to suit ute diff?
From Sydney, Australia
Not enough info to answer your questions.
Do you need bottom plates for a 1200 sedan, wagon or coupe?
I think you'll have to make the bottom plates yourself, if it's going into a sedan.
If the diff didn't come with the hand brake mechanism, so mods will be required to fit the sedan one. Requires a square plate with 4 holes in it to offset the centre mount for the handbrake cables.
Posted on: 2005/4/19 12:25
Most spare parts places stock U bolts, same goes for trailer shops but depending if you run lowering blocks - the U bolts at the trailer shop might be too short.
Posted on: 2005/4/19 14:28
From Perth Western Australia
i think i got some in the back yard...
stock from and 85 ute... would that be allright?
Posted on: 2005/4/19 15:58
From Central Vic
Alot of datsun wagons retained leaf springs when looking for u bolts try a series one bluebird wagon MAYBE
Posted on: 2005/4/20 4:19
i got a set.
Posted on: 2005/4/20 4:49
78 model datsun 1200 ute. A15 twin webbers, dogleg 5speed.
Jk Rubicon unlimited, 58 CJ3B Willys
Im chasing the U-bolts and bottom plates and the little top bit that the u-bolts sit on so that I can bolt the ute diff into the sedan.
If I do not find any I might have to take them off your hands.
Posted on: 2005/4/20 7:40
pay for postage and there urs. i gotta pull em off another ute i got at my mates place tho,
Posted on: 2005/4/20 10:21
From Brisbane Australia
Hi Danial,Head straight to Kelly's wrecking on beams rd, I think you know the place, and grab all the hardware that secures the diff to the springs but you will also need to weld the shock mounts from a sedan diff to the ute diff,I have done it to my ute diff so if you want to see how it go's drop me a line
cheers Ade
Posted on: 2005/4/20 11:17
