NOTE: If possible, add new information in the article for the part type. Let's phase out this article.
This is a list of Part Numbers. Note that discontinued (NLA) parts can sometimes be found on eBay or from individual stores (NOS or "New Old Stock"), so adding NLA part numbers to this article is useful.
This article may include links to specialty suppliers, but generally the supplier contact information is in the Parts Sources article. Best to not provide links here, so that we don't have to update the supplier's links in multiple articles.
Maintainence & Tune-Up Parts
See: Parts_Sources#General Tune-up Parts
- Roger's asian auto Parts
- Koni Shocks
- Brake pads
- classicgarage (USA)
Misc Parts
oil cap, gas cap (fuel cap), Fuel Pump , automatic choke bimetal spring, Carb to air cleaner gasket
radiator hoses, fuel hose, vacuum hose, drive belt (fan belt).
Body-Interior
Speedometer cable, Steering Column
Seats
See: Seats
Body Parts
See Body panels
Mirrors
See Mirrors
Sun Visors
See Visors
Rubber parts
See Rubber parts
Front Suspension Parts
McPherson Strut rebuild kit. Strut replacement inserts, Shock absorbers, idler arm, pittman arm, drag link, tie-rod ends
strut inserts -- information on adapting Koni inserts for VW Jetta.
Steering Parts
See Steering System
Rear Suspension Parts
rear leaf springs, shock absorbers, front coil springs
click for extensive list of shock Part Numbers Koni, Monroe, Gabriel, KYB, etc.
KYB is the factory rear shock brand (apparently), so that's good. These came in a black tube.
- Cox Import KYB rear shocks
Performance suspension parts for 1200
- I.T./S.P. LEGAL COIL-OVER SPRING KITS $199 pair
- Road Race Camber/Caster plates (some cutting needed) $265 pair
Also see:
Brakes & Hub
Clutch
<li>Clutch Kit (PLATE KIT,CLU PRESS & DRVN(W/CVR)): BECK/ARNLEY 0619114
$78.89 {
180mm Diameter;7-1/8" Diameter;18 Splines}, ACDELCO 381622 $83.79 DISC SIZE ID: 13/16; SIZE OD: 7 1/8; TEETH: 18T <li>Clutch Release Bearing (release bearing, throwout bearing): BCA 01576 $21.89 {Ball Bearing Bore = 1.5748 Outer Diameter = 2.8898 Width = 0.752} <li>Clutch Slave Cylinder: RAYBESTOS SC37495 $12.44, ACDELCO 18F19 $14.56 <li>pilot bushing <li>Clutch Alignment Tool (wood, plastic or metal)
Centerforce Clutches (USA) http://www.clutchnet.com (USA) lists B210 and 210 parts (which will fit the 1200)
Compare to B210:
B210 clutch cylinder 5/8 inch. Fits:Beck Arnley part number 072-6489
< li>620 Pickup from 1972-3/76 <li>B210 (all models) from 1974-4/75 <li>SPL-311 (1600 or 2000) from 1966-70 <li>510 from 1968-73 (with Nabco master cylinder) <li>610 from 1973-75 (with Nabco master cylinder) <li>710 from 1973-75
Beck Arnley part 072-6521
<li>74-75 B210 <li>76 F10 <li>72-76 <li>620 pickup <li>66-70 SPL-311 1600 <li>68-70 SPL-311 2000 <li>75-78 280Z <li>69-73 510 <li>78-81 510 <li>73-76 610 <li>74-77 710 <li>77-81 810
Cooling System
- <li>Lower radiator hose
21503-H1100 HOSE-RADIATOR,LOWER,FRONT FOR HEATER
21504-H1100 HOSE-RADIATOR,LOWER,REAR FOR HEATER
ACDELCO Parts 20071S & 20070S.
About $13 each from Nissan. About $8 each from
Honda 1994 - 1996 PASSPORT
ISUZU 1989 - 1994 AMIGO, 1992 IMPULSE, 1981 I-MARK, 1981 - 1995 PICKUP, 1985 - 1989 I-MARK, 1991 - 1997 RODEO, 1988 - 1990 IMPULSE, 1984 - 1991 TROOPER
NISSAN , 1971 - 1973 1200 , 1980 - 1986 720 PICKUP , 1977 - 1988 200SX , 1977 - 1981 810 , 1979 - 1982 210 , 1974 - 1978 B210 , 1974 260Z , 1986 - 1989 D21 PICKUP , 1975 - 1978 280Z , 1976 - 1978 F10 , 1979 - 1982 280ZX , 1982 - 1984 MAXIMA , 1979 - 1982 310 , 1987 PATHFINDER , 1971 - 1973 510 , 1983 PULSAR , 1978 - 1981 510 , 1983 - 1989 PULSAR NX , 1971 - 1972 521 PICKUP , 1982 - 1988 SENTRA , 1973 - 1976 610 , 1982 - 1989 STANZA , 1972 - 1979 620 PICKUP , 1987 - 1988 VAN , 1974 - 1977 710
Electrical
<li>Alternator (Stock 35 amp): OE+ AL208 $18.04, BECK/ARNLEY 1860077 $35.79, BOSCH AL231X $54.99 <li>Alternator upgrades: See wiring article <li>Voltage Regulator: Nissan PN 23500-N3300 (same as 70-73 240Z, and 68-73 510) replaced by: 23500-29906 $103 USD (which also replaced 70-72 521 pickup) AIRTEX 1V1250 $18, ACDELCO E661 $40. GP Sorensen 265003 $48 <li>Starter:PN B3343-18005 TIP: Get a Bosch starter instead of the stock Hitachi starter. Or use a Mitsubishi starter from a B310. <li>Brake Stop Light Switch: Beck-Arnley 201-0288. Fits: Mitsubishi 1985, Dodge/Plymouth 1987-1988, Datsun/Nissan 1971-1984,Toyota 1965-1967 <li>Temperature Sending Gauge Switch: beck-arnley 201-0247 fits 1965-1986 Datsun/Nissan. <li>Ignition Coil: beck-arnley 178-8025 fits: Audi, Austin, chevrolet, toyota, etc etc etc. <li>Ignition Starter Switch: ACDELCO E1499A $19.87, BECK/ARNLEY 2011174 $19.91 <li>Key lock: ACDELCO E1495C IGN $24.79 LK W/ 7 TUMBLER LOCK CYLINDER
<li>Distributor- <li>coil ballast resistor: BECK/ARNLEY 1788000 $6.28, ACDELCO E1113, AIRTEX 6R1016 $10.19
<li>Condensor: BOSCH 02135 $3.06, Airtex 5H1015 $6.19, (for rear of dual-point sytem: Airtex 5H1016 $6.12)
<li>Contact Set (Ignition Points): BECK/ARNLEY 1710391 $3.31, BOSCH 01134 $4.49, ACDELCO E179,
Drivetrain
- http://www.rockauto.com** Universal Joint: ACDELCO 45U0008 $16.16
Gearbox Bearings
- Use a general bearing supplier, like CBC Bearings or SKF. They should be able to supply them if you can give them the numbers off the existing bearings, they have them in stock and far less dollars than Nissan. This is one case where buying from Nissan is not economical.
Engine
General Replacement & Repair Parts
- NAPA Auto Parts
Gilmer drive parts, Cast Alloy Dry Sump Oil Pans With Windage Trays, oil filter adapters
Pistons
- Ross Racing pistons in So.California (they're online). $359 without wrist pins and domed for $391 also sans pins
- JE
- Wiseco
Venolia told me on the phone a while back that they would make me any piston I wanted for about $86.00 each but they may be more by now
- Malvern Racing
- JE and Wiseco forged pistons
- HP engineering in Rhode Island. Ph# 401-789-6700.</ul>
- A12 std. Cosworth race pistons with pins (19mm)
- A12 +0.040 Cosworth race pistons with pins (17mm).
- Nissan Competition no longer carries these.
- Datrats is listing A14 oversize Tomei forged pistons
- Wiseco
- A12A +0.040" over is the as the stock A14 pistons
- Nissan
- 76mm race pistons sold by Nissan under the number 12010-A14STD. These are used in the A12A engine when it is bored close to its maximum +0.040 inch overbore.
- PAECO
PISTON RINGS
- Total Seal premium piston rings
- Page 38 of the catalog has the A14 and A12A piston rings listed
- These can be bought from many parts stores
Gaskets
- Nissan: Head gasket set (includes head gasket, rocker cover gasket, intake & exhaust gaskets and thermostat gasket)
- PN 11042-18027 (replaced PN 11042-H1025)
- Nissan GX manifold gaskets
- carb gasket: 16175-A5100
- shield to manifold: 16174-H2300
- Head to manifold : 14035-H2300
- Tomei head and intake/exhaust gasket, GX gaskets, large bore head gaskets
- Pitroad sells A-series gaskets, including 27mm round intake and and 35x29 (GX?) gaskests. See http://www3.ocn.ne.jp/~kyuusya/index-3.htm
Valve Train
- Tomei
- Iskenderian - legendary California hot rod Cam Grinder
- mperdue has an Isky cam
- Crane
- Datrats
- APT
- Malvern Racing
- Yella Terra
See: Parts Sources for current details and contact information for these vendors.
CAMSHAFT
- Crane cams for the A-series engines. No Longer Available. Part# F-22/280-2-10-NC. This cam has [In] .420" and [Ex] .441" of lift.
LIFTERS
- Tomei
PUSHRODS
Recall that pushrods come in two stock lengths:
- short-deck engines (A10, A12, A12A, and late A13)
- tall-deck engines (1974 A13, all A14 and A15)
- Datrats - Custom pushrods made to length from VW pushrods and using the A-series cup. They sit the turned down cup shaft on a ledge in the alloy. Custom made to your length and cheap.
ROLLER PUSHRODS
- Many local speed shops can make custom pushrods
- Yella Terra sold their pushrod tooling to "Head Stud Developments" in Melbourne
- Crow Cams also provide pushrods to customer order, approx. 6.650-6.600 inches long (for A14/A15 subject to your needs) 0.080 wall thickness, Chrome Moly
- Iskenderian Part# 1235L+.50. - custom pushrods for roller rockers (small block Chevy, +0.050 inch length), 8mm (5/16") ball ends
- Isky also sells an adjustable pushrod ("universal" pushrod kit for Chevy smallblock)
ROCKERS
- Nismo 1.52 to 1 ratio rockers
- Malvern Racing - Custom built Roller tipped Aluminum rockers for Nissan A-series
- Yella Terra Roller Rockers - $834-$895 AUD
- Discussion: Yella Terra Roller Rockers
VALVES
- PAECO
- NAPA
VALVE SPRINGS
- wikipedia:BMC A-serie engine use the same valvespring sizes as the Datsun A-series -- partE S-002-8. Approx. $58.81 USD
- Nissan Motorsport competition dual springs with aluminum retainers. These are for high-rpm use with a compatible camshaft.
- Crane (discontinued) part# 902-0002 are a single spring rated at 80 lbs. closed at 1.531" installed height, and 209 lbs. at 1.131".
- Crane Mini springs (for Austin Mini)
- Iskenderian JA-006 inner springs (for dual spring use) are the right diameter but not enough pressure.
Fuel/Air/Carburetor
See Filters, Oil filters
Carburettor
Emission Control
http://www.rockauto.com-
<li>PCV Valve: FRAM FV263 $1.73, BECK/ARNLEY 0450031 $2.24
PCV Valve, from $4.00 - $7.50. Available everywhere
Interchange: Infiniti 1993 - 1997 J30 Subaru 1998-2002 FORESTER 2002 IMPREZA
1971 - 1973 1200, 1972 - 1979 620 PICKUP, 1966 - 1970 1600, 1974 - 1977 710 , 1968 - 1970 2000 , 1980 720 PICKUP , 1977 - 1986 200SX , 1983 - 1986 720 PICKUP , 1979 - 1982 210 , 1977 - 1981 810 , 1970 - 1973 240Z , 1974 - 1978 B210 , 1975 - 1977 280Z , 1986 - 1989 D21 PICKUP , 1979 280ZX , 1976 - 1978 F10 , 1990 - 1996 300ZX , 1982 - 1984 MAXIMA , 1979 - 1982 310 , 1987 - 1989 PATHFINDER , 1967 411 , 1983 PULSAR ,, 1968 - 1973 510 , 1983 - 1990 PULSAR NX , 1978 - 1981 510 , 1982 - 1990 SENTRA , 1965 - 1968 520 PICKUP , 1982 - 1986 STANZA , 1969 - 1972 521 PICKUP , 1988 VAN , 1973 - 1976 610
Induction
- TWM Induction
- Weber dual DCOE intake manifold Part Number 8-3122 $569 (looks like oval ports and A12 mounting points)
- AEM
- Fuel systems parts and more
- turbo plumbing
Manifolds
See Inlet manifold, Exhaust manifold
