Wheels
Revision as of 20:47, 25 November 2021; view current revision
Categories: Options | Wheel And Tire
Stock Wheels
  • 12" diameter
  • 4-inch wide
  • bolt-pattern: 4 on 4-1/2 inch circle (4 x 114.3 PCD)
Comparison of B110, B210, B310 wheels
wheelsB10B1101977 US B210 A141980 NA B310
size3-1/2 J-124 J-124-1/2 J-134-1/2 J-13
5 J-13 (aluminum)
Canada w/A12A: 4J-12
offset?30 mm30mm offset30mm
25 mm (aluminum)
tire size?-126.00-12
155SR-12
155SR-136.00-12
155SR13
175/70SR13
balance10gr or less (0.35 oz)11gr or less10gr or less
lugnut torque  8-9kg-m (58-65 ft-lb)8-9kg-m8-10
13" Wheels
Most 13" Datsun steel wheels fit the 1200, for example, 510, 610, B210 however the B310 13" wheels do not clear the front brake calipers.
A particularly stock-looking choice is 510/1600 13" wheels with 510 hubcaps
The 510 has narrow wheels and look very stock on a 1000 or a 1200.
13x5.5" custom-widened wheels
20201.jpgAlbum 20201
Datsun Option Wheels
20474.jpg#B 25653.jpg#C
23907.jpgAlbum 23907
Options
23743.jpgAlbum 23743
40300-N5825 WHEEL SET-ROAD ALUMINIUM, B TYPE (5JX13)
40300-W6625 WHEEL SET-ROAD ALUMINIUM, C TYPE (5JX13)
40300-R4625 WHEEL SET-ROAD ALUMINIUM, A TYPE (5.5JX14)
A-type 14"
Also used on 200SX (S10 silvia) 1977-1979
23740.jpgAlbum 23740
Option B Wheel
20474.jpgAlbum 20474 174_5d8b3f4024db5.jpgPost 492697
Fits the 1200 just fine (offset +25)
10023.jpgAlbum 10023
First offered Feb 1976 for the GB211
26985.jpgAlbum 26985 6420_5a30d63a10074.jpgPost 486918
26917.jpgAlbum 26917 IMAG0603-x.jpg IMAG0603.jpg ffa54711ed.jpg 174_5d8b3f52c1906.jpgPost 492697
Option C Wheel
25653.jpgAlbum 25653 23889.jpgAlbum 23889 174_5aee35f9357a9.jpgPost 488241 174_5aee3632d1c3c.jpgPost 488241
New Zealand
Datsun dealer-installed option mag wheels
28048.jpgAlbum 28048
B310 Wheels
40300-W8300 WHEEL ASSY-ROAD(4 1/2-JX13) (STYLED) 0879-
22111.jpgAlbum 22111
with 'D' center caps 40343-H5710
NOTE: B310 13" wheels do not fit the B110 front hubs due to the shape of the wheel, particularly the deep well hits the B110 brake caliper.
ホイール
Sunny 1200 Race Wheels
Sports Options Catalog | Sports Options Parts
Race Road Wheel Parts
1 40300-H5021 ROAD WHEEL FR 8Kx14 inch
  40300-H5020 ROAD WHEEL FR 9Kx14 inch
  40397-N3120 SPACER-Safety Bolt (16)
  40398-N3120 SEAL-Rubber (16)
2 40399-H50?? BOLT-Safety (16)
3 40209-A0220 SPACER-Road Wheel (4) for aluminum, t=5
4 40222-A0220 BOLT-Wheel FR (8) M12 x 1.25 x 50
5 40223-A0220 BOLT-Wheel RR (8) M12 x 1.25 x 50
6 40224-H5020 NUT-Wheel (16) (Taper)
7 40224-E7210 NUT-Wheel (16) (Taper) Chrome-plated cap nut
Japanese web page
This is 4-spoke 14-inch. Aluminum alloy instead of the magnesium, size 8J and 9J.
26584.jpgAlbum 26584 26583.jpgAlbum 26583
Lug Nuts
M12x1.25 thread
  • B110: Nuts are 19mm hex head (~3/4 inch)
  • B210: 13/16" lug nuts
See main article Wheel Studs
Torque
  • 8.0-9.0 kg/m (58-65 ft-lb)
Wheel Balance
  • Maximum allowable unbalance at rim flange: 10 gr (0.35 oz)
  • Tire balancing weight: 10-70 gr (0.35-2.47 oz), spacing 10 gr (0.35 oz)
Also See: Vibration
Wheel Offset
STOCK = 30 mm offset
* Choosing Wheel Offset for wide tires
* Selecting compatible FWD Wheels
* Measuring Offset
* Offset size that work with stock bodywork
Scrub Radius
scrub radius. its the distance from the centre of the tyre contact patch to where SAI intersects the ground.
'+' scrub radius where the centre of tyre contact patch is outside SAI, '-' where its inside the SAI.
Largest Sizes to Fit 1200
  • Front: 3.25" is the maximum backspace (which is used by the stock 4" wheel). So if going wider, the Offset must be reduced from +30.
  • Rear: +30 Offset works best with Datsun 1200, allowing the largest width tyres (205-width tyres).
18s
3813_4f08c26a89195.jpgUpload click to view
16"
4130.jpgAlbum 4130
  • 4": B110 12" stockers are 4" wide with +30 offset
  • 4.5": B310 13" +30 stockers won't fit the front of the 1200. They hit the brake calipers, which may be related to the shape of the wheel.
  • 5.5": Most with appropriate offset will fit a Datsun 1200. 15mm offset wheels fit nicely under the front guards, but look anemic on the rear.
  • 6-inch wide wheels: most will not fit, but a zero offset will.
  • 6.5": the biggest 15s you can put on are +24 15x6.5 even then they stick out a couple of mm past the fenders
  • 6.5" 16s with a 40mm offset (silvia wheels or R32 skyline stock rims fit this). These wheels are the limit, I have 195/45 R16 on it and they sit within the guard and don't rub anything....but the front of the guard has been altered.
  • 7" Reportedly 13x7 +0 fits perfectly
  • 7" wide wheels with offset of +10 require front guards modification (they will rub on the fenders). At full lock -- depending on the tires -- the fronts will probably scrub inside the guards
  • 7" 14s with 0 offset sit flush with the rear and poke a little on the front. More positive offset bring them inside, but then you risk hitting the struts
  • 7": 15s +10 offset on fronts and +2 offset on rears. Tires rub a little at full lock. With pumped guards with possibly 15x7 -2 offset would work better.
  • 7": I have 14x7 on my 1200. With zero offset. It is a tight fit with stretched tires. Mine have 175/60R14 tires, so obviously they are stretched over the 7 inch wide rim.
    19322.jpgAlbum 19322
IMPORTANT
Height has little to do with your wheel, but
more to do with the tire. See Tires
a 195-width tire will fit if
small enough diameter (e.g. 195-50R15)
You may need to roll the fender.
983.jpgAlbum 983
22878.jpgAlbum 22878
Rear
  • 7": 13x7 with 0 offset and they fill the gaurds perfectly. The tire will be under the guard lip, and will rub if the 1200 is lowered unless the tires are very small diameter.
  • 8.5": 13" -15 with 175/60R13
  • 9": 13 x 9 zero offset, tire 215/50r13
    11064_4c984cf20979d.jpgUpload click to view
Ute Rear
Weights
Stock Datsun 1200 Wheels (12 x 4) weigh 11 pounds each. Virtually all aftermarket alloy wheels are heavier, except for very expensive magnesium wheels.
See main article: Wheel Weights
Wheel Adapters
Wheel Spacers
See main article: Wheel Spacers
If the wheel offset is too negative, they will fit the fenders (guards) and there is nothing you can do except cut out the bodywork, perhaps fitting large flares.
re-drilled axle flange
10064.jpgAlbum 10064
Suppliers
See Rims
Aftermarket Wheels
See Rims
Compatible Wheels
71mm center hub
Many RWD 4-lug on 4.5 inch bolt centers fit. These are equivalent to "114.3 PCD" in metric conversion terms.
What WONT work:
  • early Honda
  • Isuzu/Holden Gemini
  • Ford Escort/Cortina
  • early Mazda
  • Subaru
  • some SAAB
  • Ford Escort/Pinto/Mustang II/Mustang Fox 4-on-4.25 (PCD 4x108 mm)
  • Chevrolet Vega/Monza 4-on-4" (PCD 4x101.6 mm)
FWD Rims
FWD rims are typically a high offset (+35 or more), and may require a spacer if used on a 1200. Stock 1200 wheels are +30, however if going wider than the stock 4" wide, less offset may be required.
  • Acura Legend 1986-1990 (15x6", 64.1 center hole)
  • Acura Vigor 1991-1994
  • Acura TC 1992-1995
  • Acura TL 2.5 1995- (15x6", 64.1 center hole)
  • Acura CL 2.2/3.0 1995- (15x6", 64.1 center hole)
  • Chevrolet Sprint 1988-1989 (12x4, 10mm studs, 59.6 center)
  • Ford Festiva 1987-1993 (12x4)
  • Ford Laser (KA to KH)
  • Geo Metro 1989-1997 (12x4, 10mm studs, 59.6 center)
  • Honda Accord 1990- (14x6, 15x6, 64.1 center)
  • Hyundai Excel
  • Kia 2001- (67.1 center)
  • SAAB 99 1968-1980 (5.5 inch wide, needs spacer)
  • SAAB 900, 900 Turbo 1979-1987 (needs spacer)
  • Suzuki 1989- including Swift, Aerio, Verona, Reno, Forenza
  • Volvo 40-series 1998- including 15x6 (centers need boring out to 70mm)
Saab Wheels
15358.jpgAlbum 15358
Saab Silvervane rims
1820.jpgAlbum 1820
  • Offset: 40 or 45 mm
  • 1979-1983 SAAB 900
  • 1984-1987 SAAB 900, 900 Turbo (6" wide, needs spacer) 71.5 centers
13360.jpgAlbum 13360
Sigma Rims
Australia
* Chrysler Sigma 1978-1980
* Mitsubishi Sigma from 1981
1977-1980 #GE Sigma SE 14x5.5 with 195/65R14
400px-1979-1980_Chrysler_Sigma_%28GE%29_SE_sedan_%282008-12-19%29.jpg 17663.jpg
1982 GH #Sigma Turbo rims 15 x 6 inch
1984-1985 GK Sigma SE 14X6JJ
400px-1984-1985_Mitsubishi_Sigma_%28GK%29_SE_sedan_%282010-12-28%29_01.jpgWIKI go to Wikipedia 11886.jpgAlbum 11886
GE Sigma SE
  • 1977-1980 Australia GE Sigma SE
  • 1976-1979 Japan Galant Lamba
  • 1978-1983 USA Plymouth Sapporo
sapporomp8.9112.jpg 400px-1979-1980_Chrysler_Sigma_%28GE%29_SE_sedan_%282008-12-19%29.jpgWIKI go to Wikipedia
11_4a88ad6f18fec.jpgPost 271115 17663.jpgAlbum 17663
Sigma Turbo
1982 GH Sigma Turbo rims 15 x 6 inch 4x114.3 (Sigma Turbo was a limited run on 500 cars)
400px-Mitsubishi_Sigma_GH_Turbo_%2815874799410%29.jpgWIKI go to Wikipedia 7843.jpgAlbum 7843 19357.jpgAlbum 19357 9725_49eac9709c097.jpgUpload click to view 3914.jpgAlbum 3914 3917.jpgAlbum 3917 4162.jpgAlbum 4162 3440.jpgAlbum 3440
Toyota
All Corolla RWD rims are candidates for Datsun 1200, as are all Celica RWD (including Supra).
16187_4f27019bf0993.jpg 6869.jpg 20748.jpg 15685.jpg 116A80E1-C99E-4E4D-872E-1B26DACE33DA.jpg
Nissan-Datsun Wheels
See Main Article: Nissan wheels
Bakkie Deluxe Wheels
B140 Champ with deluxe option wheels
16852.jpgAlbum 16852
Bakkie White-spoke Wheels
B140 Champ wheels (trail duster style aka white-spoke steels)
Factory Champ rims on 1200 GX
A-LINE "Spoke White" of the Steel Outback Range (8-spoke)
29bbz3p.jpgPost click for topic 2zibv9w.jpgPost click for topic
18079.jpgAlbum 18079 20028.jpgAlbum 20028 14894.jpgAlbum 14894 7443.jpgAlbum 7443
