Datsun 1200 grilles vary between Coupe and Sedan. The Sedans used a stainless steel grille, while Coupes used a sporty plastic type. Wagons and early utes used the sedan grille, while newer utes use a coupe-like plastic grille. In Japan, the grilles changed for 1972.
Stainless: Sedan & Pre-1978 ute Grille
1972 Sedan (Facelift) Grille
Coupe Grille (black headlight surrounds)
1978-1989 Ute Grille (silver headlight surrounds)
Late Sunny Truck Grille (1989-2007)
Sedan Grille
See main article: Sedan Grille
Sedan grille "D" and "S" emblems
Late JDM intricate "S" grille emblem
Coupe-type Grilles
- Silver headlamp surrounds
- black center
- Black headlamp surrounds
- All black paint
- All dark gray paint
- Black paint
- Silver outline
- Silver outline + silver center bar
- Black headlight surrounds: Coupe
- Silver headlight surrounds: Late Ute (1978-up)
Silver oval with Silver across the middle (all except late GX coupe):
Late GX (1972-1973) - black center:
Transitional GX? - black center, early hood
Late South Africa GX with GL grille (1973 brochure)
GX-5 Coupe grille "winged 'S'" (flying 'S')
Sunny Truck Grille
Early Truck
1971-1977 Sunny Truck, ute and bakkie used the stainless Sedan Grille.
Mid-Model Truck
1978-up Ute. This grille looks nearly identical to the Coupe grille:
- Silver headlight surrounds (coupe has black surrounds)
- Center Badge mounts Horizontal (Coupe is vertical)
Square Headlight Truck
JDM - From October 1989
Bakkie B140
Installing Round Headlights in Late Truck
http://kurumayayou.cocolog-nifty.com/tokyokodairacity/2009/04/post-8da8.html
Customized Grilles
Color Matched
- Coupe-grille with custom insert
keywords: グリル
