« 1 (2)
Re: E15 Dizzy to A12 Conversion
From durban, south africa
why noy use your dizzy with the vw hall sensor???
much easier!!!
Posted on: 2005/12/29 5:53
VW chassis
fibreglass body
A-14
280 cam
ported head shaved 1.5mm
extractors with 2inch s/s pipe
webber 38 dgas.
to come........
Dellorto 36 drla
turbo
and then maybe some gas
From Brisbane
I just saw this pic
it looks like the stock E15 plate has been cut and the stock A12 plate on the bottom
so it cant be done without cutting/grinding
Posted on: 2006/1/2 2:22
Oh I guess your right.
All those others out there uncut must be fakes
I just saw this pic,
looks like Bart Simpson using an axe on a 120y
So you can't change back rims on a 120y without cutting.
I give up. I dont know why I even bother trying to help.
Posted on: 2006/1/2 3:19
From Adelaide, Australia
so can someone explain in great detail how to modify a E15 Dizzy fo ran A series?
is it easy?
im very interested
Posted on: 2006/1/3 6:23
I hear you need a grinder, an axe and a bannana.
Posted on: 2006/1/3 6:34
From Geelong, Vic
Phunk you r a funny one
Posted on: 2006/1/3 6:47
From Launceston,Tasmania,Aus
Go and have a look in my member photo's..
I have done it and took pics all the way through, most pics an explanation of what is going on...
Posted on: 2006/1/4 3:25
Proud member of " The Tasmanian Datsun Owners Group"......
From Bunbury Western Australia
could you do away with the existing bracket and make your own like mineOpen in new window
Posted on: 2006/1/4 5:32
Two things that drive me nuts.....a dry road under a grey sky and a wet road under a blue sky, because no matter what, it's either too soon or too late to drive the way I want
« 1 (2)
