Ball Joint Comparison
Revision as of 22:57, 23 August 2011; view current revision
Category: Front Axle And Front Suspension
40160 is the part number for Ball Joint. Here is a comparo of selected Datsun ball joints.
H10
B110/early Truck/early B210 Style
M8 bolts
40160-H5000
40160-H1001 (formerly 40160-H1000)
  • B110 1970-1973
  • B210 1973-1975 except H & P models (HB210 or PB210)
  • B120 1971-September 1975
Aftermarket
  • Raybestos 5051044
  • AC/Delco 45D2044 (88911542)
H10
H74
Late B210/Late Truck Style
40160-H7400 - M10 bolts
This is the same length as B110, but the bolt pattern is a wee bit different. They fit on a revised LCA which are identical to B110 but for the ball joint bolt pattern.
  • B210 1976-1977 except L16 model
  • VB210 from October 1975
  • B211 1975-1977
  • LB210 1975-1977 except europe & USA
  • B310 1977-1981 (120Y) with A12 engine
  • LB310 1978-1982 with A12A engine - Canada
  • B120 Truck October 1975-1994
Aftermarket
  • Moog NIBJ10016
H10 vs H74
Because of the changed patterns, H74 requires notched Tension Rods with bolt holes drilled farther apart
Fasteners: M8 vs M10, so the LCA bolt holes are larger
Type H10
08911-60810 NUT (6) [M8]
* 08911 = Hex Nut
* 6 = high, medium carbon steel
* 08 = M8
* 1 = Zinc cadmium coated
08915-13810 WASHER-lock (8)
* 08915 = Washer
* 1 = Spring lock medium
* 38 = 8 + 30 = M8
Type H74
08911-64010 NUT (M10 X 1.25)
* 08911 = Hex Nut
* 40 = 10 + 30 = M10
08915-14010 WASHER (M10)
* 08915 = Washer
A10/B310 Style
40160-W5001 (formerly 40161-W5000)
This longer ball joint fits on the revised 1976-up LCA.
  • S110 1979-1981 with Z18S, Z18E
  • A10/A11 1977-1981
  • HB310/PB310 1977-1982 (some A14/A15 engine + all USA models)
Aftermarket
McQuay-Norris FA1265
TRW 10341
Moog K9073
Mevotech MK9073
Beck/Arnley 1013234
Raybestos 5051061
AC/Delco 45D2061 (88911559)
H74 vs W50
LCA with knuckle arm bolted to the Ball Joint
510/610/710 Style
40160-A8625 (formerly A8610, A8600, U7000)
  • 510/610 1968-1976 except G610
  • S10/S11 1975-1979
  • 710/711 1973-1977
  • PB110 1970-1973
  • PB210/GB210 1973-1977
  • HB210 USA & CANADA
  • GB211 (L16) 1975-1977
  • LB210 1975-1977 Europe
280ZX/810 Style
40160-S0128 (formerly -SO127,126,125,106,105,104,P6525)
  • S130 (280ZX) 1978-1983
  • C130/C131/C230/C231 (Laurel) 1972-1980
  • Skyline C110/C111/C210/C211 1972-1980
  • 810 (Bluebird) 1976-1979
  • 910 (Bluebird) 1979-1983 Z18P only
910 Style
40160-W2210 (formerly W2200, W1001,W1000)
  • F30 (Leopard) 1980-1986
  • 910 (Bluebird) 1979-1983 except Z18P
  • S12 (Silvia/Gazelle) 1983-1988
R31 Style
40160-41L00 (formerly 40160-67L00)
  • F31 (Leopard) 1986-
  • C32 (Laurel) 1984-
  • R31 (Skyline) 1985-
