Parts for 60-Series Transmissions are listed below. This includes 4-speeds and 5-speeds from B210 and B310 vehicles.
Part Number Prefixes
Also see main article: Applied Model Codes
* H90 B310 unique to F5W60L * 180 B10 56-series * H73 B210 60-series
Sandwich Plate
Case Comparo
B210 F4W60A * 32100-H7300 ASSY-CASE,TRANSMISSION B210 F4W60A 0974-0776 * 32100-H7302 ASSY-CASE,TRANSMISSION B210 F4W60A 0876-0377 * 32100-H8902 ASSY-CASE,TRANSMISSION B210 F4W60A 0477-
B310 F4W60 * 32100-H8902 CASE COMP-TRANSMISSION B310 F4W60 CANADA * 32100-H8903 CASE COMP-TRANSMISSION B310 F4W60 0879- USA * 32100-H9301 CASE COMP-TRANSMISSION B310 F4W60 0879- USA (supercedes 32100-H8903)
B310 FS5W60A * 32100-H9001 CASE COMP-TRANSMISSION B310 FS5W60A -0779 [FS5W60L, dogleg] * 32100-H9300 CASE COMP-TRANSMISSION B310 FS5W60A 0879- CAN (supercedes 32100-H9001) * 32100-H9301 CASE COMP-TRANSMISSION B310 FS5W60A 0879- FED, CAL (supercedes 32100-H9001)
F4W60L
rally cross of F4W60L Gear ratio * 1st: 3.19 * 2nd: 2.38 * 3rd: 1.89 * 4th: 1.00
F4W60 gears - B210 USA CATALOG 32200-H7300 ASSY-GEAR MAIN DRIVE 20T 32210-H7300 GEAR-COUNTER 31-27-20-15T 32220-H7300 GEAR-REVERSE COUNTER 14T 32230-H7300 ASSY-GEAR 1ST SPEED 34T 32250-H7300 ASSY-GEAR 2ND SPEED 28T 32260-H7300 ASSY-GEAR 3RD SPEED 24T 32280-H7300 ASSY-GEAR REVERSE IDLER 22T 32245-H7300 GEAR-REVERSE MAIN SHAFT 34T
Rebuild Kit
O'Reilly Auto Rebuild Kits PowerTorque BK173WS w/synchros $254 USD 60A PowerTorque BK173 w/o synchros $146 USD 60A
Synchro Kit adds includes five (5) brass BAULK RING. See Synchros
FS5W60A - non-dogleg 5-speed BALL BEARINGS (1) 32203 input shaft Type 206 (1) 32219M cluster shaft Type 304 (1) 32273 main shaft Type 305 (1) 32275 main shaft 22x50x14 NEEDLE ROLLER BEARINGS (1) 32219-H9700 cluster shaft (1) 32227-H9700 output shaft, rear SEALS (1) 32112-H7300 O-ring input shaft (1) 32114-Y4000 seal input shaft (1) C2136-H5000 seal output shaft
FS5W60A
post
FS5W60L
The 60L 5-speed is unique:
- 5th gear is added to the front
- It's a modified 4-speed. The newer 60A is a re-designed gearbox, sharing fewer parts with the 4-speed
Reverse GEAR/HUB on end of output shaft
(large 1st gear below, small rev/idler gears to right)
Gearset
* 32241-H9001 SHAFT-MAIN * 32264-H7300 BEARING-NEEDLE MAIN SHAFT 2 * 32260-H9000 GEAR ASSY-3RD 27T * 32604-H9000 RING-BAULK 4* 32603-18000 RING-SYNCHRONIZER 4 * 32609-18000 INSERT-SHIFTING 6 * 32601-H9001 HUB SYNCHRONIZER-2ND & 3RD * 32606-18000 SLEEVE-COUPLING 2 * 32250-H9000 GEAR ASSY-2ND * 32253-H7300 BUSH-1ST GEAR (MAIN SHAFT) 2 * 32246-H7300 WASHER-THRUST * 32273-H7300 BEARING-(BALL,) MAIN SHAFT * 32246-H9000 WASHER-THRUST MAIN SHAFT * 32267-H7300 BEARING-(NEEDLE,) MAIN SHAFT * 32230-H9000 GEAR ASSY-1ST * 32602-32200 SPRING-SHIFTING INSERT (SYNCHRONIZER INSERT) 3 unique to F5W60L * 32608-H9000 INSERT-SHIFTING 9 * 32258-H9001 HUB SYNCHRONIZER-1ST & REVERSE * 32245-H9000 GEAR-REVERSE, MAIN SHAFT * 32234-H9000 RETAINER SHIFTING INSERT Catalog is incorrect * 32354-H9000 NUT-HEX (M25 X 1.0) * 32228-H9000 RING-SNAP OVERDRIVE BEARING [Or 00922-12200?] * 00922-12200 RING-SNAP (T=1.2)? [Or 32228-H9000?] * 32227-H9000 BEARING-(BALL,) MAIN SHAFT END * 32228-H9000 RING-SNAP,MAIN SHAFT END BEARING [Or 00922-12200?] * 00922-12200 RING-SNAP (T=1.2) [Or 32228-H9000?]
Select only one 32204 * 32204-H7300 RING-SNAP MAIN DRIVE GEAR SELECT T=1.34-1.40 * 32204-H7301 RING-SNAP MAIN DRIVE GEAR SELECT T=1.40-1.46 * 32204-H7302 RING-SNAP MAIN DRIVE GEAR SELECT T=1.46-1.52 * 32204-H7303 RING-SNAP MAIN DRIVE GEAR SELECT T=1.52-1.58 * 32204-H7304 RING-SNAP MAIN DRIVE GEAR SELECT T=1.58-1.64 * 32204-H7305 RING-SNAP MAIN DRIVE GEAR SELECT T=1.64-1.70 * 32204-H7306 RING-SNAP MAIN DRIVE GEAR SELECT T=1.70-1.76 * 32209-H7300 SPACER-BEARING MAIN DRIVE GEAR * 32214-H7300 RING-MAIN BEARING 2 * 32203-H7300 BEARING-MAIN DRIVE * 32200-H7300 GEAR ASSY-MAIN DRIVE * 32272-H7300 BEARING-PILOT MAIN SHAFT 1 of 3 Select only one 32263 * 32268-H9000 RING-SNAP SELECT T=1.60 * 32268-H9001 RING-SNAP SELECT T=1.65 * 32268-H9002 RING-SNAP SELECT T=1.70 * 32601-H9000-HUB SYNCHRONIZER-4TH & 5TH [Also F560A] * 32340-H9000 GEAR ASSY-OVERDRIVE * 32345-H9000 BEARING-OVERDRIVE GEAR (NEEDLE MAIN SHAFT) * 32219-H9000 BEARING-COUNTER SHAFT [Also F460A 7812-] Select only one 32224 * 32224-H7200 WASHER-THRUST COUNTER SHAFT FRONT SELECT T=2.30-2.35 * 32224-H7201 WASHER-THRUST COUNTER SHAFT FRONT SELECT T=2.35-2.40 * 32224-H7202 WASHER-THRUST COUNTER SHAFT FRONT SELECT T=2.40-2.45 * 32224-H7203 WASHER-THRUST COUNTER SHAFT FRONT SELECT T=2.45-2.50 * 32224-H7204 WASHER-THRUST COUNTER SHAFT FRONT SELECT T=2.50-2.55 * 32224-H7205 WASHER-THRUST COUNTER SHAFT FRONT SELECT T=2.55-2.60 * 32224-H7206 WASHER-THRUST COUNTER SHAFT FRONT SELECT T=2.25-2.30 * 32224-H7207 WASHER-THRUST COUNTER SHAFT FRONT SELECT T=2.20-2.25 * 32210-H9000 GEAR-COUNTER ASSY * 32219-H9010 BEARING-COUNTER SHAFT * 32220-H9000 GEAR-REVERSE COUNTER Select only one 32222 * 32222-H9003 RING-SNAP COUNTER SHAFT SELECT T=1.3 * 32222-H9004 RING-SNAP COUNTER SHAFT SELECT T=1.4 * 32284-H9000 WASHER-THRUST COUNTER SHAFT REAR [Mistake? See 32285N] * 32282-H9000 GEAR-REVERSE IDLER * 32272-H7300 BEARING-REVERSE IDLER GEAR 2 2 of 3 * 32285-H9000 SPACER-REVERSE IDLER GEAR * 32292-14600 PIN-RETAINING [Also F560A] * 32281-H9000 SHAFT-REVERSE IDLER * 32284-N9000 WASHER-THRUST REVERSE IDLER 2
Bearings
RockAuto.com
BALL BEARING - input shaft 62x30x11 mm * Nissan 32203-H7300 BEARING-MAIN DRIVE $31.78 USA * Timken 206L* SUZUKI 08163-62063 * SKF 6206ZNRJ * Nachi 6206N C3 SPECS * Inside Diameter: 30 mm, 1.1811 in * Outside Diameter: 62 mm, 2.4409 in * Width: 16 mm, 0.6299 in * C3:radial clearance greater than Normal BALL BEARING - counter shaft, rear 20x52x15 mm * Nissan 32219-H8900 > 32219-H7300 BEARING-COUNTER SHAFT, REAR $95.28 USD [32219M] * Nachi 6304N * Timken 304WB * Timken 304DD (sealed) * National 304 (open)
Specifications: * Width 15mm, 0.591 in. * Bore 20mm , 0.787 * OD 52mm, 2.047 ENCLOSED BEARING - counter shaft, rear * Nissan 32219-H9702 > 32219-H9700 BEARING-COUNTER SHAFT, FRONT $22 USD [32219]
NEEDLE CAGE - output shaft, rear 18x24x17 mm needle roller bearing * Nissan 32272-H7300 BEARING-PILOT 32272-G3201 $26.02 USD > 32272-14600, 32272-H7300 * Koyo RS18/17P
32264M 32264-H7300 BEARING-NEEDLE MAIN SHAFT $38.43 USD Rear 60A National B1616 * Cone Bore: 25.400mm, 1.00 inch * Outside Diameter: 31.750mm, 1.250 inch * Width: 25.400mm, 1.00 inch![]()
NEEDLE CAGE - output shaft, rear 32350 BEARING-overdrive gear * 32345-H9000 60L 5-speed * 32345-H9702 60A
32283 32289-H9701 > 32289-H9700 BEARING-REVERSE IDLER GEAR $28.60 USD * 60L 5-SPEED (2) * 60A 5-SPEED (1)
60L 5-speed Bearings/Bushings
PowerTorque BK139 F4W60 $144 USD
FS5W60A
60A 5-speed Gearset
full
Input shaft, Counter shaft, Reverse/Idle shaft
full
Output shaft
full
5th gear bolted to end of cluster shaft
Cluster shaft and free-gears (1st, 2nd, 3rd)
32604-H9700 Synchro BAULK RING & matching gear surface
Input Shaft Bearing
BALL BEARING-MAIN DRIVE (Input shaft) 30x62x16 * Nissan 32203-H7300 (type 6206) * Timken 206SL * Nachi 6206N FITS: 60L, 60A
Output Shaft Bearing
BALL BEARING - MAIN SHAFT (Output shaft, mid) 25x62x17 * Nissan 32273-H7300 * NSK 6305NR * SKF 43305C * Nachi 6305 N C3 150314 * Timken 305L FITS * 60 4-speed, 60L 5-speed, 60A 5-speed, 56A 4-speed
BALL BEARING - MAIN SHAFT (Output shaft, rear) 22x50x14 * Nissan 32227-H9700 [32275] * Nachi 62/22XA1 140827 (22x50x14 ball bearing)
NEEDLE BEARING - PILOT (output shaft, front) 18x24x17 mm * Nissan 32272-H7300
NEEDLE BEARING - MAIN SHAFT * Nissan 32264-H7300 (2) [32264M]
NEEDLE BEARING - MAIN SHAFT * Nissan 32267-H7300 (2) [32264]
NEEDLE BEARING - OVERDRIVE GEAR (input shaft, 5th gear) * Nissan 32345-H9702 [32350]
Cluster Bearings
60A 5-speed Bearings/Bushings
32219 BEARING-COUNTER SHAFT 32219-H9700 FS5W60A $95.28 USD * enclosed needle roller bearing * ? NTN 7E-BKS20X32X20-4 181410 DRAWN CUP NRB (CAGE TYPE needle)
32219M BEARING-COUNTER SHAFT 20x52x15 * Nissan 32219-H7300 * Timken 304WB * National 304 * Nachi 6304N CE 150525 (20x52x15 ball bearing) Fits * F4W60L * FS5W60A
32224 WASHER-THRUST COUNTER SHAFT FRONT * SELECT USE T=2.30 - T=2.25
32283 BEARING-REVERSE IDLER GEAR 32283 32289-H9701 > 32289-H9700 BEARING-REVERSE IDLER GEAR $28.60 USD * 60L 5-SPEED (2) * 60A 5-SPEED (1)
32287 WASHER-THRUST REVERSE IDLER 32265-18000 * F4W56 * FS5W60A
Thrust Washers
32287 32265-18000 WASHER-THRUST REVERSE IDLER [center] 32318 32287-H9700 WASHER-THRUST [REVERSE IDLER, rear] 32285N 32283-H9700 WASHER-THRUST REVERSE IDLER [front] 32224 WASHER-THRUST COUNTER SHAFT FRONT SELECT USE 32224-H7200 T=2.30-2.35 32224-H7201 T=2.35-2.40 32224-H7202 T=2.40-2.45 32224-H7203 T=2.45-2.50 32224-H7204 T=2.50-2.55 32224-H7205 T=2.55-2.60 32224-H7206 T=2.25-2.30 32224-H7207 T=2.20-2.25
Seals
- The three welch plugs are not normally replaced or even removed
Front Cover O-ring
32112M 32112-H7300 RING-O FRONT COVER
Front Cover Seal
Front Cover Oil Seal for Aichi R4W60L/W60 4-speed, W60L/W60A 5-speed, RS5W60R 5-speed
Nissan 32114-Y4000 * A12/A14/A15,KA20DE/KA24E/KA24DE,TD23/TD25/TD27,NA20 * RD28,RB20,L18/LD20/L20,H20,Z18/Z20,VG20/VG30,FJ20,CA18 * 60-series, 71-series 71B/71C
Specs * shaft size: 30 mm * bore size: 45 mm * seal outer diameter: 45.2 mm * seal width: 8 mm * Polyacrylate or Nitrile
RockAuto TCM 30X45X 10TC-BX National 1981 Timken 1981 Fits: * Nissan 32113-Y4000, 32114-20100, 32114-Y4000 * 8942152200 * 8943270620, 8943270621, 8943348450, 8943895931 * 9004310029, 9004311141, 9031130010, 9031130014 * 9031130115, 94215220, 94327062 * Ford EBTZ7052D * Toyota W55 transmission * Isuzu 8943270620 camshaft seal
Output Shaft
32150-H7300 4-speed 8110-
4-speed & 5-speed RockAuto.com * Nissan C2136-H8900 > 32136-H8900 $10.00 USD * Nissan C2136-H5000 > 32136-H5000 OIL SEAL-REAR EXTENSION $23.87 USD * Timken 2016 * SKF 11619 (also says it replaces 32136-G1001) SPECS * 56A,60A,60L * Nitrile Seal, Counter-Clockwise-Spiral Design * Shaft Size: 1.181" * Housing Bore: 1.772" * Seal Width: 0.591" * Seal Outside Dia: 1.78" * Flange Outer Diameter=2.441" (?)![]()
Extension Housing
32160- many EXTENSION ASSY-REAR
Factory Service Manual says:If rear extension bushing is worn or cracked, replace it as an assembly of bushing and rear extension
