Console
From Datsun 1200 Club
Categories: Interior | Fibreglass
Datsun 1200s were fitted with various consoles including full-size and compact style.
Short Console
0706654A30140606W00210.jpg 13667.jpgAlbum 13667
The short pocket-type console was fitted to:
* Automatic DX
* OPTION 4-speed 1200s STD and DX
* JAPAN 3-speed column shift OPTION
* B120 Pickups as standard equipment (except STD models)
COLORS
1970-1978 Black
1978-1989 Brown
1989-1995 Gray
1970-1978 (Black)
10456.jpgAlbum 10456 21470.jpgAlbum 21470
1978-1989 (Brown)
16664.jpgAlbum 16664 16086.jpgAlbum 16086
1989-1995 (Gray)
16654.jpgAlbum 16654 21468.jpgAlbum 21468
21471.jpgAlbum 21471 21472.jpgAlbum 21472
13637_4fdaeedc05110.jpgUpload click to view 13637_4fdaeef661400.jpgUpload click to view
Brackets
Screws
23576.jpgAlbum 23576 23577.jpgAlbum 23577
Brackets (B122 pictured)
74987-H1801 BRACKET-CONSOLE FRONT [long bracket]
74988-G1161 BRACKET-CONSOLE [rear, short bracket]
01241-00061 NUT (4)
08510-61697 SCREW (holding console to bracket)
08510-61642 SCREW (holding bracket to floor)
21469.jpgAlbum 21469 25957.jpgAlbum 25957 scc.jpg scd.jpg sc1.jpg sc2.jpg sc3.jpg
Automatic
13667.jpgAlbum 13667 20399.jpgAlbum 20399
Floor Trim Part Numbers
Sunny 1200 Optional Parts catalog
* G4980-H1025 ASS'Y-CONSOLE BOX [short, OPTION for 3-speed (column shift)]
Japan CONSOLE BOX
* 74980-H1801 ASS'Y-CONSOLE BOX, 小型 (small type) with bracket 4-speed (ex. GL, GX)
* 74980-H1021 ASS'Y-CONSOLE BOX, 小型 (small type) with bracket A-all (ex. GL)
North America
* 74980-H1921 ASSY-BOX CONSOL SEDAN,COUPE AUTOMATIC
* 74980-H1801 ASSY-BOX CONSOL SEDAN,COUPE MANUAL OPTION
* 74980-H7000 ASSY-BOX CONSOL SEDAN,COUPE MANUAL OPTION 0772- [Fire-resistant?]
B120
* 74980-H1801 CONSOLE BOX KIT-FLOOR W/BRACKET     -7803 [Black]
* 74980-G1160 CONSOLE BOX KIT-FLOOR W/BRACKET 7804-7907 DARK BROWN
* 74980-G1660 CONSOLE BOX KIT-FLOOR W/BRACKET 7908-8109 BROWN
* 74980-G1900 CONSOLE BOX KIT-FLOOR W/BRACKET 8110-8910 [revised finisher panel]
* 96910-95W00 CONSOLE BOX KIT-FLOOR W/BRACKET 8910- GRAY
Full Size
Full size console came with a blank plate. GX models were fitted with a Clock. The Tachometer was rightly fitted into the dashboard, but you can put the tachometer in the console if you so choose.
5703.jpgAlbum 5703 21473.jpgAlbum 21473
Painted brown to match 1979-1988 interior
30666.jpgAlbum 30666 30667.jpgAlbum 30667 30665.jpgAlbum 30665
This same full-size console was used on JDM GL/GX automatic models
12526_4fe135ad71545.jpgUpload click to view
Heater vents still work even with the console in place
26272.jpgAlbum 26272
Foam block on underside
21477.jpgAlbum 21477 30668.jpgAlbum 30668
w/o heater
592.jpgAlbum 592
Datsun 1200 SSS
6595.jpgAlbum 6595
1970-1971 appears to be gold tinted, while 1972 seems to be silver-tinted. But the GL brochure shows what looks like a black tinted console. The catalogs show only two numbers: early and 1972.
GL | GX facelift
gsi.jpg 460.jpgAlbum 460
25955.jpgAlbum 25955 lc1.jpg 25969.jpgAlbum 25969 25971.jpgAlbum 25971
lc2.jpg lc3.jpg lc4.jpg lc5.jpg lc6.jpg lc7.jpg lc8.jpg lc9.jpg lca.jpg lcb.jpg lcc.jpg
25970.jpgAlbum 25970
Brackets
14949.jpgAlbum 14949 21478.jpgAlbum 21478 30668.jpgAlbum 30668
Bracket tabs are hot air deflectors
4939.jpgAlbum 4939 5619.jpgAlbum 5619 9471.jpgAlbum 9471 19640.jpgAlbum 19640 21466.jpgAlbum 21466 21467.jpgAlbum 21467
Consoles assemblies come with Clock mask, Clock is sold separately.
* 74980-H2010 ASS'Y-CONSOLE BOX (大型 large type) GL/GX manual
* 74980-H2020 ASS'Y-CONSOLE BOX (大型 large type) GL automatic
Japan catalog
1972 Japan [Facelift] catalog
* 74980-H3320 CONSOLE BOX ASS'Y-with bracket GL/GX 4-speed
* 74980-H3330 CONSOLE BOX ASS'Y-with bracket GL automatic
USA Catalog
* 74980-H1801 ASSY-BOX CONSOLE MANUAL -0772
* 74980-H2010 ASSY-BOX CONSOLE COUPE MANUAL 0772-
* 74980-H7000, 74980-H7001 ASSY-BOX CONSOLE MANUAL 0772-
Mask
Console mask starts with the same plastic piece as the dash mask, and then rivits it to a complex aluminum adapter.
'Sunny'
74990-H2021 MASK-clock [console]
23452.jpgAlbum 23452
'Datsun'
74990-H1800 MASK-CLOCK [console]
25956.jpgAlbum 25956
Compare to simpler Dash blank (which is the same plastic piece)
23442.jpgAlbum 23442
The console mask has an aluminum adapter bracket to allow it to bolt to the three console holes.
Clock Fitting
Just unbolt the mask plate, and bolt in the Clock. The same clock fitted in the round Coupe/Sedan dash is used in the console.
console_bolts.jpg 21465.jpgAlbum 21465
The second set of tabs - back from the face - are used to bolt into the console
If the side-brackets are missing — e.g. a 1978-up Truck clock — you may fabricate a simple bracket to hold the clock in place.
9665_4eccbc0890067.jpgPost 389578 13419_4e3cb7b51e504.jpgPost 389578
8 27389-H2300 SPACER-rubber (fixing clock to console box)
25962.jpgAlbum 25962 28518.jpgAlbum 28518
If you buy a second-hand clock and end up with the Facelift clock, cut the long bracket off to make it fit in the console:
23447.jpgAlbum 23447
24043-H2000 ASS'Y-CABLE, for console clock GX [extension harness for clock wiring]
Tachometer Fitting
The factory tachometer was not designed to bolt to the console. But is will fit if you make a bracket to hold it in place. Plumber's Strap Tape might even work.
13419_4e3cb7b51e504.jpgPost 389578 9665_4eccbc0890067.jpgPost click for topic
Fibreglas
Glassfibre versions
7955.jpgAlbum 7955 7956.jpgAlbum 7956 14774.jpgAlbum 14774 14775.jpgAlbum 14775 14776.jpgAlbum 14776 14777.jpgAlbum 14777 16616.jpgAlbum 16616
Portugal
838.jpgAlbum 838 1350.jpgAlbum 1350 834.jpgAlbum 834 4748.jpgAlbum 4748 4823.jpgAlbum 4823
Shifter Boot
シフト ブーツ Boot for shift lever. Full and short consoles use the same boot.
Aftermarket | Nissan
Buy from Bprojects
BOOT
74986-H1801 ASSY-BOOT MANUAL [Black] -7803
74986-H7000 ASSY-BOOT MANUAL 0772- USA [Black Fireproof?]
74896-G1160 7804-7907 [Dark Brown]
74896-G1660 7908-8910 [Brown]
96935-95W00 8910- [Gray]
Finisher
08961-13240 NUT (4) (holding finisher to console)
74982-H1021 FINISHER-CONSOL BOX AUTOMATIC
74982-H1801 FINISHER-CONSOL BOX MANUAL -8109
74982-G1900 PANEL-CONSOLE A 8110-8910
96930-95W00 PANEL-CONSOLE A 8910-
Aftermarket
Amco aftermarket/dealer installed
7450.jpgAlbum 7450 689.jpgAlbum 689
Westel docking-type 70 Console Custom (click for more photos)
174_5a19d27b9b097.jpgPost 486799 174_5a19d292ef7d4.jpgPost 486799
Long style
14598.jpgAlbum 14598
customized?
174_564aac18729eb.jpgPost 473777
EC 4420N (was spotted on eBay out of Austria)
Custom
aftermarket gauges fitted
3069.jpgAlbum 3069
3189.jpgAlbum 3189 16671.jpgAlbum 16671 16672.jpgAlbum 16672
Português 1200s. Eles são consoles personalizados? Ou o equipamento padrão Entreposto
Portugal 1200s. Are they custom consoles? Or the standard Entreposto equipment?
804.jpgAlbum 804 1451.jpgAlbum 1451
Documentation
JDM
1555.jpgAlbum 1555 18381.jpgAlbum 18381
USA OPTION Options
Alternative Sources
For CA18DET shifter position: Hyundai Getz modified
25502.jpgAlbum 25502
Honda Civic
30669.jpgAlbum 30669 30670.jpgAlbum 30670
Holden Barina (two types)
2970.jpgAlbum 2970 6025.jpgAlbum 6025
Volkswagen Golf CTi
14789.jpgAlbum 14789
PB110
Sunny Excellent used consoles the similar to B110, but extend up further with vents that drop down in the top. Also extends further back under the handbrake lever.
B210 Console
NOTE: Does not fit the 1200 well
Short Type | Long Type
B310 Console
センターコンソール center console
コンソール ボックス CONSOLE BOX
Retrieved from "http://datsun1200.com/modules/mediawiki/index.php?title=Console"
This page has been accessed 91,891 times. This page was last modified 20:48, 26 September 2025. Content is available under Datsun 1200 Club.
