H145
Revision as of 06:08, 28 May 2025; view current revision
Datsun 1200 cars (sedan/coupe/wagon) use an H145 differential in the Rear Axle Assembly. The B120 Datsun 1200 pickup uses the larger H165 diff.
ID
H145 has 8-stud removable center. H150 and H165 also use 8 bolts. But only the H145 is 8-stud (the others use bolts).
NOTE: Aussie-built B110 sedans with a non-removable diff center use the BW60 diff.
Differential
Flange
174_5a58324e15d6b.jpgPost 487206
H150: 45 x 54 mm round or rectangular flange
There are some differences between flanges on H165's, some long (~217.5mm from carrier mounting face to driveshaft flange face), some short (~202.5mm). Depth of hole for centering boss varies also.
Size
Measure the gear
25277.jpgAlbum 25277
H145 measures 145mm
H150 measures 150mm
H165 measures 165mm
H190 measures 190mm
Pre-1980
  B10: H145, 3.900
 VB10: H145, 4.375 (van/wagon)
  B20: H145, 4.375 S.T.D. / 4.625 Optional (ute/pick-up)
 B110: H145 3.900
VB110: H145 4.111 (van/wagon)
PB110: H165 4.111
 B120: H165 4.111 (ute/truck)
 B210 1974: H145 3.900
 B210 1975-up: H150 3.700 or 3.889
PB210: H165
GB211: H165
 B310: H150 various
  A10: H165 various
1980-up
Axle Codes
H = Hitachi removable gear carrier (pumpkin/centre section)
HA - H145 (145mm diameter ring gear, 5.709 inch)
HB - H150 (150mm diameter ring gear, 5.906 inch)
HC - H165 (165mm diameter ring gear, 6.496 inch)
HD - H190 (190mm diameter ring gear, 7.480 inch) ALUMINUM CARRIER
HE - H190 CAST IRON CARRIER
HF - H190A revised for strength
21048.jpgAlbum 21048
Counting
24439.jpgAlbum 24439
39 divided by 11 = 3.545 ratio
25276.jpgAlbum 25276
Pinion gear is similarly stamped
25278.jpgAlbum 25278
Differential Repair
Replacing diff bearings or spider gears? Or Ring & Pinion (CWP)? The procedure for re-assembly of the differential gear carrier is very complicated. Be sure to get the factory service manual.
14120.jpg#FSM
We recommend: Just swap the whole center section "pumpkin" from a 1970-1973 B110 or 1974 B210 into the housing. It will be cheaper and certainly easier, someone has one for free. The center section rarely goes bad unless the diff runs low on oil, so your chances are very high of getting a good used one.
16206.jpgAlbum 16206
Yes, B110 and 1974 B210 center section is identical. You could also swap a 1975-1978 pumpkin, using a 2mm spacer between the pumpkin and the housing, or use three gaskets.
When buying a used center section, check the play in the pinion:
Backlash between ring gear and drive pinion
H145: 0.10 to 0.15 mm
R160: 0.1 to 0.2 mm
H165: 0.13 to 0.18 mm
H190: 0.15 to 0.20 mm
Gear Sets
B110 3.90 Datsun 1200 1970-1973 Sedan & Coupe
B110 4.11 Van (wagon)
B120 - see H165
B10 4.111 Datsun 1000 1967-1970 37:9
B10 4.375 van (VB10) with alloy carrier 35:8
B20 4.625 truck (ute) 37:8
B210 3.90 -7409 (North America & Japan) [39:10]
B210 7409- see H150
Datsun Competition (later Nismo) used to sell every factory H145 ratio: 3.9, 4.111, 4.375, 4.625. See #Nissan Competition section below.
145mm ring gear diameter
174_68329695df119.jpgPost 498965 174_683296888c946.jpgPost 498965
pinion installation marks: set number 'G8608' and head number '-5' (varies for each pinion)
174_6832968fa023c.jpgPost 498965 174_683296a39954f.jpgPost 498965
Ring Gear (crown wheel) marks '39-10 CN 47 5' 39/10 = 3.90 ratio
174_683296a9b3e84.jpgPost 498965
mark '39-10 BX4.5 8'
174_683296b690011.jpgPost 498965
174_683693b96d074.jpgPost 498966
Pinion is marked to match the ring gear. This one is '37 . 9' (37/9=4.111)
174_6836938eadda2.jpgPost 498966
Gear Carrier
H145A features a cast iron gear carrier. The original H145 was the #Alloy Gear Carrier used by the B110 Datsun 1000.
174_68329647d2b8e.jpgPost 498965 174_6832968125cd9.jpgPost 498965
This carrier has been fitted for a Differential Oil Cooler
174_683693f2450e3.jpgPost 498966 174_6836a33d1491b.jpgPost 498966
174_683693ebae7d8.jpgPost 498966
Alloy Gear Carrier
The alloy carrier is weaker (less able to handle the torque) but is lighter so giving a superior ride over the normal cast iron carrier.
B10 4.111 sedan & coupe
B10 4.375 van
B20 4.625 truck
174_5a5718154210c.jpgPost 487200
Using in H150 Housing
Say you have a race-prepped H145 diff center ... can you use it in the H150 housing of your B210 or B310? Yes. I imagine this procedure was created because of the success of the B110 in racing leading to a ready supply of TS-class racing parts.
  • mill the H150 housing flange to remove 2mm
  • use a B110 driveshaft, so that the length and flange matches
How to use the H145 type
If you process the mounting surface of the #H145 type carrier (38310-G0400) to the rear axle case as shown below, you can use the H145 type with the B310 standard rear axle case (for the H150 type).
30385.jpgAlbum 30385
Processing for the H145 type gear carrier
[from centerline of side bearing to the carrier flange]
 35 ±0.05
(33 ±0.05)
[Note] ( ) indicates the dimensions of the H145 type carrier.
Cut the hatched area [of the Gear Carrier].
2mm shaved from flange of gear carrier (step is 6mm)
30386.jpgAlbum 30386
B310 rear axle
Flange
Pinion bolt-on companion flange for the Propeller Shaft
174_6836936d76568.jpgPost 498966
Parts
22378.jpgAlbum 22378
Suppliers - USA
38424-18002 WASHER-THRUST SIDE GEAR T=0.86 MM
26305.jpgAlbum 26305
Ring & Pinion
JDM B10 Datsun 1000 H145 gear sets (will fit all Datsun 1200)
38100-18000 SET-GEAR, hypoid with pinion (37 T: 9 T) [4.11] Sedan & Coupe
38100-H0700 SET-GEAR, hypoid with pinion (35 T: 8 T) [4.375] Van
* superceded 38100-18100
38100-15400 SET-GEAR, hypoid with pinion (37 T: 8 T) [4.625] Truck
38100-G0400 SET-GEAR, hypoid with pinion (37 T: 8 T) [4.625] Truck (from '69-Nov)
Datsun 1200 gear sets
38100-H1000 3.900 R&P SET Sedan & Coupe
38100-H1100 4.111 R&P SET Van
Differential
Differential Side Bearing
O.D: 62mm
38440-H1000 ASSY-BEARING DIFF SIDE (2 needed)
* replaces 38440-18000 ASSY-BEARING DIFF SIDE
* SKF BR30206 $22 USD
SKF BR30206 specifications
Tapered Bearing Cup & Cone Set
* I. D. 30mm     (1.181")
* O. D. 62mm     (2.441")
* Width 17.25 mm (0.679")
* HGM Liftparts, $9.36
* NSK HR30206J
* KOYO 30206JR
* NTN 30206
Nachi E30206J
* SKF BR30206 $16.99
* National Bearing 30206
* BCA 30206 $29.99
* Motor City S30206 $9.88
* TIMKEN Part # 30206M  $14.96
* BCA/NATIONAL Part # 30206  $16.74
30206
Application:
Alfa
Mitsubishi
Ford
Mazda
Nissan
Plymouth
Porsche
Subaru
Pinion Crush Sleeve
The Pinion gear bearing spacer (crush sleeve) is NLA. See the main article for alternatives.
174_683693c8946fe.jpgPost 498966
Pinion Seal
B110, through 1974 model year B210 (H145). Probably fits B10 as well.
38189-18000 SEAL-OIL DRIVE PINION
SKF Oil Seal #550219 $22.99
Pinion Bearing
Rear
Rear pinion bearing
174_6836936457970.jpgPost 498966
38120-18000 ASSY-BEARING DRIVE PINION REAR
* SKF BR32206
* NSK HR 32206C 62x30x21.25mm
SKF BR32206 specifications
* Width 21.26 mm (0.837")
Fits many cars, GM, Nissan, Isuzu, Mazda, Opel, etc.
Rockauto
* BCA/NATIONAL Part # 32206 $19.84
* SKF BR32206 $18.99
Front
38140-18000 ASSY-BEARING DRIVE PINION FRONT
* Koyo 303/22X
* NSK HR303/22CNF
NSK HR303/22CNF specifications
Radial Taper Roller Bearing
* I. D. 22 mm (0.866")
* O. D. 56 mm (2.205")
* Width 17 mm (0.669")
Timken HM88649H
Shims
Also need these:
* 38165-H1001 SPACER-DRIVE PINION BEARING $17.00
* 38154-G04xx WASHER-ADJUSTING DRIVE PINION $3.83 USD
Where xx = 00 through 17 for different thicknesses
* 38154-G0400 WASHER-ADJUSTING DRIVE PINION T=2.74
* 38154-G0401 WASHER-ADJUSTING DRIVE PINION T=2.77
* 38154-G0402 WASHER-ADJUSTING DRIVE PINION T=2.80
* 38154-G0403 WASHER-ADJUSTING DRIVE PINION T=2.83
* 38154-G0404 WASHER-ADJUSTING DRIVE PINION T=2.86
* 38154-G0405 WASHER-ADJUSTING DRIVE PINION T=2.89
* 38154-G0406 WASHER-ADJUSTING DRIVE PINION T=2.92
* 38154-G0407 WASHER-ADJUSTING DRIVE PINION T=2.95
* 38154-G0408 WASHER-ADJUSTING DRIVE PINION T=2.98
* 38154-G0409 WASHER-ADJUSTING DRIVE PINION T=3.01
* 38154-G0410 WASHER-ADJUSTING DRIVE PINION T=3.04
* 38154-G0411 WASHER-ADJUSTING DRIVE PINION T=3.07
* 38154-G0412 WASHER-ADJUSTING DRIVE PINION T=3.10
* 38154-G0413 WASHER-ADJUSTING DRIVE PINION T=3.13
* 38154-G0414 WASHER-ADJUSTING DRIVE PINION T=3.16
* 38154-G0415 WASHER-ADJUSTING DRIVE PINION T=3.19
* 38154-G0416 WASHER-ADJUSTING DRIVE PINION T=3.22
* 38154-G0417 WASHER-ADJUSTING DRIVE PINION T=3.25
38154-G0410 | 38154-G0403
Diff%20Adjusting%20Drive%20Pinion%20Shim%20(38154-G0410).jpg Diff%20Adjusting%20Drive%20Pinion%20Shim%20(38154-G0403).jpg
Nissan Competition
From the 1984 Nissan Competition Catalog
H145A RING & PINION SET (TO 8/74)
* 38100-H1000 3.900 R&P SET
* 38100-H1100 4.111 R&P SET
* 38100-H0700 4.375 R&P SET
* 38100-G0400 4.625 R&P SET
H145A LIMITED-SLIP ASSY (TO 8/74)
H145A DIFFERENTIAL ASSY
The H145A 3rd members will fit the 1200 and B210 (to 8/74)
and do not include limited slip units.
* 38300-H1000 3.900 3RD MEMBER
* 38300-H1100 4.111 3RD MEMBER
* 38300-H0700 4.375 3RD MEMBER
* 38300-G0500 4.625 3RD MEMBER
H145A AXLE BAFFLES
Differential Oil Cooler Assy
Damage
H145 damaged when being used by a potent A12 engine: POST Chris's Rip Snorter A12 & Red B10
22764.jpgAlbum 22764 22765.jpgAlbum 22765 22766.jpgAlbum 22766 22767.jpgAlbum 22767 22768.jpgAlbum 22768 22769.jpgAlbum 22769 22770.jpgAlbum 22770
