Chassis numbers
Revision as of 01:34, 20 February 2012; view current revision
Category: General Information
The B110 chassis number is stamped on the cowl and on the engine-compartment plate.
See Nissan chassis codes for explanation of model numbers.
Engine numbers should match the Plate. Engine numbers are here (right side of block, near back just under cylinder head):
  • 770.jpg A1216699.jpg A14
1980-up ID Plate
Oct 1980 (Japan) and 1981 Model year (USA) changed to a more detailed plate:
L-: L-level emissions (1981 Oct - 1989 Oct)
G: Long Wheelbase
Model: B122 Sunny Truck
T: 4-speed
Color: 002 White
トリム Trim: C
Engine: A12 gasoline engine
S: Single carburetor
Axle: HC41 H165 4.10 ratio
Plant 4: Aichi Machine
Australia
12779.jpg ADR compliance plate
12780.jpg B120
Mod Plate
Caution Plate コーション プレート
Japan badges list:
GX 83 HP
  • Horsepower: 83 PS
  • Torque: 7.1 Newton Meters
B120
Torque 8.4.That can't be right!
GB122
Thailand
New Zealand
Nissan Motor Distributors (N.Z.) Ltd.
In addition to regular Nissan plates, Land Transport NZ (formerly Land Transport Safety Authority) may add a "Low Volume Vehicle Certification Plate":
Brought to you by the Low Volume Vehicle Technical Association
Warranty Of Fitness (W.O.F.)
South Africa
11952.jpg 140Z
USA & Canada
1971 quench chamber cylinder head
69 HP: 9233.jpg
1972-1973 open chamber cylinder head
68 HP: 12220.jpg
USA Ratings:
  • Horsepower: 68 or 69 SAE
  • Torque: Not listed
For an explanation of SAE and why some are 68, others are 69, see: Performance.
Also see:
  • Tune-up/Dyno sticker
FMVSS Build Plate
In addition to the Nissan chassis numbers, USA models have an FMVSS build plate:
Color Number
For details, see: Colors
Custom Plates
Serial Numbers
JDM Catalog 11/1971
  • Sedan: From B110-226985
  • Coupe: From B110-877228
Maybe this is the serial numbers where 3N71B automatic was first introduced. Translation is difficult
USA Catalog
  • U = United States models
  • N = Canada models. Also some U models were sold in Canada.
  • A = Automatic transmission-equipped models
Reference: Datsun 1200 USA & Canada Parts Catalog Model B110 Series (C-0030U), 4th Overall Revision, December 1973
1200 Coupe
  • KLB110TU
  • KLB110TN
  • KLB110AU
ZFrom (L)B110-764205From Apr-71
ZFrom LB110-640001From Jan-72
ZFrom LB110-477893From Jun-72
FFrom (L)B110-877228From Apr-71
FFrom (L)B110-940001From Jan-72
FFrom LB110-975540From Jul-72
[I'm guessing the "Z" means the Zama plant, and "F" means the Fuji Heavy Industries plant. This fits because only some Coupe models were marked F, while all sedans were built at the Zama plant.]
1200 2-Door Sedan
  • LB110TRU
  • LB110TRN
  • LB110ARU
ZFrom (L)B110-247023From Apr-71
ZFrom (L)LB110-341001From Jan-72
Vehicle Identification Number
Starting in 1980, Datsuns were marked with an international-standard 17-digit VIN number.
See main article: VIN
Engine
770.jpg A12 Engine ID Mark
16699.jpg Early A14 Engine ID Mark
17147.jpg A12A Engine ID Mark
18238.jpg A15 Engine ID Mark (also newer A14)
Transmission
Manual transmission number
1882.jpg 9233.jpg1947.jpg 11952.jpg 12223.jpg12224.jpg 12225.jpg 18183.jpg 20010.jpg
20016.jpg C22 Vannette
8463.jpg KB10 Plate
