NOTE: If possible, add new information in the article for the part type. Let's phase out this article.
This is a list of Part Numbers. Note that discontinued (NLA) parts can sometimes be found on eBay or from individual stores (NOS or "New Old Stock"), so adding NLA part numbers to this article is useful.
This article may include links to specialty suppliers, but generally the supplier contact information is in the Parts Sources article. Best to not provide links here, so that we don't have to update the supplier's links in multiple articles.
Maintainence & Tune-Up Parts
See: Parts_Sources#General Tune-up Parts
- Roger's asian auto Parts
- Koni Shocks
- Brake pads
- classicgarage (USA)
Misc Parts
oil cap, gas cap (fuel cap), Fuel Pump , automatic choke bimetal spring, Carb to air cleaner gasket
radiator hoses, fuel hose, vacuum hose, drive belt (fan belt).
Body-Interior
Speedometer cable, Steering Column
Seats
See: Seats
Body Parts
See Body panels
Mirrors
See Mirrors
Sun Visors
See Visors
Rubber parts
See Rubber parts
Front Suspension Parts
McPherson Strut rebuild kit. Strut replacement inserts, idler arm, pittman arm, drag link, tie-rod ends
Steering Parts
See Steering System
Rear Suspension Parts
rear Leaf springs, Shock absorbers, front coil springs
Also see:
- [[Brake Swaps]
- Suspension Upgrades
Brakes & Hub
see Brakes
Clutch
See Clutch
Cooling System
See Radiator
Electrical
- <li>coil ballast resistor: BECK/ARNLEY 1788000 $6.28, ACDELCO E1113, AIRTEX 6R1016 $10.19
<li>Condensor: BOSCH 02135 $3.06, Airtex 5H1015 $6.19, (for rear of dual-point sytem: Airtex 5H1016 $6.12)
<li>Contact Set (Ignition Points): BECK/ARNLEY 1710391 $3.31, BOSCH 01134 $4.49, ACDELCO E179,
</ul>
Drivetrain
Gearbox Bearings
- Use a general bearing supplier, like CBC Bearings or SKF. They should be able to supply them if you can give them the numbers off the existing bearings, they have them in stock and far less dollars than Nissan. This is one case where buying from Nissan is not economical.
Engine
General Replacement & Repair Parts
- http://www.rockauto.com
- NAPA Auto Parts
See Gilmer drive
Gaskets
- Nissan: Head gasket set (includes head gasket, rocker cover gasket, intake & exhaust gaskets and thermostat gasket)
- PN 11042-18027 (replaced PN 11042-H1025)
- Nissan GX manifold gaskets
- carb gasket: 16175-A5100
- shield to manifold: 16174-H2300
- Head to manifold : 14035-H2300
- Tomei head and intake/exhaust gasket, GX gaskets, large bore head gaskets
- Pitroad sells A-series gaskets, including 27mm round intake and and 35x29 (GX?) gaskests. See http://www3.ocn.ne.jp/~kyuusya/index-3.htm
VALVES
- PAECO
- NAPA
VALVE SPRINGS
- wikipedia:BMC A-serie engine use the same valvespring sizes as the Datsun A-series -- partE S-002-8. Approx. $58.81 USD
- Nissan Motorsport competition dual springs with aluminum retainers. These are for high-rpm use with a compatible camshaft.
- Crane (discontinued) part# 902-0002 are a single spring rated at 80 lbs. closed at 1.531" installed height, and 209 lbs. at 1.131".
- Crane Mini springs (for Austin Mini)
- Iskenderian JA-006 inner springs (for dual spring use) are the right diameter but not enough pressure.
Fuel/Air/Carburetor
See Filters, Oil filters
Carburettor
Emission Control
http://www.rockauto.com-
<li>PCV Valve: FRAM FV263 $1.73, BECK/ARNLEY 0450031 $2.24
PCV Valve, from $4.00 - $7.50. Available everywhere
Interchange: Infiniti 1993 - 1997 J30 Subaru 1998-2002 FORESTER 2002 IMPREZA
1971 - 1973 1200, 1972 - 1979 620 PICKUP, 1966 - 1970 1600, 1974 - 1977 710 , 1968 - 1970 2000 , 1980 720 PICKUP , 1977 - 1986 200SX , 1983 - 1986 720 PICKUP , 1979 - 1982 210 , 1977 - 1981 810 , 1970 - 1973 240Z , 1974 - 1978 B210 , 1975 - 1977 280Z , 1986 - 1989 D21 PICKUP , 1979 280ZX , 1976 - 1978 F10 , 1990 - 1996 300ZX , 1982 - 1984 MAXIMA , 1979 - 1982 310 , 1987 - 1989 PATHFINDER , 1967 411 , 1983 PULSAR ,, 1968 - 1973 510 , 1983 - 1990 PULSAR NX , 1978 - 1981 510 , 1982 - 1990 SENTRA , 1965 - 1968 520 PICKUP , 1982 - 1986 STANZA , 1969 - 1972 521 PICKUP , 1988 VAN , 1973 - 1976 610
Induction
- TWM Induction
- Weber dual DCOE intake manifold Part Number 8-3122 $569 (looks like oval ports and A12 mounting points)
- AEM
- Fuel systems parts and more
- turbo plumbing
Manifolds
See Inlet manifold, Exhaust manifold
