Stock Wheels
- 12" diameter
- 4-inch wide
wheels | B10 | B110 | 1977 US B210 A14 | 1980 NA B310 |
size | 3-1/2 J-12 | 4 J-12 | 4-1/2 J-13 | 4-1/2 J-13 5 J-13 (aluminum) Canada w/A12A: 4J-12 |
offset | ? | 30 mm | 30mm offset | 30mm 25 mm (aluminum) |
tire size | ?-12 | 6.00-12 155SR-12 | 155SR-13 | 6.00-12 155SR13 175/70SR13 |
balance | 10gr or less (0.35 oz) | 11gr or less | 10gr or less | |
lugnut torque | 8-9kg-m (58-65 ft-lb) | 8-9kg-m | 8-10 |
Datsun Option Wheels
- 40300-N5825 WHEEL SET-ROAD ALUMINIUM, B TYPE (5JX13)
- 40300-W6625 WHEEL SET-ROAD ALUMINIUM, C TYPE (5JX13)
- Also used on 200SX (S10 silvia) 1977-1979
B310 Wheels
ホイール
Lug Nuts
M12x1.25 thread
- B210: 13/16" lug nuts
See main article Wheel Studs
Torque
- 8.0-9.0 kg/m (58-65 ft-lb)
Wheel Balance
Wheel Offset
STOCK = 30 mm offset
Scrub Radius
Largest Sizes to Fit 1200
- Front: 3.25" is the maximum backspace (which is used by the stock 4" wheel). So if going wider, the offest must be reduced from +30.
- Rear: +30 offset works best with Datsun 1200.
Rear
- 9": 13 x 9 zero offset, tire 215/50r13
Ute Rear
Weights
Stock Datsun 1200 Wheels (12 x 4) weigh 11 pounds each. Virtually all aftermarket alloy wheels are heavier, except for very expensive magnesium wheels.
See main article: Wheel Weights
Wheel Adapters
Wheel Spacers
See main article: Wheel Spacers
If the wheel offset is too negative, they will fit the fenders (guards) and there is nothing you can do except cut out the bodywork, perhaps fitting large flares.
Suppliers
See Rims
Aftermarket Wheels
See Rims
Compatible Wheels
- Rear-wheel drive Toyota
- Chevrolet Corvair (5 x 13)
- pefect for the rear
- may need a 1/4 inch spacer on fronts to clear the brake caliper
- Datsun 240Z wheels -- 14"
- Uni-lug alloy wheels
- Rear-wheel-drive Mitsubishi
What WONT work:
- early Honda
- Isuzu/Holden Gemini
- Ford Escort/Cortina
- early Mazda
- Subaru
- some SAAB
FWD Rims
- Acura Vigor 1991-1994
- Acura TC 1992-1995
- Ford Laser (KA to KH)
- Hyundai Excel
- Kia 2001- (67.1 center)
Saab Wheels
- 1979-1983 SAAB 900
Sigma Rims
Sigma Turbo rims 15 inch 4x114.3
15x6
Toyota
Corolla RWD
Supra
Supra 2nd-gen
Nissan-Datsun Wheels
Bakkie White-spoke Wheels
B140 Champ wheels (trail duster style aka white-spoke steels)
A-LINE "Spoke White" of the Steel Outback Range (8-spoke)
510
510 came with 4x13 wheels (4.5x13 option?), and are often used on 1200s. Offset is +30(?).
S13 Rims
15" x 6" +40, 4 Lug, 4.5" Bolt Pattern, 10-hole USA * Base: 195/60R15 * SE: 205/60R15
10-hole Spare 15" x 4", 4 Lug, 4.5" Bolt Pattern
"Pursuit/chaser" style wheel may be used on Datsun 1200.
See main article: Pursuits
TRX Wheels
Alloy wheels from Datsun 910 "Bluebird Series II" Australia TRX package work nicely on a Datsun 1200.
See main article: TRX Wheels
Stanza SSS
Australian-assembled 1981-1983 Stanza SSS (PA10MX) has 13" alloy rims.
SSS wheels reportedly not fit 1200 without spacers.
C22
USA C22 40300-V6104 5.5-JJX14 +40 <> 40300-V6120 40300-V8000 SPARE <> 40300-V8077 [8-hole steel] 40300-17C25 AL [turbine]
810
810 Datsun 810/200B/180B/Bluebird40300-R4671 40300-U8925
910
USA 910 "Datsun 810" and "Maxima" 40300-N8810 40300-N8870 <1> 40300-N8804 40300-W1000 40300-W1004 <5> 40300-W1014 40300-W1070 <5> 40300-W1004 40300-W2426![]()
40300-W2428
Pulsar
F31
Nissan F31 was badged "Nissan Leopard" or "Infiniti M30".
buy at rtw wheels
buy at wheel collision
1990-1992 Infiniti M30 slanted 8 slot 15 x 6.5 +25 4 on 4-1/2 bolt circle Pilot hole diameter 66 mm 23 lbs left & right wheels
F31 Japan 8602-8808 14x5.5+30 7-slot styled steel 40300-58L05 8602-8702 VG20 [F31,C32] 40300-58L07 8702-8808 VG20 [F31,C32] 15x6+30 10-slot styled steel 40300-59S00 8602-8702 V20T.XS [F31,C32,R31] 40300-59S07 8702-8808 V20T.XS GOLD [F31,C32,R31] 8808-9805 VG20E *(VG20DT+VG30#) 40300-59S08 8905- VG20E *(VG20DT+VG30#) CHROME [F31] 8602-8808 spare steel 4x15 4-slot VG20 40300-03E00 8602-8808 <> 40300-28E15 <7> 40300-16E15 VG30.ULTIMA 40300-59S15 8602-8808 ALL 40300-59S15 8808- 8602-8603- alloy 8-slant/spoke 6.5x15 40300-F6226 RH 8808- <> 40300-F6228 GOLD VG20DT+VG30# *VG20E 40300-F6626 RH 8808- <> 40300-F6628 SILVER VG20DT+VG30# *VG20E 40300-F6627 LH <> 40300-F6225 40300-F6526 8602-8808 <> 40300-F6528 VG20T.XS2+VG30D.ULTIMA *(*VG20E.XJ#+*VG20T.XS) 40300-F6527 LH
Spare Tire
15x4T+40 40300-28E15 キイロ 4ケシ 60ネン キネンシヤ <> 40300-03E00 <7> 40300-16E15 * C23 Vanette * M10/M11 * S12/S13/RS13 Silvia * W10 * T12/T12Y * A31 * F31 * R31 * C32/C33 * P10/P10E * R32 * U11/U12/U13
40300-16E15 15x4T BLACK steel クロ <7> 40300-28E15 * B15 * C23 * K30S * P11/P11E * R33 * RS13/S14 * U14 * W10/WP11 * C34 * U13
S110
S110 1980-1983 Nissan Silvia Datsun 200SX/180SX/240RS 40300-N8810 4TX16 SPARE 40300-N8900 5JX14 0179-0783 40300-N8910 5JX14 0781-1081 40300-N8427 5.5JJX14 AL [16-spoke] 40300-N8825 5.5JJX14 AL <4> 40300-11S25 [16-spoke 5.5x14 +25] 40300-S6027 5.5JJX14 AL <4> 40300-N8427 [32-spoke 5.5JJ14 25]![]()
EXA Rims
EXA wheels N12 or N13 ???
For 24-spoke, see Cheviot Classic 13x5.5
S13
R30 Rims
15 X 6 Skyline R30 wheels
Z-car Rims
Datsun S30 Fairlady Z 240Z/260Z/280Z
Datsun S130 Fairlady/280ZX![]()
300ZX 4-lug![]()
See Z Rims
