Hitachi Twin Carb Air Cleaners
Revision as of 05:41, 12 January 2013; view current revision
Category: Hitachi Twin Carb
With an Hitachi Twin Carb (GX-style) engine a RHD car there is clearance aplenty to fit air cleaners. But on a LHD car fitting an air cleaner it a bit tricky because the brake and clutch cylinders are on the left side. But the Twin Hitachis are easily fitted to LHD than a twin-Weber setup.
GX air cleaners are different from 510 SSS Twin Carb, and take a different filter element.
Red - A12GX
Blue - A12T
Air Horns
Stock utilizes air horns built into the air cleaner.
Air Horns, taken from air cleaner
Long horns
Custom Air Cleaner
Datsfullysik created this nice air cleaner from modern parts.
  • Valvoline VA61 air filter
  • TFI air filter adapter
  • bracket (could use plumbers strapping)
  • hose and clampes
12635.jpg 12636.jpg 12637.jpg 12682.jpg 12683.jpg 12684.jpg 12694.jpg 12695.jpg 12696.jpg
Cherry
NOTE: Twin round air cleaners come from the Nissan Cherry A12T engine.
Nissan Cherry as also fitted with twin-carb optional single air cleaner. Inside the housing fit two round filter elements. You can see two round sections on top and a slanted section giving it a kidney-bean shape.
For Datsun 1200 GX air cleaner, see GX Air Cleaner Part Numbers
619.jpg 960.jpg 1002.jpg 1003.jpg 1504.jpg 1512.jpg 1519.jpg 1973.jpg 2845.jpg 2846.jpg 2892.jpg 3384.jpg 3360.jpg 3682.jpg 5007.jpg 6727.jpg 7000.jpg 8125.jpg 8126.jpg 8355.jpg 8362.jpg 9257.jpg 9258.jpg 9589.jpg 9858.jpg 11789.jpg 13044.jpg 13363.jpg 13428.jpg 13882.jpg 13957.jpg 16059.jpg 16060.jpg 17046.jpg 18060.jpg
