Badges
Revision as of 22:18, 15 September 2015; view current revision
Category: Body
Datsun 1200s came with several badges (emblems). The original 1200 badges were metal, but the new ones -- genuine Nissan items -- are a high-quality plastic that looks very good. Aftermarket reproduction badges vary in quality from poor to very good.
Also see: Badge Part Numbers
Genuine Nissan badges are metal or plastic depending on the year made.
2200.jpg Various early B110 Sunny Emblems (Japan)
1972 JDM Facelift emblems
Market Differences
  • Japan market 1200s used "Sunny" & "S" badges
  • Export market 1200 used "Datsun", "D" badges
Colors
Most badges, especially the script ones, are simple silver color.
Sedan "S" and "D" grille emblems have red and blue bars:
Coupe "S" and "D" round emblems have tricolor red, white and blue pie sections:
Some are faded after all this time:
Most are faded to no color after 40 years:
Coupe
See main article: Coupe Badges
Sedan
10248.jpg South Africa GX badges
Grille
Center Ornament
Early center ornament 62312-H1626 ('D') and 62312-H1026 ('S')
Facelift grille 62312-H3125 ornament Late JDM intricate "S"
62312-H3100 cast mark
752.jpg 22828.jpg 7522.jpg 13057.jpg 23190.jpg th_bfsjq597-img600x450-1293012459v70sxm12525.jpg th_S_badge_reverse.jpg th_bfsjq597-img600x450-1293012459yvrlgd12525.jpg th_bfsjq597-img600x450-1293012459er55u512525.jpg
Grille Left Side Badge
NOTE: there are 3 types of GX badges:
 top: early GX grille
 middle: 1972 GX grille
 bottom: GX rear (see through script)
EARLY LEFT SIDE GRILLE
FACELIFT LEFT SIDE GRILLE BADGES
62330-H3125 EMBLEM SET-radiator grille "DELUXE"
7522.jpg 25974.jpg compare to rear badge 22513.jpg 84823-H1000
62330-H2026 GL
th_gl-GRILLE-badge.jpg 20864.jpg screw-on type. Rear GL badge is push-in type.
62330-H3325 EMBLEM SET-radiator grille "GL"
th_GL-Sedan-grille-1972.jpg th_GL-Sedan-grille-1972-reverse.jpg compare to early rectangular badge 20864.jpg
GL_grille_badge.jpg th_62330-H3300.jpg th_62330-H3300_.jpg cast mark "62330-H3300"
62330-H2325 GX
th_GX-grille-badge-2.jpg th_GX-grille-badge-1.jpg th_yunakiti-img600x450-1277628693ok47g777311.jpg th_yunakiti-img600x450-1277628693ybadxo77311.jpg th_yunakiti-img600x450-1277628693qqw7ym77311.jpg th_62330-H2225.jpg th_62330-H2225_reverse.jpg 18053.jpg
62330-H3425 EMBLEM SET-radiator grille "GX"
25658.jpg compare to early wide badge 18053.jpg or rear see-through badge th_gx_emblem.jpg
62330-H7225 EMBLEM SET-radiator grille "GX 5 SPEED"
th_62330-H7225.jpg compare to rear badge 25659.jpg 84823-H7200
Side
Rear Quarter
C-pillar Emblem
C-pillar Deluxe
C-pillar GL
23133.jpg th_m73760119scoresnewyork-img600x450-1264925423zpizbt91579.jpg th_m73760119scoresnewyork-img600x450-1264925429gqm2ek91663.jpg th_GL-c_pillar_badge_reverse.jpg
C-pillar GX
Rear
Model
Sunny 1200 - Right Rear
Datsun 1200 - Right Rear
21715.jpg 15650.jpg 16745.jpg 19425.jpg 24319.jpg 12129.jpg th_datsun_1200_emblem_1_73.jpg
Left Rear Sunny - UK???
Trim
Left Rear
Left Rear Deluxe - differs from similar looking front facelift badge
Left Rear GL - 84823-H2001 early
Left Rear GL - 1972 - 84823-H3300
non-1200 GL
Left Rear GX "see-through" script (compare to front GX badges which have a background attached)
25662.jpg 9930.jpg 23911.jpg 23912.jpg 23913.jpg 23914.jpg th_gx_emblem.jpg th_gx_emblem_front.jpg th_gx_emblem_reverse.jpg th_DSC07983.jpg
GX 5-Speed 84823-H7200
Reproduction
NOT 1200: This is early 610 84821-U1200 MARK-trunk lid '5-SPEED'
Sports
4-speed Center Rear (left of license plate)
Sports badge
"Sports" 4-speed - to right of license plate
25977.jpg 755.jpg 1972 GL Sedan rear
Automatic
Early "Full Automatic" 79200-H1020
Late "Full Matic" 79200-H2820 from '71 April, 79200-H3200 1972
non-1200 'Nissan Matic' is blue 84821-U0300
keywords: エンブレム
Sunny Truck & Ute
See main article: Truck Badges
Van
Van uses the same badges as Sedan:
* Grille 'S' ornament (including facelift version)
* No grille trim badges (Deluxe, GL or GX)
* 'Sunny' rear quarter badge
* 'Sunny 1200' rear badge
* 'Deluxe' rear badge (DX only, early version)
* 'Sports' rear badge (DX 4-speed only)
In addition, Van used these unique badges:
96905-18100 LABEL-loading capacity '400 kg'
* lower left side
96907-G1100 LABEL-4 speed Van-Std T, Van-P T
* middle height right side
'VAN' badge - Portugal
Van Deluxe (Japan)
Van Deluxe (export)
Van - Portugal
Custom
'DATSUN 1200' coupe badge + Portuguese 'VAN' badge
1200 SSS
The Datsun 1200 SSS sedan was a product from Datsun New Zealand.
SSS left-side grille emblem
Same as 62800-N0401 MARK-radiator grille "SSS" Datsun 510 Coupe KPK, Sedan PTK
5567.jpg SSS badges
82858-U0800 - same as 610/180B SSS
  • SSS badge on the glove box. Anyone have a photo?
Non-1200 SSS
These 1200 SSS badges are not to be confused with similar badges from other Datsuns that are pointy on the bottom.
910 Bluebird SSS
62892-W3500 Front Grille Mark 8201-8907 [triangular 'SSS']
62896-W1200 Front Mark 7910-8112 [octagonal 'SSS']
810 Bluebird SSS [Sedan:62396-U7625, Coupe:62396-U8325]
62397-U7600 'SSS' ~120 mm long
411 SSS rear badge
:post :full :full
PB110 Sunny Excellent
The PB110 model line for the most part uses unique badging. See the "Sunny Excellent 1400" article: PB110.
The badges that appear to be the same as B110 are:
  • 'Sunny' badge
  • 'Nissan Full Auto Matic' badge
  • Steering wheel badges
Datsun 1200 S1
The Datsun 1200 S1 2-door sedan was a Datsun of Portugal offering.
See main article: Datsun 1200 S1
  • S1 grille badge
  • S1 boot badge, fitted to left of the right taillight
Interior
The only interior badge is the steering wheel, a small piece of aluminum trim. See the steering wheel article.
Part Sources
* Nissan USA and Nissan Japan are out of badges
* Nissan Australia apparently still has some.
* eBay has them from time to time
* Yahoo Auctions Japan always has some
* Too Intense usually has some 1200 badges
* Aoba Auto
* South Yokohama
* Matsuoka
Be careful of the quality:
Malaysia repro vs Nissan item: This reproduction badge has has poor chroming and what appears to be hand-painted coloring that doesn't exactly stay within the lines. However, other reproduction badges may be high quality.
エンブレム バッジ マーク
