These are important parts, oftentimes overlooked, but can have a large effect on how well the carburetor works.
Remanufactured Carburetor
http://www.rockauto.com * TOMCO 10002A AT w/Electric Choke $200.79, MT w/Electric Choke $204.79 USD Carburetor (remanufactured)
Miscellaneous Carburetor Parts
Float
Plastic float
Fuel Inlet Valve
16101-H1000 VALVE-NEEDLE * DCG306/DCH306 * Hitachi Twin Carb
Choke Pull Off
Choke Pull Off * Nissan 16011-H3910 * Tomco 7248, Carter 202-854 * TOMCO 7211 (Type HI-2), A12A 1981-1982 (strait fitting) $9 * TOMCO 7213 A14 1978-1981 (80-degree fitting) * 7281 1978-1980 * TOMCO 7386 A12A 1980 (90-degree fitting) * TOMCO 7390 A14 1975-1978 (90-degree fitting) $8
Fuel-cut Valve
Anti-Diesel valve * TOMCO 8134 $36 * Chevy Luv Truck 1975-1980 * Ford Courier Truck 1979-1980 * Honda 1973-1976 * Mazda 1975-1978 * Datsun 1973-1983 * Subaru 1974-1980
Insulator
Heat Shield
Throttle Chamber
Gaskets
Also see: Carburetor Part Numbers
Repair Kit
A kit usually contains:
* new accelerator pump * gaskets and o-rings * new inlet valve * parts breakdown diagram * brief instructions
- Some kits contain new jets but be careful they are the correct ones for your engine.
- Some gasket kits contain more than one style of top gasket.
- Kits do not contain the auto-#Choke Pull Off, one of the most prone to break parts
* H16 (B110, early B210) * H88 (early B310) * H8805 (late B310, B120 1981-1989)
Gasket Set
Contains gaskets only. Fits all B110 and early B120.
Nissan 16455-H6201 GASKET KIT contains 1) top gasket 2) throttle chamber gasket 3) pump cover
Top gasket = choke chamber gasket
Throttle Chamber Gasket
1970-1974 without the extra hole
Manifold gaskets
Two needed, one for each side of spacer. They can usually be re-used.
Late Model A12 (8910-) manifold/insulator gasket 16174-19B00
Part Numbers, B110
See Index#Fuel
