Speedometer
Revision as of 09:18, 3 August 2018; view current revision
Speedometers were either in kilometers (JDM) or miles (USA). Australia started with mph and then switched to kph via sticker overlays. Some speedometers had a trip meter.
Template:OwnersManual2
Comparo
2148.jpgAlbum 2148
MPH speedo is also marked in KPH ranges on the very edge, which is partly visible when installed. 13742.jpgAlbum 13742
Also See:
* Cluster Gauge
* Dashboard
Variations
STD bar gauge
STD speedometer was a rectangular type. GL & GX used round gauges. DX varied.
1085.jpgAlbum 1085
Round gauge
24850-H1816 100MPH w/o tripmeter (AUS/USA standard equipment)
10675.jpgAlbum 10675
?? 100MPH with tripmeter
571.gifAlbum 571
1973 5mph marks
24850-H3400 1200 120MPH SPEEDOMETER Includes tripmeter
140 kph
1300060168_177086830_11-DATSUN-SADO-.jpgPost click for topic
160 kph
160 kph late
GX - 180 kph
#Facelift GX - 180 kph
Matsuoka - 240 kph
26445.jpgAlbum 26445
B140 2008
26989.jpgAlbum 26989 174_589e901cb017b.jpgPost 483841
Facelift GX
Gauges changed for the 1972 minor facelift in Japan.
See Main Article: Facelift
22.jpg 21084.jpgAlbum 21084
18701.jpgAlbum click to view 18702.jpgAlbum click to view
Round
24850-H1816 ASSY-SPEEDOMETER 100MILE/H [With 20 mph markings]
24850-H7000 ASSY-SPEEDOMETER 100MILE/H From 7/72 [With 10 mph markings]
24850-H3400 120MPH SPEEDOMETER Includes tripmeter
JDM Sunny Truck
24850-G1670 SPEEDOMETER ASSY 7804- [Round]
Rectangle
JDM Sunny Truck
24850-G1000 SPEEDOMETER ASS'Y (up to '72-6)
24850-G1001 SPEEDOMETER ASS'Y (from '72-7 for speed buzzer) > 24850-G1000
24850-G1002 SPEEDOMETER ASS'Y (from '72-12 for intermittent buzzer) > 24850-G1001
24850-B8600 SPEEDOMETER ASSY 7510-7803 [Rectangle]
JDM Meter Kaku (Bar Gauge)
Through '70 Dec
 24850-H1000 ASS'Y-SPEEDOMETER Std
 24850-H1100 ASS'Y-SPEEDOMETER S-Dx, VDT [Van Super-Deluxe T]
 * with trip meter
From '71 Jan
 24850-H1001 ASS'Y-SPEEDOMETER S-Std
 24850-H1101 ASS'Y-SPEEDOMETER S-Dx
 * with trip meter
 24850-H1410 ASS'Y-SPEEDOMETER VS,VP [Van Standard, Van Deluxe]
 24850-H1401 ASS'Y-SPEEDOMETER VDT
 * with trip meter
H10 ? - all red lamps
8400.jpgAlbum 8400
MPH Rectangle - 0-100 Miles Per Hour
10290_4a2f72d1a2c39.jpgUpload click to view
B86 - Blue H.B. lamp + yellow/red zones
25031.jpgAlbum 25031
KPH+MPH
277_4c0264d7b3d4a.jpgUpload click to view
Metric-Imperial Conversion
Sometimes on eBay Australia you can get the vintage conversion stickers.
923.jpgAlbum click to view 15393.jpgAlbum click to view
OR
Take the face plate and scan it on the flatbad scanner, then modify it. Finally, print a new one out with the photo printer. You can modify the font, colors, etc. Bolt it to the speedo using the standard screws.
5362.jpgAlbum click to view 1101.jpgAlbum click to view
Speedometer Calibration
It is normal for the speedometer to read fast. The specified tolerance is +5% -10%. So at actual 60mph it can read 57 to 66 and still be acceptable. But you can blueprint the speedometer to be closer to the actual speed.
See main article: Speedometer Calibration
Amplifier Speed Switch
1972 Japan, Australia late utes and 1973 USA used a speed switch.
See main article: Instrument_Panel_Wiring#Speed Switch
Alternatives
Possible fit: POST Smith's guage from a Triumph
10754.jpgAlbum 10754
VDO
11799.jpgAlbum 11799
Custom Faces
See main article Custom Dash Faces
Z Speedometer
280Z speedometer fits in the 1200 dash cluster.
  1. Swap the mounting cups as the 280Z unit is deeper
  2. Drill a hole for the trip meter shaft through the back
  3. The face is to large for the opening in the 1200 housing, so carefully reduce the diameter by 1/8 inch
350Z speedometer looks a similar size.
14499.jpgAlbum 14499
Electronic Speedometer
Yes, you can fit an electronic speedometer into a 1200.
See Main Article: Electronic Speedometer
Speedometer Cable
See Main Article: Speedometer Cable
Drive Ratios
See Main Article: Speedometer Gears
Also see:
* Square Dash Photo Index
* Round Dash Photo Index
2192.jpgAlbum click to view 2729.jpgAlbum click to view 5043.jpgAlbum click to view 8881.jpgAlbum click to view 10934.jpgAlbum click to view 10935.jpgAlbum click to view 12944.jpgAlbum click to view 13092.jpgAlbum click to view
スピードメーター
