A remote-mounted Hydraulic clutch Master cylinder may also be needed if there is not enough room in the engine compartment.
Mount the clutch master inside the passenger compartment -- under the dash -- and connect it to the gearbox slave cylinder via a hydraulic line.
- Fabricate L-shaped bracket, bolt (or weld) to the under-dash steering column brace
- Lengthen clutch pedal, attach the master rod ABOVE the fulcrum
- Place the filler tube under the dash, connect to master via rubber hose
Not enough room after a big Engine Swap? Move the clutch master under the dash!
PIGDOG
PIGDOG used a A20 Celica (1970-1977) master cylinder and replaced the Reservior with a banjo fitting
Celica first generation A20 (A21, A22, A25, A27, etc.)
Banjo fittings are available at auto parts stores in generic metric sizes. PIGDOG used one off a Nissan Skyline#R33 power steering pump.
HiAce brake reservoir with one of the outlets blocked off was mounted in the engine bay. Big hose is just the feed from the reservoir so no pressure in there....same clamp that was on there stock
Girling
Under-dash mounted Girling clay pipe master
Girling "claypipe" master cylinder, available in 5/8" and 3/4" bores (about $70 AUD). Threads are 3/8 unc for pipe outlet and 7/16 unc for fluid in
Urvan
http://en.wikipedia.org/wiki/Nissan_Caravan
- Use with Nissan Urvan remote-fill tops
- A simple 90-degree bracket is fabricated to mount it to the under-dash steering column brace
Sentra
http://en.wikipedia.org/wiki/Nissan_Sentra (Nissan Sunny FWD)
Nissan Sentra Clutch Master Cylinder
Fluid reservoir is connected to the cylinder via a rubber hose.
Similar to Sentra B15U clutch master 30610-5M007 (top outlet)
Lancer
http://en.wikipedia.org/wiki/Mitsubishi_Lancer_(A70)
For ideas, could something like this be used on a 1200?
Cable-to-Hydraulic custom remote clutch m/c found on Mitsubishi LA Lancer
