Remote Clutch Master Cylinder
Revision as of 22:53, 13 January 2017; view current revision
Category: Clutch
A remote-mounted Hydraulic clutch Master cylinder may also be needed if there is not enough room in the engine compartment.
Mount the clutch master inside the passenger compartment -- under the dash -- and connect it to the gearbox slave cylinder via a hydraulic line.
  1. Fabricate L-shaped bracket, bolt (or weld) to the under-dash steering column brace
  2. Lengthen clutch pedal, attach the master rod ABOVE the fulcrum
  3. Place the filler tube under the dash, connect to master via rubber hose
24294.jpgAlbum 24294
Not enough room after a big Engine Swap? Move the clutch master under the dash!
18813.jpgAlbum 18813 18812.jpgAlbum 18812
PIGDOG
18890.jpgAlbum 18890 18891.jpgAlbum 18891 18893.jpgAlbum 18893 19198.jpgAlbum 19198 19199.jpgAlbum 19199 19200.jpgAlbum 19200
Extended pedal
18892.jpgAlbum 18892
Old setup - 2nd pedal box
18894.jpgAlbum 18894 18895.jpgAlbum 18895 18896.jpgAlbum 18896
Girling
Under-dash mounted Girling clay pipe master
Girling "claypipe" master cylinder, available in 5/8" and 3/4" bores (about $70 AUD). Threads are 3/8 unc for pipe outlet and 7/16 unc for fluid in
Urvan
https://en.wikipedia.org/wiki/Nissan_Caravan
  • Use with Nissan Urvan remote-fill tops
  • A simple 90-degree bracket is fabricated to mount it to the under-dash steering column brace
Sentra
http://en.wikipedia.org/wiki/Nissan_Sentra
Nissan Sentra Clutch Master Cylinder
9524.jpgAlbum 9524 9668.jpgAlbum 9668
Fluid reservoir is connected to the cylinder via a rubber hose.
9526.jpgAlbum 9526
Similar to Sentra B15U clutch master 30610-5M007 (top outlet)
Lancer
https://en.wikipedia.org/wiki/Mitsubishi_Lancer_(A70)
For ideas, could something like this be used on a 1200?
Cable-to-Hydraulic custom remote clutch m/c found on Mitsubishi LA Lancer
