A12A
Revision as of 06:19, 16 November 2014; view current revision
Category: A-series Engines
A12A engine (1237cc) was used 1978-1982. It has a 75mm bore, larger than an A12 (1171cc) engine with 73mm bore (NOTE: the A13 Engine used a 76mm bore). The A12A block is virtually identical to the original 1974 A12. The A12A used a casting similar to the A12 and same stroke, but machined with a 75 mm bore (up from 73 mm) for an increase of 66 cc capacity. The A12A shared a common block and crankshaft with the redesigned A12 and A13 engines. Although referred to as "A12" and "1200" in most Datsun literature, it was explicitly stamped 'A12A' on the engine ID pad. In the Japan market both engines were used at the same time, with A12 fitted to B310 wagons and A12A fitted to B310 Sedan & Coupe.
6713.jpg A12A Engine ID Mark
12223.jpg Chassis Plate
Applications
B310
* 1979 'Datsun Sunny 210' B310 Canada
* 1980-1982 'Datsun 210' B310 USA and Canada
* 1977-1980 Datsun Sunny B310 Japan and Asia markets S,K only
  (replaced by the new A13 for 1981/1982)
  Wagon used A12, not A12A
H65 = A12
H85 = A12A
H86 = A13
  • 58 HP
  • 1237 cc (A12 is 1171 cc)
  • 75 mm bore (2mm larger than A12)
  • 70 mm stroke (same as A12)
  • 19.7 mm piston pins (same as A14)
  • New (A14 style) manifold bolt pattern
B310 with A12A - Japan Market sedans & coupes
CYLINDER BLOCK ASSY
11010-H9960 A12A USA 0879-
11010-H8500
* A12A JAP 7712-8010
* A12A CAN 1278-0779
11010-H8502 A12A CAN ^11010-H8500
11010-H9001 A12A CAN 0879- °11010-H8502
Connecting Rods
12100-H8500 B310 A12A/A13S CONNECTING ROD
* for use with 19 mm piston pin (same as A14)
Head Gasket [75 mm bore]
11044-H8501 JAP A12 S,K 7712-8010
Cylinder Head
11041-H8500 JAP A12S.S,K 7712-7909
11041-H8501 JAP A12S.S,K 7910-8010
Piston Set with Pin
12010-H8511 JAP A12S.S,K 7712-7909 STD
12014-H8514 JAP A12S.S,K 7712-7909 OS=0.50
12014-H8516 JAP A12S.S,K 7712-7909 OS=1.00
12010-H8521 JAP A12S.S,K 7910-8010 STD
12010-H8524 JAP A12S.S,K 7910-8010 OS=0.50
12010-H8526 JAP A12S.S,K 7910-8010 OS=1.00
Piston Ring Set
12033-H8500 JAP A12S.S,K 7712-8010 STD
12035-H8500 JAP A12S.S,K 7712-8010 OS=0.50
12037-H8500 JAP A12S.S,K 7712-8010 OS=1.00
Crankshaft
12200-H5001 JAP A12,A12A -7909
12200-H8500 JAP A12,A12A,A13S 7910-
229.jpg 1977.jpg 4444.jpg 4711.jpg 4712.jpg 5522.jpg 5793.jpg 6554.jpg 6713.jpg 8122.jpg 12223.jpg 15171.jpg 15779.jpg 17147.jpg 17148.jpg
Nissan A Engines: Overview | A10 | A12 | A12A | A13, old | A13, new | A14 | A15
