Badges
Revision as of 00:06, 11 June 2015; view current revision
Category: Body
Datsun 1200s came with several badges (emblems). The original 1200 badges were metal, but the new ones -- genuine Nissan items -- are a high-quality plastic that looks very good. Aftermarket reproduction badges vary in quality from poor to very good.
Genuine Nissan badges are metal or plastic depending on the year made.
2200.jpg Various early B110 Sunny Emblems (Japan)
1972 JDM Facelift emblems
Market Differences
  • Japan market 1200s used "Sunny" & "S" badges
  • Export market 1200 used "Datsun", "D" badges
Colors
Most badges, especially the script ones, are simple silver color.
Sedan "S" and "D" grille emblems have red and blue bars:
Coupe "S" and "D" round emblems have tricolor red, white and blue pie sections:
Some are faded after all this time:
Most are faded to no color after 40 years:
Coupe
See main article: Coupe Badges
Sedan
10248.jpg South Africa GX badges
Grille
Center Ornament
Early center ornament 62312-H1626 ('D') and 62312-H1026 ('S')
Facelift grille 62312-H3125 ornament Late JDM intricate "S"
62312-H3100 cast mark
752.jpg 22828.jpg 7522.jpg 13057.jpg 23190.jpg th_bfsjq597-img600x450-1293012459v70sxm12525.jpg th_S_badge_reverse.jpg th_bfsjq597-img600x450-1293012459yvrlgd12525.jpg th_bfsjq597-img600x450-1293012459er55u512525.jpg
Grille Left Side Badge
NOTE: there are 3 types of GX badges:
 top: early GX grille
 middle: 1972 GX grille
 bottom: GX rear (see through script)
EARLY LEFT SIDE GRILLE
FACELIFT LEFT SIDE GRILLE BADGES
62330-H3125 EMBLEM SET-radiator grille "DELUXE"
7522.jpg compare to rear badge 22513.jpg 84823-H1000
62330-H2026 GL
th_gl-GRILLE-badge.jpg 20864.jpg screw-on type. Rear GL badge is push-in type.
62330-H3325 EMBLEM SET-radiator grille "GL"
th_GL-Sedan-grille-1972.jpg th_GL-Sedan-grille-1972-reverse.jpg compare to early rectangular badge 20864.jpg
GL_grille_badge.jpg th_62330-H3300.jpg th_62330-H3300_.jpg cast mark "62330-H3300"
62330-H2325 GX
th_GX-grille-badge-2.jpg th_GX-grille-badge-1.jpg th_yunakiti-img600x450-1277628693ok47g777311.jpg th_yunakiti-img600x450-1277628693ybadxo77311.jpg th_yunakiti-img600x450-1277628693qqw7ym77311.jpg th_62330-H2225.jpg th_62330-H2225_reverse.jpg 18053.jpg
62330-H3425 EMBLEM SET-radiator grille "GX"
25658.jpg compare to early wide badge 18053.jpg or rear see-through badge th_gx_emblem.jpg
62330-H7225 EMBLEM SET-radiator grille "GX 5 SPEED"
th_62330-H7225.jpg compare to rear badge 25659.jpg 84823-H7200
Side
Rear Quarter
C-pillar Emblem
C-pillar Deluxe
C-pillar GL
23133.jpg th_m73760119scoresnewyork-img600x450-1264925423zpizbt91579.jpg th_m73760119scoresnewyork-img600x450-1264925429gqm2ek91663.jpg th_GL-c_pillar_badge_reverse.jpg
C-pillar GX
Rear
Model
Sunny 1200 - Right Rear
Datsun 1200 - Right Rear
21715.jpg 15650.jpg 16745.jpg 19425.jpg 24319.jpg 12129.jpg th_datsun_1200_emblem_1_73.jpg
Left Rear Sunny - UK???
Trim
Left Rear
Left Rear Deluxe - differs from similar looking front facelift badge
Left Rear GL - 84823-H2001 early
Left Rear GL - 1972 - 84823-H3300
non-1200 GL
Left Rear GX "see-through" script (compare to front GX badges which have a background attached)
25662.jpg 9930.jpg 23911.jpg 23912.jpg 23913.jpg 23914.jpg th_gx_emblem.jpg th_gx_emblem_front.jpg th_gx_emblem_reverse.jpg th_DSC07983.jpg
GX 5-Speed 84823-H7200
Reproduction
NOT 1200: This is early 610 84821-U1200 MARK-trunk lid '5-SPEED'
Sports
4-speed Center Rear (left of license plate)
Sports badge
4-speed - to right of license plate
755.jpg 1972 GL Sedan rear
Automatic
Early "Full Automatic" 79200-H1020
Late "Full Matic" 79200-H2820 from '71 April, 79200-H3200 1972
non-1200 'Nissan Matic' is blue 84821-U0300
keywords: エンブレム
Sunny Truck & Ute
See main article: Truck Badges
Van
Van uses the same badges as Sedan:
* Grille 'S' ornament (including facelift version)
* No grille trim badges (Deluxe, GL or GX)
* 'Sunny' rear quarter badge
* 'Sunny 1200' rear badge
* 'Deluxe' rear badge (DX only, early version)
* 'Sports' rear badge (DX 4-speed only)
In addition, Van used these unique badges:
96905-18100 LABEL-loading capacity '400 kg'
* lower left side
96907-G1100 LABEL-4 speed Van-Std T, Van-P T
* middle height right side
Japan Van
Van Deluxe (Japan)
Van Deluxe (export)
Custom
'DATSUN 1200' coupe badge + unknown 'VAN' badge
1200 SSS
The Datsun 1200 SSS sedan was a product from Datsun New Zealand.
SSS left-side grille emblem
Same as 62800-N0401 MARK-radiator grille "SSS" Datsun 510 Coupe KPK, Sedan PTK
5567.jpg SSS badges
82858-U0800 - same as 610/180B SSS
  • SSS badge on the glove box. Anyone have a photo?
Non-1200 SSS
These 1200 SSS badges are not to be confused with similar badges from other Datsuns that are pointy on the bottom.
910 Bluebird SSS
62892-W3500 Front Grille Mark 8201-8907 [triangular 'SSS']
62896-W1200 Front Mark 7910-8112 [octagonal 'SSS']
810 Bluebird SSS [Sedan:62396-U7625, Coupe:62396-U8325]
62397-U7600 'SSS' ~120 mm long
411 SSS rear badge
:post :full :full
PB110 Sunny Excellent
The PB110 model line for the most part uses unique badging. See the "Sunny Excellent 1400" article: PB110.
The badges that appear to be the same as B110 are:
  • 'Sunny' badge
  • 'Nissan Full Auto Matic' badge
  • Steering wheel badges
Datsun 1200 S1
The Datsun 1200 S1 2-door sedan was a Datsun of Portugal offering.
See main article: Datsun 1200 S1
  • S1 grille badge
  • S1 boot badge, fitted to left of the right taillight
Interior
The only interior badge is the steering wheel, a small piece of aluminum trim. See the steering wheel article.
Part Sources
* Nissan USA and Nissan Japan are out of badges
* Nissan Australia apparently still has some.
* eBay has them from time to time
* Yahoo Auctions Japan always has some
* Too Intense usually has some 1200 badges
* Aoba Auto
* South Yokohama
* Matsuoka
Be careful of the quality:
Malaysia repro vs Nissan item: This reproduction badge has has poor chroming and what appears to be hand-painted coloring that doesn't exactly stay within the lines. However, other reproduction badges may be high quality.
エンブレム バッジ マーク
