(1) 2 3 4 5 »
What's this part?
From Brisbane
I am trying to get confirmation on what this part is (apart from broken!)? I think it is the temperature sensor for the temp gauge but not 100% sure. My gauge is still working but the car appears to be running cooler
I have a feeling it was damaged when I had the extractors put on.
Are new ones readily available?
Posted on: 2005/7/27 9:08
Re: What's this part?
From Bay of Plenty
do you have an electric fan if so it must be that & must be why it is running cooler fan will be on all of the time
Posted on: 2005/7/27 10:48
From penrith,sydney,aus
look like its the water temp sender
how much cooler is it running is it like not moving of the bottom at all
Posted on: 2005/7/27 10:51
From Stone Age somewhere in U.S.A.
it,s a coolant temp. sensor for emission controlls. you can probably live without it.
Posted on: 2005/7/27 10:54
it is possable, like someone else mentioned, that it's for an electric fan, but I doubt it unless it's a front wheel drive car.
Posted on: 2005/7/27 10:56
From Warwick, QLD
I think it's a knock sensor, but hey thats just my guess
Damo
Posted on: 2005/7/27 11:14
Drive It Like You Stole It
Every Car Has 500hp In The Wet
Team NEW SKOOL
From sydney australia
no,it's a temp sensor for emissions,like rgrinder
said.as most people(ok,me) remove this emissions crap,it's not needed.so,this makes the outlet a good place to put the temp sender for an aftermarket water temp guage.vdo has an adaptor with the same outside thread as this
hole,& the same thread as aftermarket senders.
or the water temp sensor for an injection setup.
Posted on: 2005/7/27 11:41
From Brisbane Australia
My guess is a sensor for the auto choke, it is not the sensor for the guage as it sits on the right hand side
Ade
Posted on: 2005/7/27 13:08
From Brisbane
Well thanks for all the replies
I can tell you that it is not for the auto choke, I still have a manual one.
It's not for an electric fan, don't have one of those either
The motor is as it came out of the factory so it must be an emissions/temp sensor like has been suggested.
The car was running at about half the temp it normally sits on so one could think only one wire is broken so maybe it reads low but on the way to work today it was back up to normal temp so it may have just been the cool night air that was affecting it but I have never noticed before.
I always tend to watch the gauges very closely after I have had work done on the car!!
Posted on: 2005/7/28 1:38
From Central Vic
if your temp runs low on a cold night probably best to fit a new termostate
just to be sure
Posted on: 2005/7/28 2:47
(1) 2 3 4 5 »
