Body
Revision as of 06:33, 25 November 2011; view current revision
Category: Body
The Datsun 1200 had a wikipedia:Unibody design made out of high-strength steel.
Also See
Also See:
and
Bonnet (Hood)
The bonnet (hood) of the Datsun 1200 is a classic design: an elegant flat sheet with a strengthening ridge down the middle. You can use the ridge to aim it down the autobahn.
See main article: Hood
Guards (Fenders)
See Fenders
Doors
See main article: Doors
Front Panels
Radiator Core Panels
  • 62522-H1001 STAY-HOOD CATCH
  • 62524-H1000 PLATE-closing rod (optional)
    Also listed as COVER ASSY-COOLING HOLE Truck -7803
    • 62524-51012 SCREW (4)
Coupe
  • 62500-H1800 ASSY-SUPPORT RADIATOR CORE
  • 62510-H1800 RAIL-SUPPORT RADIATOR CORE UPPER
  • 62610-H1800 ASSY-PANEL APRON FRONT
Sedan
including 1972 facelift Sedan, Van, and Truck -7803)
  • 62500-H1000 ASS'Y-SUPPORT, radiator core
  • 62512-H1000 RAIL-support, radiator core, upper
  • 62522-H1001 STAY-hood catch
  • 77720-89908 SCREW (4)
  • 63140-78500 NUT(4)
  • 62612-H1000 PANEL-APRON,FRONT
Front Fender Panel
See Front Fender and Front End
Hood Ledge & Hood Panel
See Hood
Firewall
These parts make up the Firewall and water box:
  • Cowel Top
  • Dash-Upper
  • Dash-Lower
  • Dash-Side
View from engine compartment:
View from inside cabin:
The water box is also known as the ventilation plenum. It is where air enters the cabin. The large oval hole in the center is for the heater (or ventilator). The cowl vents are located at the base of the windshield due to aerodynamic reasons.
Normally, rainwater goes in through the top through the Cowl vents and falls onto the topside of the Upper Dash panel. From there it runs out a vent hole on the outside of the panel near the guards (fenders).
Lower Dash panel:
In this photo, the Reinforcement has been removed, and you can see how the hoodledge joins with the firewall and radiator panel to form the engine compartment:
Repairing Water Box
Water comes in though the vents behind the bonnet, then runs down to a hole that is there to let it out. If this is rusted, it will instead leak down onto the fenders.
See Water Box Rust
  • 66301-H1000 PANEL-cowl top JAPAN
  • 66301-H1600 PANEL-COWL TOP USA
  • 66810-H1001 PLATE-BAFFLE COWL TOP RH
  • 66811-H1001 PLATE-BAFFLE COWL TOP LH
  • 24426-H1001 ASS'Y-BRACKET, battery
  • 24427-H1001 STAY-BATTERY BRACKET
    • 24427-H1000 STAY-BATTERY BRACKET
    • 77720-89910 BOLT-SPECIAL
Dash Panel
Also see Tunnel which is built of Lower Dash + Front Floor
RHD
  • 67300-H1000 ASS'Y-PANEL, dash, lower
  • 67300-H1021 ASS'Y-PANEL, dash, lower Automatic
    • 74306-H1020 ASS'Y-PANEL, A/T floor cover, front
  • 46570-H1001 ASS'Y-BRACKET, pedal & steering post
    • 81-10620-62 BOLT-with lock washer (fixing reinforcing & stay) (8)
  • 46575-H1001 BRACKET-clutch cable
  • 46582-H1000 PACKING-clutch cable bracket
    • 83-10614-62 SCREW (3)
    • 89-15436-1 WASHER-plain (3)
LHD
  • 67300-H1600 ASSY-PANEL DASH LOWER
  • 67300-H1601 ASSY-PANEL DASH LOWER
  • 67300-H1922 ASSY-PANEL DASH LOWER
  • 67300-H1921 ASSY-PANEL DASH LOWER
  • 46570-H1600 ASSY-BRACKET PEDAL & STEERING POS
Roof Panel
Body Outside Fitting
Roof Drip Moulding
Rain gutters for USA & JAPAN are the same.
  • The rear piece differs 2dr, 4dr, Van
  • Truck doesn't have a rear piece
  • Coupe front & rear pieces are unique
Coupe
73800-H1800 SET-MOULDING ROOF DRIP RH
 73810-H1800 MOULDING-ROOF DRIP FRONT RH
 73812-H1800 MOULDING-ROOF DRIP REAR RH
73801-H1800 SET-MOULDING ROOF DRIP LH
 73811-H1800 MOULDING-ROOF DRIP FRONT LH
 73813-H1800 MOULDING-ROOF DRIP REAR LH
73800-H1801 SET-MOULDING ROOF DRIP RH (from '70-May)
 73810-H1801 MOULDING-ROOF DRIP FRONT RH
 73812-H1801 MOULDING-ROOF DRIP REAR RH
73801-H1801 SET-MOULDING ROOF DRIP LH (from '70-May)
 73811-H1801 MOULDING-ROOF DRIP FRONT LH
 73813-H1801 MOULDING-ROOF DRIP REAR LH
73815-H1100 CLIP-MOULDING ROOF DRIP [center clip]
Sedan & Van
STD models had no drip rails.
73800-H1100 SET-MOULDING-drip roof 4S
73800-H1300 SET-MOULDING ROOF DRIP 2S
73800-H1300 SET-MOULDING ROOF DRIP V-DX,VP
Sets include
 73810-H1100 MOULDING-ROOF DRIP FRONT RH
 73811-H1100 MOULDING-ROOF DRIP FRONT LH
 2-dr
  73812-H1300 MOULDING-ROOF DRIP REAR RH
  73813-H1300 MOULDING-ROOF DRIP REAR LH
 4-dr
  73812-H1100 MOULDING-drip roof, rear (R.H.)
  73813-H1100 MOULDING-drip roof, rear (L.H.)
 Van
  73812-H1500 MOULDING-drip roof, rear (R.H.)
  73813-H1500 MOULDING-drip roof, rear (L.H.)
Truck
73810
73812-G1000 MOULDING-ROOF DRIP, FRONT RH
73811
73813-G1000 MOULDING-ROOF DRIP, FRONT LH
Rear Panels
Rear Panel
Sometimes called a beaver panel, however the 1200 rear panel is one piece:
  • 79100-H1000 ASS'Y PANEL-rear Sedan
  • 79100-H1800 ASS'Y PANEL-rear Coupe
  • 79100-H1400 ASS'Y PANEL-rear Van
Ute
Back Panel
  • 79110-G1001 PANEL-REAR, LOWER
Rear Gate Panel
See Tailgate
Rear Floor Panel
The rear floor is the bottom of the tray (cargo well). The supporting structure (side members and cross members) are also part of the floor.
Rear Floor Panel サニトラ リア フロア  パネル
  • 79100-G1000 PANEL ASSY-BACK -7803
    • 79106-G1401 PANEL-BACK, LOWER -7803
  • 79100-G1060 PANEL ASSY-BACK 7804-
    • 79106-G1660 PANEL-BACK, LOWER 7804-8105
    • 79106-G1902 PANEL-BACK, LOWER 8106-8111 SB
    • 79106-G1903 PANEL-BACK, LOWER 8106-8111 LB
    • 79106-G1904 PANEL-BACK, LOWER 8112- SB
    • 79106-G1905 PANEL-BACK, LOWER 8112- LB
  • 74502-G1001 PANEL-floor, rear SB
  • 74502-G1400 PANEL-floor, rear LB
  • 16 74502-G1001 PANEL-floor, rear
  • 17 74540-G1000 COVER ASS'Y-floor hole (up to '71-3)
  • 17 74540-G1001 COVER ASS'Y-floor hole (from '71-4)
  • 18 74546-G1001 ANGLE-floor hole (up to '71-3) (2)
  • 18 74546-G1002 ANGLE-floor hole (from '71-4) (2)
  • 19 24200-89920 CLIP (2)
  • 20 74850-G1001 MEMBER ASS'Y-rear side (R.H.)
  • 20 74851-G1000 MEMBER ASS'Y-rear side (L.H.)
  • 21 55202-G1000 BRACKET ASS'Y-rear spring, front (R.H.)
  • 21 55203-G1000 BRACKET ASS'Y-rear spring, front (L.H.)
  • 22 55242-G1000 STOPPER ASS'Y-bumper rear (R.H.)
  • 22 55243-G1000 STOPPER ASS'Y-bumper rear (L.H.)
  • 23 55208-G1000 BRACKET ASS'Y-shackle (2)
  • 24 20633-G1001 BRACKET-muffler mounting (2)
  • 25 [not used for Short Bed]
  • 26 74860-G1002 MEMBER ASS'Y-cross #1, replaced 74860-G1001
  • 27 17241-G1000 BRACKET ASS'Y-fuel tank mounting
  • 28 74870-G1000 MEMBER ASS'Y-cross #2
  • 29 74870-G1002 MEMBER ASS'Y-cross #3, replaced 74870-G1001
  • 30 74890-G1001 MEMBER ASS'Y-rear end
  • 31 96206-G1000 BRACKET ASS'Y-license plate
  • 31 96206-G1001 BRACKET ASS'Y-license plate
  • 32 79110-G1001 PANEL ASS'Y-rear, replaced 79110-G1000
Long Body - parts above except:
  • 16 74502-G1400 PANEL-floor, rear LB
  • 17LB 74345-G1401 BRACKET ASS'Y-center bearing, upper
  • 20 74850-G1400 MEMBER ASS'Y-rear side (R.H.)
  • 20 74851-G1400 MEMBER ASS'Y-rear side (L.H.)
  • 21 55202-G1400 BRACKET ASS'Y-rear spring, front (R.H.)
  • 21 55203-G1400 BRACKET ASS'Y-rear spring, front (L.H.)
  • 23 55208-G1400 BRACKET ASS'Y-shackle (R.H.)
  • 23 55209-G1400 BRACKET ASS'Y-shackle (L.H.)
  • 25 74860-G1401 MEMBER ASS'Y-cross #1
  • 26 74867-G1400 MEMBER ASS'Y-cross #2
  • 27 17241-G1400 BRACKET ASS'Y-fuel tank mounting bar
  • 28 74870-G1000 MEMBER ASS'Y-cross #3
  • 29 74880-G1400 MEMBER ASS'Y-cross #4
  • 30 74890-G1400 MEMBER ASS'Y-rear end
Rear Side Panels
Ute Rear Side
  • Long Body has 5 hooks per side
  • Short Body has 4 hooks per side
  • Red parts differ Long Body versus Short Body
76304-G1025 PANEL ASS'Y-body side outer (R.H.)
76305-G1025 PANEL ASS'Y-body side outer (L.H.)
1 76306-G1050 PANEL ASS'Y-body side outer rear (R.H.) with gas filler lid
2 76307-G1050 PANEL ASS'Y-body side outer rear (L.H.)
3 76310-G1050 PANEL ASS'Y-body side outer rear end (R.H.)
3 76311-G1050 PANEL ASS'Y-body side outer rear end (L.H.)
4 90510-G1000 HOOK ASS'Y-rear gate (R.H.)
4 90511-G1000 HOOK ASS'Y-rear gate (L.H.)
5 75310-G1000 REINFORCEMENT ASS'Y-anchorage upper (R.H.)
5 75311-G1000 REINFORCEMENT ASS'Y-anchorage upper (L.H.)
6 76500-G1000 PILLAR ASS'Y-center (R.H.)
6 76501-G1000 PILLAR ASS'Y-center (L.H.)
7 76308-G1050 PANEL ASS'Y-body side outer upper (R.H.)
  * superceded 76308 G1000
8 76309-G1050 PANEL ASS'Y-body side outer upper (L.H.)
  * superceded 76309-G1000
9 76320-G1027 PANEL ASS'Y-body side inner rear (R.H.)
10 76321-G1026 PANEL ASS'Y-body side inner rear (L.H.)
   * superceded 76321 G1025 superceded 76320-G1026
   ** replaced 76320-G1025
11 93332-G1000 HOOK-rope (8)
12 79200-G1000 PANEL ASS'Y-back inside (R.H.)
12 79201-G1000 PANEL ASS'Y-back inside (L.H.)
13 76907-G1000 COVER-body side (R.H.) [3-bar]
13 76908-G1000 COVER-body side (L.H.) [3-bar]
* 14 96706-G1000 GROMMET-screw (12 per side)
* 15 08530-51612 SCREW (12 per side)
Long Body - same as above except:
76304-G1425 PANEL ASS'Y-body side outer (R.H.) LB
76305-G1425 PANEL ASS'Y-body side outer (L.H.) LB
1 76306-G1450 PANEL ASS'Y-body side outer rear (R.H.)
  * includes gas filler lid
2 76307-G1400 PANEL ASS'Y-body side outer rear (L.H.)
9 76320-G1425 PANEL ASS'Y-body side inner rear (R.H.)
10 76321-G1425 PANEL ASS'Y-body side inner rear (L.H.)
11 93332-G1000 HOOK-rope (10)
13 76907-G1400 COVER-body side (R.H.) [4-bar]
13 76908-G1400 COVER-body side (L.H.) [4-bar]
Rear Quarters
3330.jpg 6240.jpg 6241.jpg 9197.jpg 10879.jpg 11082.jpg 11618.jpg 11619.jpg 11621.jpg 11735.jpg 14180.jpg 14468.jpg 14820.jpg 15017.jpg 15602.jpg 15733.jpg
Floor Trim
Floor Side Cover - Front SEDAN & COUPE
  • 74921-H1100 COVER-FLOOR SIDE FRONT RH NLA
  • 74921-H7000 COVER-FLOOR SIDE FRONT RH (BLUE,LG-211 0772-
  • 74921-H7001 COVER-FLOOR SIDE FRONT RH (BEIGE,LG-20 0173-
  • 74921-H7002 COVER-FLOOR SIDE FRONT RH (BLACK,LG-13 0173- NLA
  • 74922-H1100 COVER-FLOOR SIDE FRONT LH NLA
  • 74922-H7000 COVER-FLOOR SIDE FRONT RH (BLUE,LG-211 0772-
  • 74922-H7001 COVER-FLOOR SIDE FRONT LH (BEIGE,LG-20 0173-
  • 74922-H7002 COVER-FLOOR SIDE FRONT LH (BLACK,LG-13 0173- NLA
Floor Side Cover - Rear SEDAN
  • 74925-H1300 COVER-FLOOR SIDE REAR RH NLA
  • 74925-H7000 COVER-FLOOR SIDE REAR RH (BLUE,LB-211 0772-
  • 74925-H7002 COVER-FLOOR SIDE REAR RH (BLACK,LG136 NLA 0173-
  • 74926-H7002 COVER-FLOOR SIDE REAR LH (BLACK,LG136 NLA 0173-
  • 74926-H1300 COVER-FLOOR SIDE REAR LH
  • 74926-H7000 COVER-FLOOR SIDE REAR LH (BLUE,LB-211
  • 74926-H7001 COVER-FLOOR SIDE REAR LH (BEIGE,LH-20
  • 74926-H7002 COVER-FLOOR SIDE REAR LH (BLACK,LG-13
Floor Side Cover - Rear COUPE
  • 74925-H1800 COVER-FLOOR SIDE REAR RH COUPE
  • 74925-H7100 COVER-FLOOR SIDE REAR RH (BLUE,LB-211 0772-
  • 74925-H7101 COVER-FLOOR SIDE REAR RH (BEIGE,LH-20 0173-
  • 74925-H7102 COVER-FLOOR SIDE REAR RH (BLACK,LG-13 0173-
  • 74926-H1800 COVER-FLOOR SIDE REAR LH
  • 74926-H7102 COVER-FLOOR SIDE REAR LH (BLACK,LG-13
  • 74926-H7101 COVER-FLOOR SIDE REAR LH (BEIGE,LH-20
  • 74926-H7100 COVER-FLOOR SIDE REAR LH (BLUE,LB-211
Wheel House Trim - SEDAN
74915-H1000 COVER-REAR WHEEL HOUSE BLACK#1742 (2) SEDAN
74915-H1001 COVER-REAR WHEEL HOUSE YELLOW (2) SEDAN(DX) 1270-
74915-H7000 COVER-REAR WHEEL HOUSE (BLUE,LB-211 (2) SEDAN 0772-
74915-H7001 COVER-REAR WHEEL HOUSE (BEIGE,LH-20 (2) SEDAN 0772-
74915-H7002 COVER-REAR WHEEL HOUSE (BLACK,LG-13 (2) SEDAN 0173-
74917-18200 PAD-REAR WHEEL HOUSE (2)
Wheel House Trim - COUPE
74915-H1800 COVER-REAR WHEEL HOUSE RH
74915-H1801 COVER-REAR WHEEL HOUSE RH YELLOW COUPE 1270-
74915-H7100 COVER-REAR WHEEL HOUSE RH (BLUE,LB-211 COUPE 0772-
74915-H7101 COVER REAR WHEEL HOUSE RH (BEIGE,LH-20 COUPE 0772-
74915-H7102 COVER REAR WHEEL HOUSE RH (BLACK,LG-13 COUPE 0173-
74916-H1800 COVER-REAR WHEEL HOUSE LH
74916-H1801 COVER-REAR WHEEL HOUSE LH YELLOW 1270-
74916-H7101 COVER REAR WHEEL HOUSE LH (BEIGE,LH-20 0772-
74916-H7100 COVER-REAR WHEEL HOUSE LH (BLUE) 0772-
74916-H7102 COVER REAR WHEEL HOUSE LH (BLACK,LG-13 0173-
74917-H1800 PAD-REAR WHEEL HOUSE (2)
74917-H7000 PAD-REAR WHEEL HOUSE 0173- (2)
Scuff Plate
See Kicking Plate
Interior Trim
  • G9910-H7000 Shelf-parcel $63.67
  • 79911-H1000 Cover-parcel shelf
  • 73950-H1000 Sunvisor-gry $39.83
Front window - 2-dr sedan
  • 80260-H1000 Handle-vent R $19.67
  • 80261-H1000 Handle-vent L $19.67
Door
  • 80510-H1000 ESCUTCHEON-REMOTE CONTROL RH NLA
  • 80511-H1000 ESCUTCHEON-REMOTE CONTROL LH NLA
  • 80760-H1000 Handle-regulatr $24.00
Rear window - 2-dr sedan
  • 76828-H1200 Cover-hinge [rear window] $1.02 USD
  • 76870-H1200 Handle-window RR $39.17 USD
  • 76871-H1200 Handle-window RL $40.62 USD
    • 80234-H1000 WASHER-BRACKET PIVOT $5.83 USD
  • 76832-H1201 HINGE-SIDE WINDOW (4) NLA
Hinge Covers
Also consider B210 gray part:
  • 76828-H5300, 76828-H5301 COVER-SIDE WINDOW HINGE B210 [GRAY]
Sedan Trunk
  • 84820-H1000 HANDLE-TRUNK
  • 84810-H1001 Wthrstrip Trunk $53.73
Misc
  • 78130-H1000 Lid-gas Filler SEDAN $18.83
Aftermarket Suppliers
Most of these body panel manufacturers have a minimum sale of a full cargo container. So look for a local distributor.
  • CHUNG FU CHING - Taiwan
  • EDP - Seattle, WA USA
  • Auto Parts Industrial (API)
    http://www.autostone.com/contactus.asp
    We sell Auto Crash Parts to distributors on container base.
    • DT20-013-0 DATSUN 1200 -73 FRT APRON LOWER
    • DT20-015-0 DATSUN 1200 BONNET (Sedan / Ute)
    • DT20-016-1 DATSUN 1200 FR GUARD RH (Sedan / Ute)
    • DT20-016-2 DATSUN 1200 FR GUARD LH (Sedan / Ute)
    • DT20-077-0 DATSUN 1200 TAILGATE
