Bluebird
Revision as of 23:48, 25 August 2016; view current revision
Category: Nissan Vehicles
Bluebird is Nissan's C-class (compact) model family, which grew out of the original Datson (DAT Light Car) model, the Datson Type 10 of 1931. For additional details, see History. Bluebird family includes the 210/310/410/510/610/810/910 model series -- but not the 710 which was of the Violet family.
[hide]
th_18a.jpg the original Datson Light Car
The first Datsun to be called Bluebird was the 210 model series, apparently during mid-run.
  • 1957-1959 210 Datsun 1000/Datsun Bluebird 1000
  • 1959-1963 310/311/312 Datsun Bluebird/1000/1200
  • 1963-1967 410/411 Datsun Bluebird/410/411
  • 1967-1973 510 Datsun Bluebird/510/1600,1300,1400
  • 1973-1976 610 Datsun Bluebird/610/180B
  • 1976-1979 810 Datsun Bluebird/810/180B/200B
  • 1980-1983 910 Datsun/Nissan Bluebird/810/Maxima (to 1986 in Australia)
  • 1983 switch to FWD starting with U11 model series Bluebird/Maxima
Bluebirds often feature Independent rear suspension (IRS) starting with the 510 series. 510 wagons are a notable exception, although export 510 sedans may also may have a live axle.
Later models, starting with the G610 and the G810 -- stretched models, may be considered D-class (mid-size) cars.
1958 210 number plate light with 'ダットサン' script ('DATSUN')
th_mkauk09-img600x398-13082772687xupjf86341.jpg th_mkauk09-img600x398-1308277268vsnjiz86341.jpg th_mkauk09-img600x398-1308277269khjvs586341.jpg
1958 Datsun 116 ID Plate
full
310
Datsun Model Series 310
310 1959-1960 Bluebird 1000
311 1961      Bluebird 1200
312 1962-1963 Bluebird 1200
312 1962-1963 Saenara Bluebird
312 1963-1966 Shinjin Shinsungho
    1963-1964 Yue Loong Bluebird 704
310 Indicators are separate from grille
312 - Indicators are wrapped by grille
P models (P310/PL310) were powered by the premium E1 engine (1189 cc "1200")
312 minor change - larger taillights, wider grille, and upright instrument panel
7935.jpgAlbum click to view 8237.jpgAlbum click to view10411.jpgAlbum click to view 10412.jpgAlbum click to view 11392.jpgAlbum click to view 11393.jpgAlbum click to view 11394.jpgAlbum click to view 11395.jpgAlbum click to view 11396.jpgAlbum click to view 11397.jpgAlbum click to view 11398.jpgAlbum click to view 11430.jpgAlbum click to view19841.jpgAlbum click to view 19842.jpgAlbum click to view
13951_4c81bdc888fe5.jpgPost click for topic 13951_4c81bdd8179f9.jpgPost click for topic 13951_4c81bde905db2.jpgPost click for topic
410/411
410 - The first unibody Datsun. Previous series used body-on-frame construction.
* 410: 1964-1965
* 411: 1966-1967
 410 = C1 engine (998cc)
P410 = E1 engine (1189cc)
P411 = J13 engine
R411 = R16 engine
12064.jpg 12065.jpg 12066.jpg 12067.jpg 12068.jpg 12069.jpg 13744.jpg16823.jpg
411 minor change
7245.jpg 5821.jpg 11022.jpg 11023.jpg 23937.jpg 11704.jpg 11705.jpg16822.jpg 10994_49f94ac35f0ce.jpgPost 252859
SS = 410 with E1 (1200) Twin Carb
SS = 411 with J13 Twin Carb
SSS = 411 with R16 Twin Carb
174_5796cceb2fdc3.jpgPost 480140 174_5796ccd43a2f0.jpgPost 480140 Datsun%20SSS%20badge_.jpg Datsun%20SSS%20emblem.jpg
S = Standard
D = Deluxe
F = Fancy
N = automatic clutch
L- = left hand drive
-L = handling package?
R = 2-door sedan
SS = Sport Sedan
SS-R = 2-dr Sport Sedan
U = export
W = Wagon
410 JAPAN Carburetors
C1 = 2-bbl carb
E1 = 2-bbl Hitachi DAB-308-7
E1 = 2-bbl Nikki 2D-30CE <> 2D-30CE-2 Pedal clutch
E1 = 2-bbl Nikki Pedal clutch
E1 = 2-bbl Nikki 2D-30CF <> 2D-30CF-2 Automatic clutch
-K = SS = Twin Carburetor Hitachi HJE38W-1
510
1967-1972 Datsun Bluebird (model series 510)
Also see: 510 Parts Donor
Datsun model series 510 was marketed in Japan as the Bluebird, in America as the 510 and in some countries as 1300/1400/1600 depending on engine (L13, L14 or L16).
 510 1300 L13 engine
N510 1400 L14 engine
P510 1600 L16 engine
H510 1800 L18 engine
 510  4-door Sedan
 510R 2-door Sedan
K510  2-door Coupe (semi-fastback design)
V510  4-door Van (Wagon)
2-door Sedan vs 2-door Coupe
Coupe
4063.jpg 12059.jpg 16063_502d91231ffd1.jpgPost click for topic 16063_502d912ca96b5.jpgPost click for topic 16063_502d913e713d6.jpgPost click for topic
2-door Sedans
4-door Sedans
859.jpg 1043.jpg 1044.jpg 2787.jpg 2789.jpg 2790.jpg 2791.jpg 2793.jpg 2866.jpg 3509.jpg 3797.jpg
CA18-powered 510
16442.jpgAlbum click to view 16443.jpgAlbum click to view 16444.jpgAlbum click to view 16445.jpgAlbum click to view
Wagon
11120_49d951dc586d9.jpgPost click for topic 11120_49d951e490997.jpgPost click for topic 11120_49da8b65a0c5d.jpgPost click for topic 11120_49da8b6fe9c16.jpgPost click for topic
One-off custom 510 Coupe Utility
11120_49d951bd56bba.jpgPost 249936 11120_49d951c88cb93.jpgPost click for topic 11120_49d951ec4034d.jpgPost click for topic
610
The Datsun 610 was the Bluebird model for the 1973-1977 Model years. It was marketed in various countries as:
  • "Datsun 610" (USA)
  • "Datsun Bluebird-U" (Japan)
  • "Datsun 160B" or "Datsun 180B" depending on engine size
See main article: 610
Coupe, Sedan, Wagon
810
Datsun model series 810 was produced 1976-1979. In some countries it was marketed as "Bluebird", in others as "200B" or "180B" or "160B" depending on the engine fitted. Not the same as the 1980-1984 Datsun 810 north america, which is actually model series 910.
Japan         1976-1979 "Bluebird"
North America 1977-1979 "810" and "Maxima"
Australia     1977-1982 "200B"
200B with swapped in FJ20T engine
3796.jpgAlbum 3796
  810 Bluebird 1600
 P810 Bluebird 1800/180B
RG810 Bluebird 2000 G6 L20 six cylinder
HG810 810 L24E engine
Australia "200B" L20B four cylinder
* in GL, SX and GX trim
USA 810/Maxima with L20 six cylinder
810 180B (with swapped-in FJ20 engine)
810 200B
8149.jpg 8150.jpg 8151.jpg 12484.jpgAlbum click to view 12486.jpgAlbum click to view
810 200B SSS
early 810 Bluebird script emblem
910
1980-1986 in Australia
9803.jpg Bluebird badge
13995.jpg SSS
With Z18ET (Japan):
Australia: Bluebird Series I/II 1981-1984 (L20B engine, no IRS, H165)
* Difference between series I and II is most black rubber bumper trim
Bluebird TRX with L20B engine.
* Trim: front air dam, alloy wheels, a small rear spoiler, internal reading lights.etc.
* Rear disc brakes and 15" alloy wheels
Australia: Bluebird Series III/Bluebird TRX 1985-1986 with CA20S engine
910 Europe RHD
L16S
L18S
L18T
Z20E
LD20
16836.jpg 18227.jpg photo  photo  photo  photo
1979 910 BLUEBIRD JAPAN
13x4.5J+40 - non-SSS
14x5J+40   - all SSS models
14x4.5JJ+35 alloy OPTION P910/Y910
Y910   Z20E
P910   Z18E
PJ910  Z18S/Z18P
J910   Z16S
CT     Z16S.F4
DX     Z16S.FR
GL	Z16S.F4
FANCY GL S.Z18S.AT
GF     Z16S.F4, HT.Z18S.F4, S.Z18S.F4/MT
SSS    Z18S (single carburetor),F4/F5/AT
SSS-E  Z18E (EGI fuel injection),F4/F5/AT
SSS-EL Z20E F5/AT
SSS-ES Z20E F5
SSS-EX Z20E F5/AT
SSS-EX G-type Z20E F5/AT
LPG GL/DX/STD S.Z18P.R3W65L/AT
1980 910 BLUEBIRD JAPAN
Y910   Z20E
P910   Z18E/Z18ET
PJ910  Z18S/Z18P
J910   Z16S
EJ910  LD20
WPJ910 AD WAGON Z18S
VTJ910 VAN L16S
VEJ910 VAN LD20
J = LIVE AXLE
Z18ET 135PS@6000rpm, 2.0kg-m@3600RPM
