Grille
Revision as of 01:42, 12 August 2012; view current revision
Category: Body
Datsun 1200 grilles vary between Coupe and Sedan. The Sedans used a stainless steel grille, while Coupes used a sporty plastic type. Wagons and early utes used the sedan grille, while newer utes use a coupe-like plastic grille. In Japan, the sedan grilles change for 1972.
Stainless: Sedan, Wagon & Pre-1978 ute Grille
1972 Sedan (Facelift) Grille
Coupe Grille (black headlight surrounds)
1978-1989 Ute Grille (silver headlight surrounds)
Late Sunny Truck Grille (1989-2007)
Sunny Excellent Grille
Stainless Grille
See main article: Sedan Grille
Sedan grille "D" and "S" emblems
Late JDM intricate "S" grille emblem
Plastic Grilles
  • Silver headlamp surrounds
    • black center
  • Black headlamp surrounds
    • All black paint
    • All dark gray paint
    • Black paint
      • Silver outline
      • Silver outline + silver center bar
  • Black headlight surrounds: Coupe
  • Silver headlight surrounds: Late Ute (1978-up)
Silver oval with Silver across the middle (all except late GX coupe):
Late GX (1972-1973) - black center:
Early GX:
Transitional GX? - black center, early hood
Late South Africa GX with GL grille (1973 brochure)
Flipped Grille (upside down)
865.jpg GX-5 Coupe grille "winged 'S'" (flying 'S')
Sunny Truck Grille
Early Truck
1971-1977 Sunny Truck, ute and bakkie used the stainless Sedan Grille.
Mid-Model Truck
1978-up Ute. This grille looks nearly identical to the Coupe grille: 16656.jpg
  • Silver headlight surrounds (coupe has black surrounds)
  • Center Badge mounts Horizontal (Coupe is vertical)
Square Headlight Truck
See main article: Square Light Grille
JDM - From October 1989
Bakkie (B140)
Facelift Grille
For 1972, Japan-model 1200s received a minor facelift.
Sedan
Customized Grilles
FRP
Color Matched
  • Coupe-grille with custom insert
GDM Style
Mounting
Each grile type has unique mounting variation.
A plastic grill will not bolt in place of a sedan grille and vice-versa.
Ditto for round vs square headlight grilles.
The four Datsun 1200 grille types and their mount points
See:
  • Sedan Grille Mounting
  • Coupe Grille Mounting
  • Sedan Grille in late Sunny Truck
  • Coupe Grille in late Sunny Truck
    • For a late Sunny Truck with square headlights, you also need to fit round headlights. See Converting
Dimensions
Coupe/Mid-ute/Late-ute
  • 123 x 22 x 10 cm box
Sedan/Early-ute
See Grille Photo Index
keywords: グリル
