60-Series Transmission Parts
Revision as of 08:25, 27 January 2016; view current revision
Category: Transmission
Parts for 60-Series Transmissions are listed below. This includes 4-speeds and 5-speeds from B210 and B310 vehicles.
Part Number Prefixes
Also see main article: Applied Model Codes
The applied model part of the Part Number indicates the original use of the part. You'll find that several parts of the 60 gearboxes were originally used by the 56 gearboxes (180 parts), but that many parts are unique (H73 parts).
* 180	B10	56-series
* H73	B210	60-series
* H90	B310	unique to F5W60L
Rebuild Kit
O'Reilly Auto Rebuild Kits
PowerTorque BK173WS w/synchros $254 USD 60A
PowerTorque BK173 w/o synchros $146 USD 60A
Bearing Kit
Synchro Kit adds includes five (5) brass BAULK RING. See Synchros
FS5W60A - non-dogleg 5-speed
BALL BEARINGS
(1) 32203-H7300  input shaft   Type 206
(1) 32219-H8900  cluster shaft Type 304
(1) 32273-H7300  main shaft    Type 305
(1) 32227-H9700  main shaft    22x50x14
NEEDLE ROLLER BEARINGS
(1) 32219-H9700 cluster shaft
(1) 32227-H9700 output shaft, rear
SEALS
(1) 32112-H7300 O-ring input shaft
(1) 32114-Y4000 seal   input shaft
(1) C2136-H5000 seal   output shaft
FS5W60A
post
FS5W60L
The 60L 5-speed is unique:
  • 5th gear is added to the front
  • It's a modified 4-speed. The newer 60A is a re-designed gearbox, sharing fewer parts with the 4-speed
full
Reverse GEAR/HUB on end of output shaft
(large 1st gear below, small rev/idler gears to right)
Gearset
full
* 32241-H9001 SHAFT-MAIN
* 32264-H7300 BEARING-NEEDLE MAIN SHAFT 2
* 32260-H9000 GEAR ASSY-3RD 27T
* 32604-H9000 RING-BAULK 4
* 32603-18000 RING-SYNCHRONIZER 4
* 32609-18000 INSERT-SHIFTING 6
* 32601-H9001 HUB SYNCHRONIZER-2ND & 3RD
* 32606-18000 SLEEVE-COUPLING 2
* 32250-H9000 GEAR ASSY-2ND
* 32253-H7300 BUSH-1ST GEAR (MAIN SHAFT) 2
* 32246-H7300 WASHER-THRUST
* 32273-H7300 BEARING-(BALL,) MAIN SHAFT
* 32246-H9000 WASHER-THRUST MAIN SHAFT
* 32267-H7300 BEARING-(NEEDLE,) MAIN SHAFT
* 32230-H9000 GEAR ASSY-1ST
* 32602-32200 SPRING-SHIFTING INSERT (SYNCHRONIZER INSERT) 3
  unique to F5W60L
* 32608-H9000 INSERT-SHIFTING 9
* 32258-H9001 HUB SYNCHRONIZER-1ST & REVERSE
* 32245-H9000 GEAR-REVERSE, MAIN SHAFT
* 32234-H9000 RETAINER SHIFTING INSERT
  Catalog is incorrect
* 32354-H9000 NUT-HEX (M25 X 1.0)
* 32228-H9000 RING-SNAP OVERDRIVE BEARING [Or 00922-12200?]
* 00922-12200 RING-SNAP (T=1.2)? [Or 32228-H9000?]
* 32227-H9000 BEARING-(BALL,) MAIN SHAFT END
* 32228-H9000 RING-SNAP,MAIN SHAFT END BEARING [Or 00922-12200?]
* 00922-12200 RING-SNAP (T=1.2) [Or 32228-H9000?]
full
Select only one 32204
* 32204-H7300 RING-SNAP MAIN DRIVE GEAR SELECT T=1.34-1.40
* 32204-H7301 RING-SNAP MAIN DRIVE GEAR SELECT T=1.40-1.46
* 32204-H7302 RING-SNAP MAIN DRIVE GEAR SELECT T=1.46-1.52
* 32204-H7303 RING-SNAP MAIN DRIVE GEAR SELECT T=1.52-1.58
* 32204-H7304 RING-SNAP MAIN DRIVE GEAR SELECT T=1.58-1.64
* 32204-H7305 RING-SNAP MAIN DRIVE GEAR SELECT T=1.64-1.70
* 32204-H7306 RING-SNAP MAIN DRIVE GEAR SELECT T=1.70-1.76
* 32209-H7300 SPACER-BEARING MAIN DRIVE GEAR
* 32214-H7300 RING-MAIN BEARING 2
* 32203-H7300 BEARING-MAIN DRIVE
* 32200-H7300 GEAR ASSY-MAIN DRIVE
* 32272-H7300 BEARING-PILOT MAIN SHAFT 1 of 3
Select only one 32263
* 32268-H9000 RING-SNAP SELECT T=1.60
* 32268-H9001 RING-SNAP SELECT T=1.65
* 32268-H9002 RING-SNAP SELECT T=1.70
* 32601-H9000-HUB SYNCHRONIZER-4TH & 5TH [Also F560A]
* 32340-H9000 GEAR ASSY-OVERDRIVE
* 32345-H9000 BEARING-OVERDRIVE GEAR (NEEDLE MAIN SHAFT)
* 32219-H9000 BEARING-COUNTER SHAFT [Also F460A 7812-]
Select only one 32224
* 32224-H7200 WASHER-THRUST COUNTER SHAFT FRONT SELECT T=2.30-2.35
* 32224-H7201 WASHER-THRUST COUNTER SHAFT FRONT SELECT T=2.35-2.40
* 32224-H7202 WASHER-THRUST COUNTER SHAFT FRONT SELECT T=2.40-2.45
* 32224-H7203 WASHER-THRUST COUNTER SHAFT FRONT SELECT T=2.45-2.50
* 32224-H7204 WASHER-THRUST COUNTER SHAFT FRONT SELECT T=2.50-2.55
* 32224-H7205 WASHER-THRUST COUNTER SHAFT FRONT SELECT T=2.55-2.60
* 32224-H7206 WASHER-THRUST COUNTER SHAFT FRONT SELECT T=2.25-2.30
* 32224-H7207 WASHER-THRUST COUNTER SHAFT FRONT SELECT T=2.20-2.25
* 32210-H9000 GEAR-COUNTER ASSY
* 32219-H9010 BEARING-COUNTER SHAFT
* 32220-H9000 GEAR-REVERSE COUNTER
Select only one 32222
* 32222-H9003 RING-SNAP COUNTER SHAFT SELECT T=1.3
* 32222-H9004 RING-SNAP COUNTER SHAFT SELECT T=1.4
* 32284-H9000 WASHER-THRUST COUNTER SHAFT REAR [Mistake? See 32285N]
* 32282-H9000 GEAR-REVERSE IDLER
* 32272-H7300 BEARING-REVERSE IDLER GEAR 2 2 of 3
* 32285-H9000 SPACER-REVERSE IDLER GEAR
* 32292-14600 PIN-RETAINING [Also F560A]
* 32281-H9000 SHAFT-REVERSE IDLER
* 32284-N9000 WASHER-THRUST REVERSE IDLER 2
Bearings
RockAuto.com
BALL BEARING - input shaft (main drive)
62x30x11 mm Type 206
* 32203-H7300
BALL BEARING - counter shaft, rear
20x52x15 mm Type 304
* 32219-H8900
BALL BEARING - MAIN SHAFT, MID
* 32273-H7300
BALL BEARING - MAIN SHAFT END
* 32227-H9000
ENCLOSED BEARING - counter shaft, rear
* Nissan 32219-H9702 > 32219-H9700 BEARING-COUNTER SHAFT, FRONT $22 USD [32219]
NEEDLE CAGE - output shaft, rear
18x24x17 mm needle roller bearing
* Nissan 32272-H7300 BEARING-PILOT 32272-G3201 $26.02 USD > 32272-14600, 32272-H7300
* Koyo RS18/17P
32264M 32264-H7300 BEARING-NEEDLE MAIN SHAFT $38.43 USD
 Rear 60A
 National B1616
 * Cone Bore: 25.400mm, 1.00 inch
 * Outside Diameter: 31.750mm, 1.250 inch
 * Width: 25.400mm, 1.00 inch
32350 BEARING-overdrive gear
* 32345-H9000 60L 5-speed
* 32345-H9702 60A
32283  32289-H9701 > 32289-H9700 BEARING-REVERSE IDLER GEAR $28.60 USD
* 60L 5-SPEED (2)
* 60A 5-SPEED (1)
60L 5-speed Bearings/Bushings
32203-H7300
62x30x11 mm
* Nissan 32203-H7300 BEARING-MAIN DRIVE $31.78 USA
* Timken 206L
* SUZUKI 08163-62063
* SKF 6206ZNRJ
* Nachi 6206N C3
SPECS
* Inside Diameter: 30 mm, 1.1811 in
* Outside Diameter: 62 mm, 2.4409 in
* Width: 16 mm, 0.6299 in
* C3:radial clearance greater than Normal
APPLICATIONS:
* FS5W60L 5-speed input shaft
* FS5W60A 5-speed input shaft
32219-H8900
* Nissan 32219-H8900 > 32219-H7300 BEARING-COUNTER SHAFT, REAR $95.28 USD [32219M]
* Nachi 6304N
* Timken 304WB
* Timken 304DD (sealed)
* National 304 (open)
SPECS
* Width 15mm, 0.591 in.
* Bore 20mm , 0.787
* OD 52mm, 2.047
APPLICATIONS
* FS5W60L 5-speed counter shaft, rear
32273-H7300
BALL BEARING - Main Shaft, middle
* Nissan 32273-H7300 BEARING-(BALL,) MAIN SHAFT, MID
APPLICATIONS
* FS5W60L
* FS5W60A
32227-H9000
BALL BEARING - Main Shaft end
* Nissan 32227-H9000 BEARING-(BALL,) MAIN SHAFT END
APPLICATIONS
* FS5W60L
FS5W60A
60A 5-speed Gearset
full
Input shaft, Counter shaft, Reverse/Idle shaft
full
Output shaft
full
1st, 1-2 hub, 2nd
Reverse/Idler Gears
th_60a-reverse.jpg th_60a-reverse-1.jpg th_60a-reverse-2.jpg th_60a-rev-1.jpg th_60a-rev-2.jpg
5th gear bolted to end of cluster shaft
Cluster shaft and free-gears (1st, 2nd, 3rd)
32604-H9700 Synchro BAULK RING & matching gear surface
th_case-1.jpg th_case-2.jpg th_case-3.jpg th_case-a.jpg th_case-b.jpg th_casec.jpg
Input Shaft Bearing
BALL BEARING-MAIN DRIVE (Input shaft)
30x62x16
* Nissan 32203-H7300 (type 6206)
* Timken 206SL
* Nachi 6206N
FITS: 60L, 60A
Output Shaft Bearing
BALL BEARING - MAIN SHAFT (Output shaft, mid)
25x62x17
* NSK 6305NR
* SKF 43305C
* Nachi 6305 N C3 150314
* Timken 305L
FITS
* 60 4-speed, 60L 5-speed, 60A 5-speed, 56A 4-speed
BALL BEARING - MAIN SHAFT (Output shaft, rear)
22x50x14
* Nissan 32227-H9700 [32275]
* Nachi 62/22XA1 140827 (22x50x14 ball bearing)
NEEDLE BEARING - PILOT (output shaft, front)
18x24x17 mm
NEEDLE BEARING - MAIN SHAFT
* Nissan 32264-H7300 (2) [32264M]
* Nissan 32267-H7300 (2) [32264]
NEEDLE BEARING - OVERDRIVE GEAR (input shaft, 5th gear)
* Nissan 32345-H9702 [32350]
Cluster Bearings
60A 5-speed Bearings/Bushings
32219 BEARING-COUNTER SHAFT
32219-H9700 FS5W60A $95.28 USD
* enclosed needle roller bearing
* ? NTN 7E-BKS20X32X20-4 181410 DRAWN CUP NRB (CAGE TYPE needle)
32219M BEARING-COUNTER SHAFT
20x52x15
* Nissan 32219-H7300
* Timken 304WB
* National 304
* Nachi 6304N CE 150525 (20x52x15 ball bearing)
Fits
* F4W60L
* FS5W60A
32224 WASHER-THRUST COUNTER SHAFT FRONT
* SELECT USE T=2.30 - T=2.25
32283 BEARING-REVERSE IDLER GEAR
* 60L 5-SPEED (2)
* 60A 5-SPEED (1)
32287 WASHER-THRUST REVERSE IDLER
32265-18000
* F4W56
* FS5W60A
Thrust Washers
32287  32265-18000 WASHER-THRUST REVERSE IDLER [center]
32318  32287-H9700 WASHER-THRUST [REVERSE IDLER, rear]
32285N 32283-H9700 WASHER-THRUST REVERSE IDLER [front]
       SELECT USE
       32224-H7200 T=2.30-2.35
       32224-H7201 T=2.35-2.40
       32224-H7202 T=2.40-2.45
       32224-H7203 T=2.45-2.50
       32224-H7204 T=2.50-2.55
       32224-H7205 T=2.55-2.60
       32224-H7206 T=2.25-2.30
       32224-H7207 T=2.20-2.25
Seals
Front Cover O-ring and Seal
  • The three welch plugs are not normally replaced or even removed
Front Cover O-ring
32112M  32112-H7300 RING-O FRONT COVER
Front Cover Seal
Front Cover Oil Seal for Aichi R4W60L/W60 4-speed, W60L/W60A 5-speed, RS5W60R 5-speed
Nissan 32114-Y4000
* A12/A14/A15,KA20DE/KA24E/KA24DE,TD23/TD25/TD27,NA20
* RD28,RB20,L18/LD20/L20,H20,Z18/Z20,VG20/VG30,FJ20,CA18
* 60-series, 71-series 71B/71C
Specs
* shaft size: 30 mm
* bore size: 45 mm
* seal outer diameter: 45.2 mm
* seal width: 8 mm
* Polyacrylate or Nitrile
RockAuto
TCM 30X45X 10TC-BX
National 1981
Timken 1981
Fits:
* Nissan 32113-Y4000, 32114-20100, 32114-Y4000
* 8942152200
* 8943270620, 8943270621, 8943348450, 8943895931
* 9004310029, 9004311141, 9031130010, 9031130014
* 9031130115, 94215220, 94327062
* Ford EBTZ7052D
* Toyota W55 transmission
* Isuzu 8943270620 camshaft seal
Output Shaft
32150-H7300 4-speed 8110-
4-speed & 5-speed RockAuto.com
* Nissan C2136-H8900 > 32136-H8900 $10.00 USD
* Nissan C2136-H5000 > 32136-H5000 OIL SEAL-REAR EXTENSION $23.87 USD
* Timken 2016
* SKF 11619 (also says it replaces 32136-G1001)
FITS
* 56A,60A,60L
SPECS
* Material        Nitrile
* Shaft Size      1.181" 30mm
* Housing Bore    1.772" 45mm
* Outer Diameter  1.78"  45.2mm
* Flange Diameter 2.441" 62mm
* Width           0.591" 15mm
Sandwich Plate
th_ds325050m3508d-img600x448-1415020101v4pvcr8911.jpg th_60A-sandwhich_.jpg th_60A-sandwhich.jpg
Case Comparo
B210 F4W60A
* 32100-H7300 ASSY-CASE,TRANSMISSION B210 F4W60A 0974-0776
* 32100-H7302 ASSY-CASE,TRANSMISSION B210 F4W60A 0876-0377
* 32100-H8902 ASSY-CASE,TRANSMISSION B210 F4W60A 0477-
B310 F4W60
* 32100-H8902 CASE COMP-TRANSMISSION B310 F4W60 CANADA
* 32100-H8903 CASE COMP-TRANSMISSION B310 F4W60 0879- USA
* 32100-H9301 CASE COMP-TRANSMISSION B310 F4W60 0879- USA (supercedes 32100-H8903)
B310 FS5W60A
* 32100-H9001 CASE COMP-TRANSMISSION B310 FS5W60A -0779 [FS5W60L, dogleg]
* 32100-H9300 CASE COMP-TRANSMISSION B310 FS5W60A 0879- CAN (supercedes 32100-H9001)
* 32100-H9301 CASE COMP-TRANSMISSION B310 FS5W60A 0879- FED, CAL (supercedes 32100-H9001)
F4W60L
rally cross of F4W60L Gear ratio
* 1st: 3.19
* 2nd: 2.38
* 3rd: 1.89
* 4th: 1.00
F4W60 gears - B210 USA CATALOG
32200-H7300 ASSY-GEAR MAIN DRIVE 20T
32210-H7300 GEAR-COUNTER 31-27-20-15T
32220-H7300 GEAR-REVERSE COUNTER 14T
32230-H7300 ASSY-GEAR 1ST SPEED 34T
32250-H7300 ASSY-GEAR 2ND SPEED 28T
32260-H7300 ASSY-GEAR 3RD SPEED 24T
32280-H7300 ASSY-GEAR REVERSE IDLER 22T
32245-H7300 GEAR-REVERSE MAIN SHAFT 34T
Extension Housing
32160- many EXTENSION ASSY-REAR
Factory Service Manual says:
If rear extension bushing is worn or cracked, replace it as an assembly of bushing and rear extension
