Ball Joint Comparison
Revision as of 14:09, 7 October 2020; view current revision
Category: Front Axle And Front Suspension
40160 is the part number for Ball Joint. Here is a comparo of selected Datsun ball joints.
H10
40160-H1000 - B110 and early Truck/early B210 Style $77.83 USD
M8 bolts
40160-H5000 supercedes 40160-H1000
40160-H1001 (formerly 40160-H1000)  fits:
* B110 1970-1973
* B210 1973-1975 except H & P models (HB210 or PB210)
* B120 1971-September 1975
Aftermarket
* Raybestos 5051044
* AC/Delco 45D2044 (88911542)
* SIDEM 41084
* PROTEX BJ92
* QUINTON HAZELL QSJ618S
H10 Ball Joint
Dust Cover 40192-G1500
H74
40160-H7400 - Late B210/Late 1200 Truck Style
40160-H7400 - M10 bolts $77.83 USD
This is the same length as B110, but the bolt pattern is a wee bit different. They fit on a revised LCA which are identical to B110 but for the ball joint bolt pattern.
* B210 1976-1977 except L16 model
* VB210 from October 1975
* B211 1975-1977
* LB210 1975-1977 except europe & USA
* B310 1977-1981 (120Y) with A12 engine
* LB310 1978-1982 with A12A engine - Canada
* B120 Truck October 1975-1994
Aftermarket
MOOG NI-BJ-10016
FIRST LINE FBJ5088
LEMFÖRDER 183000037574
OCAP 403574
QUINTON HAZELL QSJ1253S
SIDEM 41380
SPIDAN 44016
TRIPLE FIVE SB4122
TRW 10016 - JBJ183
PROTEX BJ176
H10 vs H74
Outer bolt holes are wider apart. Approximately 50 mm vs 40mm
Because of the changed patterns, H74 requires notched Tension Rods with bolt holes drilled farther apart
Fasteners: M8 vs M10, so the LCA bolt holes are larger
Type H10
08911-60810 NUT (6) [M8]
* 08911 = Hex Nut
* 6 = high, medium carbon steel
* 08 = M8
* 1 = Zinc cadmium coated
08915-13810 WASHER-lock (8)
* 08915 = Washer
* 1 = Spring lock medium
* 38 = 8 + 30 = M8
Type H74
08911-64010 NUT (M10 X 1.25)
* 08911 = Hex Nut
* 40 = 10 + 30 = M10
08915-14010 WASHER (M10)
* 08915 = Washer
A10/B310 Style
40160-W5001 (formerly 40161-W5000)
This longer ball joint fits on the revised 1976-up LCA. This later B120/B210/B310 LCA can fit either H74 or W50 ball joints.
* S110 1979-1981 with Z18S, Z18E
* A10/A11 1977-1981
* HB310/PB310 1977-1982 -- all with 2" struts
B310 A14/A15 engine + all USA models. A12 powered B310 use the 45mm struts with H74 ball joints.
Ball-joint: A10, A11, B310, S110
Aftermarket
McQuay-Norris FA1265
TRW 10341
Moog K9073
Mevotech MK9073
Beck/Arnley 1013234
Raybestos 5051061
AC/Delco 45D2061 (88911559)
SIDEM 41388
H74 vs W50 (bj163)
LCA with knuckle arm bolted to the Ball Joint
B10
Datsun 1000 ball joints are totally different from Datsun 1200.
Buy at Bprojects Japan or Bprojects Australia.
40160-18000 Lower Ball Joint
th_balljoint-lower-350010.jpg th_40160-18000-350017.jpg th_40160-18000-350019.jpg th_40160-18000_a.jpg th_40160-18000_b.jpg
40110-18001 Upper Ball Joint (2)
th_balljoint-up-350006.jpg th_balljoint-up-350007.jpg th_balljoint-up-350008.jpg th_40110-18001_a.jpg th_40110-18001_b.jpg
40110-18001 replaces
* 40110-18000 Upper Right
* 40111-18000 Upper Left
Upper Right & Left pair
510/610/710 Style
40160-A8625 (formerly A8610, A8600, U7000)
* 510 (1300/1400/1600/1800) 1968-1973
* 610 (180B) 1973-1976 except G610
* S10/S11 Silvia/200SX 1975-1979
* 710/711 Violet/160J 1973-1977
* PB110 Sunny Excellent 1970-1973
* PB210/GB210 1973-1977
* HB210 USA & CANADA
* GB211 (L16) 1975-1977
* LB210 1975-1977 Europe
280ZX/810 Style
40160-S0128 (formerly -SO127,126,125,106,105,104,P6525)
  • S130 (280ZX) 1978-1983
  • C130/C131/C230/C231 (Laurel) 1972-1980
  • Skyline C110/C111/C210/C211 1972-1980
  • 810 (Bluebird) 1976-1979
  • 910 (Bluebird) 1979-1983 Z18P only
910 Style
40160-W2210 (formerly W2200, W1001,W1000)
  • F30 (Leopard) 1980-1986
  • 910 (Bluebird) 1979-1983 except Z18P
  • S12 (Silvia/Gazelle) 1983-1988
R31 Style
40160-41L00 (formerly 40160-67L00)
  • F31 (Leopard) 1986-
  • C32 (Laurel) 1984-
  • R31 (Skyline) 1985-
ボール ジョイント
