The Datsun 1200 has a unibody design made out of high-strength steel. It does not use Body-on-Frame construction. The result is a lighter, stronger and stiffer chassis.
Front Panels
Core Support & Apron
Radiator Core Support & Front Apron (valence panel)
Note: The core support assembly includes the stay and rail, which were also sold seperarately.
62500-H1000 Stainless grille type (sedan/van/early-ute) 62500-H1800 Plastic grille type (coupe/mid-ute) 62500-95W00 Square headlight type (late-ute)
There is also a cooling hole cover assembly, which covers the aircon hole in the core support:
62524-H1000 PLATE-closing rod (optional) 62524-H1000 COVER ASSY-COOLING HOLE Truck F/COLD ZONE
Also see: Front Body Panels Part Numbers
Sedan
All Sedan & Van, including 1972 facelift. Also for early ute.
62500-H1000 ASS'Y-SUPPORT, radiator core NLA.(USA) * 62512-H1000 RAIL-support, radiator core, upper [62511] NLA.(USA) * 62522-H1001 STAY-hood catch [62515] NLA.(USA) 62612-H1000 PANEL-APRON,FRONT [62610] $112 USD
Coupe
Coupe and mid-model utes.
62500-H1800 ASSY-SUPPORT RADIATOR CORE NLA.(USA) * 62510-H1800 RAIL-SUPPORT RADIATOR CORE UPPER NLA.(USA) * 62522-H1001 STAY-hood catch 62610-H1800 ASSY-PANEL APRON FRONT $130 USD
Sunny Truck
Early (to March 1978) * Same as Sedan/Van Mid-model (April 1978 to October 1989) * same as Coupe Late-model (from October 1989) 62500-95W00 SUPPORT ASSY-RADIATOR CORE 8910- * 62510-G1265 SUPPORT-RADIATOR CORE, UPPER * 62522-H1001 STAY-HOOD LOCK 62610-H1800 ASSY-PANEL APRON FRONT except SB.DX 62612-H1000 ASSY-PANEL APRON FRONT LB + SB.DX
The core support rail stay is the same for all models:
62522-H1001 STAY-HOOD CATCH (all models) * sold separately but included with the Core Support assembly.
The other parts differ by the grille used. The core support has brackets for one of these:
Sedan Grille (core-mounted brackets) Plastic round-light grille (narrow spaced brackets) Plastic square-light grille (wide spaced brackets)
The core support rail has either wide or narrow plastic grille upper brackets ... or none at all for early sedan/van/ute.
The apron panel upper edge has plastic grille lower brackets ... or none at all for early sedan/van/ute.
The core support contains headlamp fittings for either sedan, coupe, or square-eye. Sedan/van and early utes Cores (H1000) have brackets to bolt on the grille.
Front Fender Panel
For fender/guard/wing, see main article: Front Fender and Front End
Hood Ledge & Hood Panel
See main articles: Hood (bonnet) Front Fender and Front End
Cowl Panels (Firewall & Dash)
- Cowel Top
- Dash-Upper
- Dash-Lower (see Dash Panel section below)
- Dash-Side
The steering post bracket bolt to the firewall.
See main article: Steering_Column#Steering_Post_Bracket
The water box is also known as the ventilation plenum. It is where air enters the cabin. The large oval hole in the center is for the heater (or ventilator). The cowl vents are located at the base of the windshield due to aerodynamic reasons.
Normally, rainwater goes in through the top through the Cowl vents and falls onto the topside of the Upper Dash panel. From there it runs out a vent hole on the outside of the panel near the guards (fenders).
In this photo, the Reinforcement has been removed, and you can see how the hoodledge joins with the firewall and radiator panel to form the engine compartment:
How the hoodledge (inner fender) ties in to the A-pillar:
Repairing Water Box
Water comes in though the vents behind the bonnet, then runs down to a hole that is there to let it out. If this is rusted, it will instead leak down onto the fenders.
See Water Box Rust
- 66301-H1000 PANEL-cowl top JAPAN
- 66301-H1600 PANEL-COWL TOP USA
- 66810-H1001 PLATE-BAFFLE COWL TOP RH
- 66811-H1001 PLATE-BAFFLE COWL TOP LH
- 24426-H1001 ASS'Y-BRACKET, battery
- 24427-H1001 STAY-BATTERY BRACKET
- 24427-H1000 STAY-BATTERY BRACKET
- 77720-89910 BOLT-SPECIAL
Dash Panels
Also see Tunnel which is built of Lower Dash + Front Floor
RHD
- 67300-H1000 ASS'Y-PANEL, dash, lower
- 67300-H1021 ASS'Y-PANEL, dash, lower Automatic
- 74306-H1020 ASS'Y-PANEL, A/T floor cover, front
- 46570-H1001 ASS'Y-BRACKET, pedal & steering post
- 81-10620-62 BOLT-with lock washer (fixing reinforcing & stay) (8)
- 46575-H1001 BRACKET-clutch cable
- 46582-H1000 PACKING-clutch cable bracket
- 83-10614-62 SCREW (3)
- 89-15436-1 WASHER-plain (3)
LHD
- 67300-H1600 ASSY-PANEL DASH LOWER
- 67300-H1601 ASSY-PANEL DASH LOWER
- 67300-H1922 ASSY-PANEL DASH LOWER
- 67300-H1921 ASSY-PANEL DASH LOWER
- 46570-H1600 ASSY-BRACKET PEDAL & STEERING POS
Roof Panel
See main article: Roof
Floor Panels
See main article: Floor
Side Panels
Door Panels
See main article: Doors
Rear Side Panels
See main article: Body Side Panels
* Dash side * Hood Ledge Reinforcement * Rear Wheel House * Roof Rail * Shock Bracket Panel * Sills * Quarter Panels (rear fender)* Tray Sides
* Pillars
Rear Panels
Also See: Trunk Lid
parts
119 76613-H1000 PANEL-rear pillar (L.H.) 4 door [HAS BEEN CUT]
Rear Panel
Sometimes called a beaver panel, however the 1200 rear panel is one piece:
- 79100-H1000 ASS'Y PANEL-rear Sedan
- 79100-H1800 ASS'Y PANEL-rear Coupe
- 79100-H1400 ASS'Y PANEL-rear Van
Ute
Back Panel
- 79110-G1001 PANEL-REAR, LOWER
Rear Floor
Rear Floor Panel
Also see: Truck Floor Part Numbers
The rear floor is the bottom of the tray (cargo well). The supporting structure (side members and cross members) are also part of the floor.
REAR FLOOR PANEL is the tray/bed bottom. All years the same.
74502-G1001 PANEL-floor, rear SB 74502-G1400 PANEL-floor, rear LB
33 BACK PANEL forms the rear of the cabin
Long Body is mostly the same as Short Body except it has one extra crossmember and of course longer side members and floor.
Rear Gate Panel
See Tailgate
Exterior Fitting
See main articles: Badges emblems, marks, IDs Colors Radiator Grille
Misc
- 78130-H1000 Lid-gas Filler SEDAN $18.83
Roof Drip Moulding
Rain gutters for USA & JAPAN are the same.
- The rear piece differs 2dr, 4dr, Van
- Truck doesn't have a rear piece
- Coupe front & rear pieces are unique
Coupe
73800-H1800 SET-MOULDING ROOF DRIP RH 73810-H1800 MOULDING-ROOF DRIP FRONT RH 73812-H1800 MOULDING-ROOF DRIP REAR RH 73801-H1800 SET-MOULDING ROOF DRIP LH 73811-H1800 MOULDING-ROOF DRIP FRONT LH 73813-H1800 MOULDING-ROOF DRIP REAR LH 73800-H1801 SET-MOULDING ROOF DRIP RH (from '70-May) 73810-H1801 MOULDING-ROOF DRIP FRONT RH 73812-H1801 MOULDING-ROOF DRIP REAR RH 73801-H1801 SET-MOULDING ROOF DRIP LH (from '70-May) 73811-H1801 MOULDING-ROOF DRIP FRONT LH 73813-H1801 MOULDING-ROOF DRIP REAR LH 73815-H1100 CLIP-MOULDING ROOF DRIP [center clip]
Sedan & Van
STD models had no drip rails.
73800-H1100 SET-MOULDING-drip roof 4S 73800-H1300 SET-MOULDING ROOF DRIP 2S 73800-H1300 SET-MOULDING ROOF DRIP V-DX,VP
Sets include 73815-H1100 CLIP-MOULDING ROOF DRIP [center clip] 73810-H1100 MOULDING-ROOF DRIP FRONT RH 73811-H1100 MOULDING-ROOF DRIP FRONT LH 2-dr 73812-H1300 MOULDING-ROOF DRIP REAR RH 73813-H1300 MOULDING-ROOF DRIP REAR LH 4-dr 73812-H1100 MOULDING-drip roof, rear (R.H.) 73813-H1100 MOULDING-drip roof, rear (L.H.) Van 73812-H1500 MOULDING-drip roof, rear (R.H.) 73813-H1500 MOULDING-drip roof, rear (L.H.)
Truck
73810 73812-G1000 MOULDING-ROOF DRIP, FRONT RH 73811 73813-G1000 MOULDING-ROOF DRIP, FRONT LH
Interior Fitting
See main article: Interior
Scuff Plate
See Kicking Plate
Aftermarket Suppliers
Most of these body panel manufacturers have a minimum sale of a full cargo container or 100 units. So look for a local distributor.
CHUNG FU CHING - Taiwan * DS057112AL Left Door (4-dr, van, truck)![]()
Auto Parts Industrial (API) http://www.autostone.com/contactus.asp * We sell Auto Crash Parts to distributors on container base. * DT20-013-0 DATSUN 1200 -73 FRT APRON LOWER * DT20-015-0 DATSUN 1200 BONNET (Sedan / Ute) * DT20-016-1 DATSUN 1200 FR GUARD RH (Sedan / Ute) * DT20-016-2 DATSUN 1200 FR GUARD LH (Sedan / Ute) * DT20-077-0 DATSUN 1200 TAILGATE
